Can't add a Dummy Selector
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
Whatever I try, do not get a dummy selector added to Domoticz. Have tried the following things:
- add dummy, add it via manual light
- via create virtual sensors
What do i wrong? :cry:
Anyone can build a fast processor. The trick is to build a fast system.
HansieNL
Re: Can't add a Dummy Selector
Post by HansieNL »
Hardware - Setup - Dummy (Create Virtual Sensors) - Sensor Type = Selector Switch
Blah blah blah
mAiden88
Post by mAiden88 »
HansieNL wrote: Wednesday 06 June 2018 17:22 Hardware - Setup - Dummy (Create Virtual Sensors) - Sensor Type = Selector Switch
I did @HansieNL.
But dont see the Dummy Selector.
Venzent
Domoticz version: 3.8153
Post by Venzent »
Under Hardware, first add the Dummy (under the list of already available hardware), then when added, you can add dummy devices
Schermafbeelding 2018-06-06 om 17.33.18.png (348.69 KiB) Viewed 2913 times
mAiden88
Post by mAiden88 »
@Venzent,
I did:
Venzent
Post by Venzent »
Mmmm, ok, and when you select "Create Virtual Sensor" , give it a name and type and save it, it does not appear under " Switches".
Is there anything in the log?
mAiden88
Post by mAiden88 »
Venzent wrote: Wednesday 06 June 2018 17:44 Mmmm, ok, and when you select "Create Virtual Sensor" , give it a name and type and save it, it does not appear under " Switches".
Unfortunately, also via Create Virtual Sensor, do not get any of my dummy switch.
Ric68
Post by Ric68 »
It seems that there is a general issue with adding switches.
I just got IKEA-Tradfri plugin to work and I can see 10 switches in the devices-list (and all is added with the "Add Light/Switch Device" commando, and I can also control them from the devices-list, but the Switches-tab is completely empty
I also tried to add a dummy switch without success as mentioned in this thread
Tested on both 9573 and 9580 on a Raspberry PI 3+
mAiden88
Post by mAiden88 »
Have it solved. Apparently it was my browser, Chrome does not see the selector added, but Internet Explorer does. (I did not try Edge, I do not like it.)
