Aurora theme
Re: Aurora theme
Im playing with theme css, and have idea about custom image (PNG with transparency) on bottom page backgrounds for each Room (different energy monitoring ,tv, irrigation, security...).
For whole theme it works pretty well (i can post screenshots and css). But looks like, i cant change it individualy because rooms are not using any css identifiers.... Any idea how to solve this?
rhendriks
- Domoticz version: Newest
Re: Aurora theme
Theme button is gone.
I have update several times but there is no button.
How can I fix this?
How can I fix this?
Xztraz
Re: Aurora theme
Running beta?rhendriks wrote: Monday 11 June 2018 19:29 Theme button is gone.
How can I fix this?
Test other browser with clean cache and files
SweetPants
Re: Aurora theme
No problem on V3.9629rhendriks wrote: Monday 11 June 2018 19:29 Theme button is gone.
How can I fix this?
rhendriks
Re: Aurora theme
SweetPants wrote: Tuesday 12 June 2018 12:35No problem on V3.9629rhendriks wrote: Monday 11 June 2018 19:29 Theme button is gone.
How can I fix this?
I mean this , normally stay under " Backup/Herstel" the theme button.
rhendriks
Re: Aurora theme
Yes
SweetPants
Re: Aurora theme
Xztraz
Re: Aurora theme
I'm on latest beta and i see the theme button.
looking at the code for that
one fault condition could be no web storage. so have you blocked web pages to store local files or something in your browser? did you try with another browser?
// actually adding the settings tab.
if (typeof(Storage) !== "undefined") { // Do we even have theme settings?
if (!$('#tabtheme').length){
// modifying settings menu
$('#tabs .pull-right').before('<li id="themeTabButton"><a data-target="#tabtheme" data-toggle="tab" data-i18n="Theme">Theme</a></li>');
// If were on a mobile phone, make the settingsmenu a dropdown.
$('#tabs li:not(.pull-right)').click(function() {
if ($(window).width() < 480) {
$(this).parent().toggleClass('menuopen');
if( !$(this).parent().hasClass('menuopen') ){
$(this).siblings('li:not(.pull-right)').slideUp("fast");
}else{
$(this).siblings('li:not(.pull-right)').slideDown("fast");
}else{
$(this).siblings().show(); //safety, if user scaled/rotated the screen.
$(this).parent().removeClass('menuopen');
// inserting the themesettings.html
$('#my-tab-content').append('<div class="tab-pane" id="tabtheme"><section id="theme">Loading..</section></div>');
$('#my-tab-content #theme').load("acttheme/themesettings.html",loadedSettingsHTML);
// loadedSettingsHTML() was here
} else {
// No Web Storage support.. hmm.
}Re: Aurora theme
When I change any settings and press save, all settings are reverted to default.
I'm using a baseURL in my domoticz, perhaps this needs special configuration with aurora?
I've tried using the parameter baseURL in custom.js but it doesn't do anything..
Re: Aurora theme
Setting in aurora is saved afaik localy, so it looks like problem with you browser (cookies disabled or private browsing enabledMaes wrote: Thursday 14 June 2018 13:01 When I change any settings and press save, all settings are reverted to default.
Re: Aurora theme
Thanks for the help.
I checked and my chrome browser was still in pornhub mode.
I turned it off and the settings are "saved". However, the menu bar keeps going back to the top (but the setting clearly states that it should be a side bar)
Re: Aurora theme
try reset theme to default setting and reset app-cacheMaes wrote: Thursday 14 June 2018 14:23 Thanks for the help.
Re: Aurora theme
I tried this just now but it doesn't work.devros wrote: Thursday 14 June 2018 14:28try reset theme to default setting and reset app-cacheMaes wrote: Thursday 14 June 2018 14:23 Thanks for the help.
If I uncheck the setting "Main menu as a sidebar" and check it again then the menu goes to the side. However, once I press "APPLY SETTINGS" the menu bar goes back to the top. The setting is still saved as checked, though.
jannnfe
Re: Aurora theme
i love the Aurora Theme but i'm not able to get the Camera Live Stream in Dashboard.
It looks like this: and my Camera is linked to this devices: In the Settings the Camera Option of Aurora is enabled.
What to do?
What to do?
Re: Aurora theme
Switch Dashboard mode from compact to normal...jannnfe wrote: Thursday 14 June 2018 23:46 Hello,
What to do?
Thanks!![]()
then it should work
jannnfe
Re: Aurora theme
No sorry also in Normal mode there is no preview of the camera live feed.devros wrote: Friday 15 June 2018 8:42Switch Dashboard mode from compact to normal...jannnfe wrote: Thursday 14 June 2018 23:46 Hello,
It looks like this:
What to do?
Thanks!![]()
then it should work
Cleared cache and browser history.
- bueno79
- Domoticz version: 4.9700
Re: Aurora theme
Hi, did you try the theme with 4.9700 ? Does it fully work ? Sad it is not implemented by default...
Jem101
Re: Aurora theme
I'm running the latest beta which is slightly ahead of the release version and the Aurora theme works just fine. Which is not to say that it definitely works with 4.97 but I'd be astonished if it doesn't.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
- bueno79
Re: Aurora theme
hi,
I've test and yes it works on 4.9700. Still a bug on kodi telecommande popup windows. I love the theme, very interesting but we should be able to choose which device we want to display in 'big' and which one in small. camera or weather are interresting in Big and there is a good add ed value. for Switchs small is enought.
