After latest update the dZvent system is broken. Lots of set... commands are not working anymore for example:
I already reported.
setRGB
Method setRGB is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
Method setDiscoMode is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.Code: Select all
Method setKelvin is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
Method dimTo is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
Method switchOff is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
