Can you please test this version and do a clean install.
domoticz_apollolake-6.2_4.0.9700-7.spk (updated version)
http://www.jadahl.com/domoticz_stable_6 ... 9700-7.spk
Here you should have /usr/local/domoticz/dzVents/runtime
Ha ha
Thanks for your prompt reply! And guess what: this evening I got a notification of my DS218+, that DSM6.2 is ready to install (running now DSM6.1)jumbotroll wrote: ↑Sunday 24 June 2018 15:05 I did update my DS712+ from DSM6.1 to DSM6.2 without any problem. (Not need to reformat)
The domoticz version with python is build with python plugin if you need that and you have to install the python3.5.1 from synology before you install this version or the domoticz package will not run.
I will build v.4.9700 for DSM 6.1 too, later this weekend, but it take some time to build all this packages.
The homepage is updated and the packages is updated gradually.
Edit:bldewit wrote: ↑Monday 25 June 2018 0:31 @Jumbotroll,
Thanks for the great work so far!
After Goodwe have changed their server infrastructure (due to the new EU privacy legislation) the Goodwe Web Connection interface in Domoticz has been down since June 2nd. The interface has now been adapted in Domoticz. Can you make that change available to Synology users? I am running a DS211 and don't have the skills to compile Domoticz myself.
Would be great if you could make my inverter work with Domoticz again!
Thx,
Bart
I will upload all stable release v.49700, but it take some time to compile for all versions
Because if you are on an old version, the install script take backup and restore old folders, but you can test to only do a update and if all working you are fine. But if you use dzVents, you maybe have to do a clean install..
jumbotroll wrote: ↑Sunday 24 June 2018 23:42 @Gravityz
The files should be in correct folders now.
All v4.9700 packages will be updated with this fix tomorrow.
Apollolake is fixed, do a clean install.
/usr/local/domoticz/dzVents/runtime$
device-adapters HistoricalStorage.lua persistence.lua Time.lua
Device.lua HTTPResponse.lua Security.lua Timer.lua
Domoticz.lua integration-tests tests todo.md
dzVents.lua lodash.lua TimedCommand.lua Utils.lua
EventHelpers.lua misc
It is: http://www.jadahl.com/domoticz_stable_6 ... apollolakeGravityz wrote: ↑Monday 25 June 2018 17:46 it is just not my lucky day.
the appollolake package WITHOUT PYTHON(DS718+) is not updated, the one with python(which i do not use) is.
can you update the package so i can try. i just did a clean install and found out the hard way that dzVents still is missing
i am geting handy at doing fresh installs now
Hmm..I will check that
There will NOT be any domoticz V.49700 for DS211 DSM 6.2.sincze wrote: ↑Monday 25 June 2018 17:57 @jumbotroll I was just wondering.
I've a DS211 with DSM 5.2, running Domoticz Stable (previous version) at a remote site keeping my parents happy.
Never had any problems. Great job![]()
Before upgrading to DSM 6.2 I was looking If I could find "Domoticz 4.9700 stable for DSM6.2" for DS211.
However the DS211 is not listed.
Should I be worriedthere is no more time to compile it for the DS211 ?
To much dependencies?
Hope It will be available for me so I can upgrade and have a great new setup again.
tnx.
Thanks I thought I already read it somewhere but it was worth the shot.jumbotroll wrote: ↑Monday 25 June 2018 18:02There will NOT be any domoticz V.49700 for DS211 DSM 6.2.
Synology toolchain is to old and will not build latest domoticz with -std=c++11
Great
