[MyDomoAtHome] Support thread
- epierre
Imperihome released its API that permits any system implementing it to be recognized and integrated in ther mobile device UI.
http://www.imperihome.com/apidoc/systemapi/
It is quite easy to integrate with, and that would permit to have a WAF UI available for tablet and smartphone.
INSTALLATION
Please see https://github.com/empierre/MyDomoAtHom ... /README.md
SUPPORT
Regarding support: since I don't have all devices, please send to [email protected] your domoticz.db so I can try to reproduce what you have and make a more efficient support on devices I wouldn't have.
LAST CHANGES (see https://github.com/empierre/MyDomoAtHome)
Latest updates:
- RGB devices
- multiswitch
- custom sensor
- graphes on all devices day/week/month/year
TODO:
- local camera
- grouping switches and instant energy
INSTALLATION
SUPPORT
Latest updates:
- RGB devices
- multiswitch
- custom sensor
TODO:
- local camera
Last edited by epierre on Tuesday 14 November 2017 22:01, edited 6 times in total.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
joshimosh
Re: [MyDomoAtHome] Support thread
Installed and works flawlessly ! Thanks a lot.
If it is not too much work for you, may I ask you to post a short hint in this thread when a new update has been made ?
Thank you for your work.
Josh
Josh
- epierre
Well this is work in progress, some changes yesterday with confirmation by users today so here are the news:
NEW:
- Full thermostat support including changing the Setpoint
- push on/off button roll backed to switch
TODO:
- manage curves for all devices
- RGB management
- some UTF fixes ?
- a barometer issue ?
NEW:
TODO:
- RGB management
- some UTF fixes ?
- epierre
Well utf8 issue is on arm, not on intel...
I've asked about the fix, but have a few hope on this...
https://github.com/PerlDancer/Dancer/issues/882
joshimosh
Thank you for this update. I can confirm that there seems to be an issue with barometric pressure. Instead of barometer, temp and humidity are displayed.
Anyway, for tablet display, for my taste Imperihome looks better than the (standard) Domoticz dashboard - but of course you can discuss endlessly about taste
So again: thank you very much for your work ! I really appreciate it.
Cheers
Josh
Cheers
Josh
- epierre
Take a look, you chould have both in two separated devices.joshimosh wrote:Thank you for this update. I can confirm that there seems to be an issue with barometric pressure. Instead of barometer, temp and humidity are displayed.
Josh
Domoticz has one object for Temp+Hum+Baro, Imperihome has two (btw they have the same name)
- epierre
I have a solution that will require, when validated, to make an upgrade to Dancer2, so a simple upgrade won't be possible for those using the current version.epierre wrote:Well utf8 issue is on arm, not on intel...
Stay tuned, it may also improve performance again !
joshimosh
Yes, I know. The problem is that in Imperihome both objects give me Temp+Hum, but no Baro.epierre wrote:Take a look, you chould have both in two separated devices.joshimosh wrote:Thank you for this update. I can confirm that there seems to be an issue with barometric pressure. Instead of barometer, temp and humidity are displayed.
Josh
- epierre
They have the same display name, try reloading in imperihome your devicesjoshimosh wrote:Yes, I know. The problem is that in Imperihome both objects give me Temp+Hum, but no Baro.epierre wrote:Take a look, you chould have both in two separated devices.joshimosh wrote:Thank you for this update. I can confirm that there seems to be an issue with barometric pressure. Instead of barometer, temp and humidity are displayed.
Josh
joshimosh
Hi, me again:-)
once more: thank you so much for providing this gateway to Imperihome. I have only started to explore the potentials. Domoticz + MySensors + Imperihome is an extremely useful combination for me - exactly what I've been looking for.
I can only hope that you keep up your work. Thanks again
Josh
Josh
- epierre
fine, the best of all worlds for me, a central controller and a good app, with all the possibilities for hardware, this is the best combination !
joshimosh
since a few days I am experiencing problems with this gateway.
