check domoticz with monit and restart when check fails Topic is solved
curious
Post by curious »
I installed monit to check my raspberry and particular domoticz because I often have to restart the domoticz service
I use code below in monit config to restart domoticz when "things" go wrong.
The code runs fine only the check fails :
url http://127.0.0.1:8080/json.htm?type=com ... getversion
and content = '"status" : "OK"'
Does it always have to be 127.0.0.1:8080 or should it be an other ip-address (my domoticz ip for example) ?
check process domoticz with pidfile /var/run/domoticz.pid
 start program = "/etc/init.d/domoticz.sh start"
 stop program = "/etc/init.d/domoticz.sh stop"
 if failed
 url http://127.0.0.1:8080/json.htm?type=command&param=getversion
 for 2 cycles
 then restart
 if 5 restarts within 5 cycles then exec "/sbin/reboot"
if cpu usage > 70% for 3 cycles then restart
I am using Raspberry 2
jvdz
Domoticz version: 4.107
Re: check domoticz with monit and restart when check fails
Post by jvdz »
Shouldn't this:
be :
 and content == '"status" : "OK"'
Jos
curious
Post by curious »
@Jos
I don't know. It's not what is in the downloaded code.
But should 127.0.0.1 be correct ? I can ping this address by the way but when adding portnumber it says host unknown
This is the error message :
connection failed to 127.0.0.1:8080/json.htm?type=command¶m=getversion [HTTP via TCP]
mark.sellwood
Post by mark.sellwood »
My monit config contains the following:-
# Monitor Domoticz
if failed
for 2 cycles
then restart
In Domoticz on the Settings Tab do you have 127.0.0.1 entered under Local Networks (no username/password): ?
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
curious
Post by curious »
I indeed forgot to add the ip-address, but now I did, the errors remains.
'domoticz' failed protocol test [HTTP] at INET[127.0.0.1:8080/json.htm?type=command&param=getversion] via TCP -- HTTP error: Regular expression doesn't match: No match
mark.sellwood
Try replacing 127.0.0.* with 127.0.0.1
curious
Post by curious »
mark.sellwood wrote: Friday 27 October 2017 12:53 Try replacing 127.0.0.* with 127.0.0.1
Still the same error
mark.sellwood
Are you sure the web interface is running on port 8080?
From another computer on your network what do you get if you enter:-
http://x.x.x.x:8080/json.htm?type=comma ... getversion
Where x.x.x.x is the IP of you Domoticz computer
curious
Post by curious »
I was pretty sure about that :) but checking doesn't harm.
The results are :
"DomoticzUpdateURL" : "http://www.domoticz.com/download.php?ch ... ine=armv7l",
"HaveUpdate" : false,
"Revision" : 8153,
"SystemName" : "linux",
"build_time" : "2017-07-30 12:19:41",
"hash" : "494fff7",
"status" : "OK",
"title" : "GetVersion",
"version" : "3.8153"
In the file I have this line of code too:
allow 10.0.0.4/10.0.0.255        # allow localhost to connect to the server and
Should I add some other ip-addresses ?
mark.sellwood
I don't think the allow statement is correct from memory, I'll have a look at my config when I'm back at home later today.
curious
Post by curious »
The IP-range of my local network is from 10.0.0.1-10.0.0.255
The code of the 'allow'-part :
set httpd port 2812 and
 use address 10.0.0.12  # only accept connection from localhost
   allow admin:monit      # require user 'admin' with password 'monit'
    allow @monit           # allow users of group 'monit' to connect (rw)
    allow @users readonly  # allow users of group 'users' to connect readonly
mark.sellwood
My allow is:-
    allow 192.168.1.0/24        # allow localhost to connect to the server and
So I think yours should be:-
   allow 10.0.0.0/24
Did you try the command
sudo monit -t
This should check your config file & tell you if there are any errors.
Remember to restart monit with
sudo service monit reload
curious
Post by curious »
After changing the allow- line it seems to work now.
Correct me if I am wrong but the example code is not very clear.
However, thank you for your help.
EDIT : Does not work after al. I forgot to uncomment some lines. And after that the same error-message returned.
Will try to play with some ip adresses in the allow-line.
Syntax is OK
mark.sellwood
I think the Wiki needs to be updated as things have changed in monit. I'm rebuilding my systems at present & I know I had to change my existing config as it didnt work.
Below is my config for the webserver bit
Configure Webservice
   	 use address 127.0.0.1  # only accept connection from localhost
curious
Post by curious »
Still doesn't work and as I am not a script specialist I only can rely on whats in the wiki.
So i am afraid it ends for me here. Monitor runs fine now, and I will keep watching it so now and then to see if there is something special
Andyf66
Post by Andyf66 »
The monitor check seems to be failing at the moment on raspberry pi due to the '&' in the URL, which isn't being escaped and breaks syntax. I fixed it by changing the monitrc file to look like this:
if failed host 127.0.0.1 port 80 protocol http
and request "/json.htm?type=command&param=getversion"
for 2 cycles
then restart
jake
Post by jake »
Sometimes Domoticz is acting weird with the & sign in the url.
You can try a quick work-around as I have successfully done as well in this topic: viewtopic.php?p=170057#p170057
Simply put the 'param=...' part of the url in a different order, in such a way that & isn't followed by 'p'. For the JSON command it doesn't make a difference, but it will gve you the right hyperlink without breaking it up or adding funny characters in between.
So change line 1 into line 2 to try:
http://127.0.0.1:8080/json.htm?param=ge ... pe=command
I would recommond to keep for the rest the original script. In your version you're not checking for the Status = OK version, so I wonder what the script checks at the moment.
I check my domoticz instance using this monit check:
# Check domoticz
check process Domoticz with pidfile  /var/run/domoticz.pid
if not exist for 8 cycles then restart    # 8 minutes
if failed
        url http://192.168.192.nn:nnnn/json.htm?type=command&param=getversion  # comment
if memory usage > 80% then restart
if 5 restarts within 5 cycles then alert
alert [email protected]
the availability of the system itself and port 80 is checked from another system with.
# Check PI's using ping / port
check host PI-1 address PI-1
if failed ping then alert
if failed port 80 protocol http then alert
    alert [email protected] with reminder on 10 cycles
check host PI-2 address PI-2
# if failed port 80 protocol http then alert # test system
check host PI-3 address PI-3
# if failed port 80 protocol http  then alert  # development system
#end
Theedoek
Post by Theedoek »
I have the exact same thing but can't get it to work.
When I execute "http://192.168.0.100:8080/json.htm?type ... getversion" from a remote host (PC running Win10) on the same network, I get a reply containing a JSON array with data like the Domoticz version number, update url and so on.
If I execute "curl http://127.0.0.1:8080/json.htm?type=com ... getversion" from the command line (via putty), I get a
   "status" : "ERR"
I have added 127.0.0.1 to the local networks list. Before I did that I used to get an access denied message.
What can be wrong here? I am dying to get this sorted out, but I am not a guru in this :D
Theedoek wrote: Thursday 09 August 2018 19:29 I have the exact same thing but can't get it to work.
   "status" : "ERR"
You could try with
curl -s -X GET "http://127.0.0.1:8080/json.htm?type=command&param=getversion"
