[MyDomoAtHome] Support thread
Re: [MyDomoAtHome] Support thread
Hi back.
Thanks for the support.
I see all those devices in domoticz and I can use them (e.g. switches). Just it seems that my MyDomoAtHome service on the system might not get updates when I create new devices.
After I set up MyDomoAtHome and the ImperiHome app on the phone (all worked great...) I added new devices to domoticz. Only those new ones I cannot see in the ImperiHome app. I can see/use them in domoticz (also see them in "domoticz-ip/#/devices").
Last time I had this issue (after adding two new devices), I tried to stop/start the services (stop MyDomoAtHome, then stop domoticz and restart them both in revers order) result = nothing. ImperiHome app worked well, just not see the newly added devices.
Only when I deleted the ImperiHome app from phone, reinstalled it and set up a new dashboard, I also see the newly added devices and can use them in ImperiHome app.
Seems to me there might be a kind of configuration issue somewhere (e.g. something like "only use previous devices" or something like that....). Looked in ImperiHome app configuration but cannot make any changes there on this behaviour.
Don't know enough of the MyDomoAtHome service on my NAS. Maybe I need to make some config changes there? I just took it, installed it and in ran.
Just think that deleting/reinstalling each time I add new devices might not be the way it is meant to work.
Question is: How can I make it that the ImperiHome app on iOS always gets the actual device list?
Apart from that all works fine.
Maybe someone with same experience? Or a solution (would be even better )
Thanks a lot.
Thanks a lot.
Ah well ..... consider my problem as solved!
All is working great - except my brain.
It was me not seeing the ‚reload‘ button in the ImperiHome app.
Once a clever user press this, the app reloads the actual device list from domoticz and everything is running very smooth.
Shame on me!
Working now! Good guys! Thanks a lot for this solution!
Shame on me!
Yeah, I've tried that and the RGB switch for all of my RGB devices is no longer showing in the /devices list. I'm assuming that there's been a change in how these devices are handled within Domoticz that stops them working with MDAH.
marcojpolet wrote: ↑Sunday 13 May 2018 7:22 Hi,
If you're missing devices in ImperiHome, you might check the /devices link of your DomoAtHome server (i.e. http://serverip:port/devices). In there you should get a list of all your devices. If you don't see your device there, it for sure won't show up in ImperiHome. If it does, you need to check ImperiHome settings.
Regards,
Marco
Hello
I can not connect to MDAH anymore
it worked well before.
I do not understand.
can you help me ?
can you help me ?
Same problem. No devices page on mydomoathome server. Used to work. constantly updating domoticz to latest build and now it's not giving any data to imperihome.
tried the /device page. can't reach(browser gives error)
page in/ works so i assume something is working.
log just repeats:
Also. isn't latest version .37? cant update with apt-get says i have latest
log just repeats:
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:37.762Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:37.769Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:38:45.390Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:38:45.411Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:38:45.414Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:45.416Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:45.423Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:38:50.884Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:38:50.905Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:38:50.908Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:38:50.910Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:38:50.916Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8080/json.htm","timestamp":"2018-05-24T16:39:01.408Z"}
{"level":"info","message":"Node version: 4.9.1","timestamp":"2018-05-24T16:39:01.430Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.36","timestamp":"2018-05-24T16:39:01.434Z"}
{"level":"info","message":"OS version: Linux linux 4.1.18-v7+","timestamp":"2018-05-24T16:39:01.437Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.1.199 in /var/www /","timestamp":"2018-05-24T16:39:01.446Z"}
Having looked through some of the recent changes made in the latest beta of Domoticz this one seems to be the potential culprit -
https://github.com/domoticz/domoticz/issues/2078 - "Feature suggestion: WW / RGB / RGBW / RGBWW dimmers"
There's now a sub-type of RGBWW, I can see within MDAH that the sub-types RGB & RGBW are handled but not RGBWW -
I'm far from being a coder but as far as I can tell this may be the cause of my issue.
UPDATE - I've just noticed that I have one RGBW device and that's not showing in /devices either so there must be more to it than I was thinking.
case 'Dimmer':
if (data.result[i].SubType == 'RGB') {
//console.log("OK"+data.result[i].SubType);
result.push(DevRGBLight(data.result[i]));
} else if (data.result[i].SubType == 'RGBW') {
} else {
result.push(DevDimmer(data.result[i]));
i just plugged my pi2, clean install of domoticz with stable version v3.8153 it works
I switch to beta v3.9501 and it does not work anymore. so this is a problem in the beta ....... and the problem is that I need the beta
je viens de rebrancher mon pi2, install propre de domoticz avec la version stable v3.8153 ça fonctionne
je passe en beta v3.9501 et ça ne fonctionne plus. c'est donc bien un probleme dans la beta ....... et le probleme c'est qu'il me faut la beta
a new video
someone else has the same problem on a synology.
with version V3.9478
https://easydomoticz.com/forum/viewtopi ... 622#p54621
a new video
- epierre
fix done, package will be out tonight !