Problem 1: It crashes from time to time. In nohup.out I see the follwing lines:
2015/06/24-08:19:26 Starman::Server (type Net::Server::PreFork) starting! pid(2635)
Resolved [*]:5001 to [0.0.0.0]:5001, IPv4
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Die Adressfamilie wird von der Protokollfamilie nicht unterst%C3%BCtzt at /usr/share/perl5/Net/Server/Proto.pm line 133.
Binding to TCP port 5001 on host 0.0.0.0 with IPv4
Setting gid to "1000 1000 4 5 20 24 27 29 44 46 60 100 105 107 999 1000 1002 1003"
TYPE:temp + humidity
2015/06/24-11:24:55 Server closing!
Problem 2: I can start the gateway "by hand":
cd domoticz/MyDomoAtHome
start.sh
Since I want the gateway to start automatically during start-up of my Raspi, I have entered in /etc/rc.local the line
/home/pi/domoticz/MyDomoAtHome/start.sh
(/home/pi is the home directory)
The gateway is not running afterwards. Same thing if I enter /home/pi/domoticz/MyDomoAtHome/start.sh
If it required that I have first to switch to the directory where the gateway resides before I can call start.sh ?
If so, may I suggest that you mention it in your description ?
Cheers
Josh
start.sh
Cheers
Josh
- epierre
2015/06/24-11:24:55 Server closing!There is a proper start script to use, place it in /etc/init.d with executable flags, modify the paths in it line 20, and add the runlevels corresponding to your system:
https://github.com/empierre/MyDomoAtHom ... oAtHome.sh
joshimosh
Thank you for your fast reaction, most welcome !
Will try the start script.
As to the issue "Server closing!": I did not perform a manual kill. I started the gateway with start.sh, as decsribed in the wiki. The gateway detaches from the shell (nohup) and works fine after I have closed the terminal session.
As you can see from the output of nohup, start was at 8:19, closing several hours later at 11:24. I did not have any open session on that Raspi at 11:24.
Anyway, thanks a lot. I will have an eye on it and will keep you posted.
Cheers
Josh
Cheers
Josh
jkimmel
- Domoticz version: 2021.1
Once again I try to get familar with IH.
I just put my nohup.out here, maybe it is selfexplaining.
2015/06/29-16:37:51 Starman::Server (type Net::Server::PreFork) starting! pid(27037)
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Address family not supported by protocol at /usr/share/perl5/Net/Server/Proto.pm line 133.
2015/06/29-16:37:51 Can't connect to TCP port 5001 on 0.0.0.0 [Address already in use]
at line 67 in file /usr/share/perl5/Net/Server/Proto/TCP.pm
2015/06/29-16:37:51 Received QUIT. Running a graceful shutdown
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 355.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 385.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 405.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 413.
2015/06/29-16:37:51 Worker processes cleaned up
2015/06/29-16:37:51 Server closing!
shutdown() on closed socket GEN1 at /usr/lib/perl/5.14/IO/Socket.pm line 294.
Rfxcom
Raspi 4
Raspi 4
- epierre
@jkimmel there is already a process on port 5001
and kill the process, certainly a starman already up, and start again.
try finding it out with :2015/06/29-16:37:51 Can't connect to TCP port 5001 on 0.0.0.0 [Address already in use]
sudo lsof -i tcp:5001ImperiHome & MyDomoAtHome on top of:
joshimosh
Good evening,
I have a question: does your gateway relay sounds from Domoticz to Imperihome ? My best guess is that it does not (I can imagine that this would be pretty difficult), but who knows
Cheers Josh
Cheers Josh
pluggin
This gateway works on ARM architecture like raspeberry PI?
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
- epierre
is there sound in domoticz ?joshimosh wrote:Good evening,
Cheers Josh
- epierre
yes it works on PI, and since it is architecture independant (in perl) it works on any computer given you have the right librariespluggin wrote:This gateway works on ARM architecture like raspeberry PI?
