dZvents broken with 3.9165
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
After latest update the dZvent system is broken. Lots of set... commands are not working anymore for example:
I already reported.
setRGB
Method setRGB is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
setDisco
Method setDiscoMode is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
setKelvin
Method setKelvin is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
dimTo
Method dimTo is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
switchOff
Method switchOff is not available for device "Dressoir" (deviceType=Color Switch, deviceSubType=RGBWW). If you believe this is not correct, please report.
devros
Re: dZvents broken with 3.9165
Post by devros »
Yes its afaik related to latest RGB bulbs code changes...
dannybloe
Post by dannybloe »
Guess someone changed de devicetypes/hwtypes. Bah!
poudenes
Post by poudenes »
Here all the changes made. i added you so you knew there come some changes ;)
https://github.com/domoticz/domoticz/is ... -375955772
dannybloe
Post by dannybloe »
Yeah.. I'm working on a fix right now.
poudenes
Post by poudenes »
Let me know if i can do something to help and test.
dannybloe
Post by dannybloe »
dzVents 2.4.2 is about to be merged after the checks are OK.
dannybloe
Post by dannybloe »
dannybloe
Post by dannybloe »
Ok, 2.4.2 is merged with development. Check it out.
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
dannybloe wrote: Monday 02 April 2018 15:58 Ok, 2.4.2 is merged with development. Check it out.
Anything new or just fixes?
Is this in an update or do you have to compile domoticz yourself?
Greetings McMelloW
dannybloe
Post by dannybloe »
[2.4.2]
- Fixed RGBW device adapter
- Fixed EvoHome device adapter
- Changed param ordering opentherm gateway command (viewtopic.php?f=59&t=21620&p=170469#p170469)
devros
Post by devros »
hello,
on/off now works ok but setRGB seems broken
domoticz.devices('Xiaomi_RGB').setRGB(118, 118, 118)
and in log...
Error: Error opening url: http://127.0.0.1:8050/json.htm?type=command¶m=setcolbrightnessvalue&idx=385&hue=300&brightness=46.274509803922&iswhite=true
dannybloe
Post by dannybloe »
That looks like an encoding issue. The code creates this url:
/json.htm?type=command&param=setcolbrightnessvalue&idx=...
So as you can see the &param part got wrongly encoded. That looks like a Domoticz/OS/Whatever issue that is not dzVents related. I just checked the code in github and there the encoding is correct.
What OS are you using?
devros
Post by devros »
oh thanks, so its something else wrong :)
im on Ubuntu 16.04.4 LTS
banana pi M2 berry
anything what should i check ?
dannybloe
Post by dannybloe »
I think I have fixed this in the upcoming 2.4.3. Well, not fixed it but worked around it. Looks like on some systems &param in a url is encoded to ¶m. Will be merged later today.
devros
Post by devros »
great it works now :) (on, off commands)
but when tried setNightMode(), decreaseBrightness(), increaseBrightness()
i get
EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-04-04 23:05:32.730 Error: Error opening url: http://127.0.0.1:8050/json.htm?param=nightlight&type=command&idx=514
url link looks ok when i use it manually with changed IP adress it works
in domoticz preferences is set 192.168.3.*,127.0.0.1
any idea whats wrong ?
yfands
Domoticz version: latest B
Post by yfands »
Version: 3.9174 beta
Build Hash: ac7daa5b
Compile Date: 2018-04-03 12:59:46
dzVents Version: 2.4.2
Also my scene's with milights, all my lights turn red and I can't change them back, what's with the colored circles and txtbox ????
See picture. The orange box shows that all my lights are red after the latest update, tried to change them via the colored circles but all I ended
up was a black square and 0% luminosity. How do I reverse this with this o so not-friendly totally not understandable (sorry) circles interface.
It's not responding to my mouse clicks or value that I put in the txtBox, is there a manual how to operate this????
Frank
devros
Post by devros »
yfands wrote: Wednesday 04 April 2018 23:43 Version: 3.9174 beta
Frank
But thats not dZvents problem, i saw some patches on github so maybe fix is allready prepared.. :)
yfands
Post by yfands »
Hai devros,
Yup, you are right no dZvents. I was referring to the RGB issues maybe a common 'module' error.
Thanks, I will give github a try..
devros
Post by devros »
any idea what could be this problem?
i get
its dzVents bug, domoticz problem, or something on my side :D
thanks