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Works! I was hoping my new soil moisture sensor would show up too. but doesn't seem like imperihome have support for that. So mailed them a feature request for that.
- epierre
If you have the definition in json.htm I can make a custom
All now working, thanks epierre.
hi i was installing mydomoathome and stumbled on to a problem
i did follow the guide and up till the point of installing the server and the configuration file i'm a bit lost here and can not get it to work proper
"Important remark: do not install as root, but sudo as an unprivilegied user."
what is unprivilagied user?? i have just installed it using pi and raspberry as login
"Edit the configuration file with your values:
sudo nano /etc/mydomoathome/config.json"
what must be in this file
i have set the ip to the same ip as domoticz
and did ad the login and password i use in domoticz
result i get
"app_name": "MyDomoAtHome",
"auth": null,
"domoticz": {
"ssl": false,
"host": "192.168.1.XXX",
"port": "8080",
"path": "/",
"auth": null,
"port": 3002,
"passcode": { "username": "jess", "password": "XXXXX" },
pi@raspberrypi ~ $ curl http://domoticz_ip:domoticz_port/json.htm?type=devices&filter=all&used=true&order=Name
[1] 875
[2] 876
[3] 877
pi@raspberrypi ~ $ curl: (6) Could not resolve host: domoticz_ip
filter=all&used=true&order=Namecz_port/json.htm?type=devices&
[4] 879
[5] 880
[6] 881
[1] Exit 6 curl http://domoticz_ip:domoticz_port/json.htm?type=devices
[2] Done filter=all
[3] Done used=true
[5]- Done filter=all
pi@raspberrypi ~ $ [1] 875
-bash: [1]: command not found
[6]+ Done used=true
pi@raspberrypi ~ $ [2] 876
-bash: [2]: command not found
pi@raspberrypi ~ $ [3] 877
-bash: [3]: command not found
pi@raspberrypi ~ $ pi@raspberrypi ~ $ curl: (6) Could not resolve host: domoticz_ipcurl: (6) Could not resolve host: domoticz_ip
- epierre
Remove the coma between the two }}
thats what i just did with same resault
what i do see is here when i enter the ip in internet explorer to port 3002
the instructions of mydomoathome but on the side i get this
AppName: MyDomoAtHome
MDAH: http://192.168.1.xxx:3002
Domoticz: http://127.0.0.1:8080/json.htm
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
the domoticz ip is not correct altho i have set the correct one in the config file above
"auth": null,
"domoticz": {
"ssl": false,
"host": "192.168.1.xxx",
"port": "8080",
"path": "/",
"auth": null,
"port": 3002,
"passcode": { "username": "jessy", "password": "xxxxxxx" }
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
- epierre
sorry this one:
"auth": null,}
just remove the coma
"auth": null,}
hi this did help also i saw that i'v put my log in and password in the wrong field
when i open mdah in browser i get
Domoticz: http://jessy:[email protected]:8080/json.htm
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
so i tought it would work
but i still get the error
sorry kind of a noob when it comes to this , car mechanic not a programmer
"auth": null,
"domoticz": {
"ssl": false,
"port": "8080",
"path": "/",
"auth": { "username": "jessy", "password": "xxxxxx" }
"port": 3002,
"passcode": ""
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
[1] 1016
[2] 1017
[3] 1018
[2]- Done filter=all
strange but somhow got it to work
only thing i cant do in imperihome is use the dimmers it shows only on or off
will be something for tomorrow to trie and get that to work
thanks for the help
thanks for the help
- Domoticz version: 2020.1
I'm having a recurring issue (https://github.com/empierre/MyDomoAtHome/issues/156), where MDAH stops with an Unexpected end of input:
It occured after updating to 0.2.39. Before it has been running for weeks without stopping.
info: Domoticz server: http://127.0.0.1:8084/json.htm
info: Node version: 4.8.7
info: MDAH version: MyDomoAtHome 0.2.39
info: OS version: Linux linux 3.2.40
info: Hostname: NAS 192.168.2.201 in /root /root
info: Refreshing version cache: v0.2.39
[SyntaxError: Unexpected end of input]
undefined:2267
at Object.parse (native)
at Request._callback (/volume1/@appstore/MyDomoAtHome/app/mdah.js:2346:18)
at Request.self.callback (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:200:22)
at emitTwo (events.js:87:13)
at Request.emit (events.js:172:7)
at Request.<anonymous> (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:1067:10)
at emitOne (events.js:82:20)
at Request.emit (events.js:169:7)
at IncomingMessage.<anonymous> (/volume1/@appstore/MyDomoAtHome/app/node_modules/request/request.js:988:12)
at emitNone (events.js:72:20)
at IncomingMessage.emit (events.js:166:7)
I moved to HomeAssistant. It was fun while it lasted!
- epierre
it is the result of getting a json request, that code has not changed, maybe a stability issue on domoticz ?
