Thanks for the support.
I see all those devices in domoticz and I can use them (e.g. switches). Just it seems that my MyDomoAtHome service on the system might not get updates when I create new devices.
After I set up MyDomoAtHome and the ImperiHome app on the phone (all worked great...) I added new devices to domoticz. Only those new ones I cannot see in the ImperiHome app. I can see/use them in domoticz (also see them in "domoticz-ip/#/devices").
Last time I had this issue (after adding two new devices), I tried to stop/start the services (stop MyDomoAtHome, then stop domoticz and restart them both in revers order) result = nothing. ImperiHome app worked well, just not see the newly added devices.
Only when I deleted the ImperiHome app from phone, reinstalled it and set up a new dashboard, I also see the newly added devices and can use them in ImperiHome app.
Seems to me there might be a kind of configuration issue somewhere (e.g. something like "only use previous devices" or something like that....). Looked in ImperiHome app configuration but cannot make any changes there on this behaviour.
Don't know enough of the MyDomoAtHome service on my NAS. Maybe I need to make some config changes there? I just took it, installed it and in ran.
Just think that deleting/reinstalling each time I add new devices might not be the way it is meant to work.
Question is: How can I make it that the ImperiHome app on iOS always gets the actual device list?
Apart from that all works fine.
Maybe someone with same experience? Or a solution (would be even better
Thanks a lot.
