Python Plugin : Broadlink RM2 V4
Lars65
Re: Python Plugin : Broadlink RM2 V4
I have just installed an Broadlink A1, and try to use this plugin.
Everything seems to be fine, except that I get no values for temp and Hum:
2018-03-07 18:40:18.991 (Livingroom Temperature) Updating device from 0:'0.0' to have values 0:'0.0'.
2018-03-07 18:40:18.997 (Broadlink) Update 0:'0.0' (Livingroom Temperature)
Anyone who knows what possibly could be wrong?
zak45
- Domoticz version: V2024.4
do you have selected the right type:Lars65 wrote: Wednesday 07 March 2018 18:42 I have just installed an Broadlink A1, and try to use this plugin.
Lars65
Yes, I have choosen the A1 sensor. It have found all the sensors, temp, hum, air, noice and lux. But it don't update the values.
Lars65
Got it working. It was needed to be set in AP mode.
Alcloud
No, actually, i have the same error..Velly wrote: Tuesday 13 February 2018 14:16 Anybody with MP1 on V4 (Raspberry, Python 3.4):
are your MP1 plugs POWER STATE synced well with Domoticz?
Legster
Hello everyone.
First off I dont know if its allowed to ask question on this topic when its allready open so delete me if I offend.
setup information:
Domoticz: 3.8975
pip --version: pip 9.0.1 from /usr/lib/python2.7/site-packages
Python 2.7 and 3.5.1 installed on NAS aswell as Python module.
manually exectuted (after following wiki it was not working so found missing items and installed):
python3.5 get-pip.py
python -m pip install pyaes
pip install pycryptodomex
python -m Cryptodome.SelfTest
My problem (and I found many with same error but not a solution for me):
I have a Synology Nas and have installed Domoticz there.
I also have a broadlink mini. But since it did not work natively i bought a Xiaomi universal remote controller. total nightmare. so back to Broadlink.
I use it alot on my phone to control led lamps but i want it intergrated so installed your awesome script!
I can add the Broadlink in Domotics now and filled in IP and MAC adres of the device.
folder to store ini /usr/local/domoticz/var/plugins/BroadlinkRM2 (all py files i put there including plugin.py as read on wiki).
so far so good.
but the item wont do anything so I check log file in NAS and see:
2018-03-12 15:40:42.872 Domoticz V3.8975 (c)2012-2018 GizMoCuz
2018-03-12 15:40:42.872 Build Hash: 63d0d07-modified, Date: 2018-02-28 08:26:48
2018-03-12 15:40:42.873 Startup Path: /usr/local/domoticz/
2018-03-12 15:40:42.910 EventSystem: reset all events...
2018-03-12 15:40:43.024 PluginSystem: Started, Python version '3.5.1'.
2018-03-12 15:40:43.034 Active notification Subsystems: pushover (1/14)
2018-03-12 15:40:43.036 WebServer(HTTP) started on address: :: with port 8084
2018-03-12 15:40:43.042 WebServer(SSL) started on address: :: with port 8443
2018-03-12 15:40:43.044 Proxymanager started.
2018-03-12 15:40:43.045 Camera: settings (re)loaded
2018-03-12 15:40:43.046 Starting shared server on: :::6144
2018-03-12 15:40:43.046 TCPServer: shared server started...
2018-03-12 15:40:43.047 RxQueue: queue worker started...
2018-03-12 15:40:45.052 ToonThermostat: Worker started...
2018-03-12 15:40:45.052 XiaomiGateway: will listen on 9898 for hardware id 3
2018-03-12 15:40:45.053 XiaomiGateway: Delaying worker startup...
2018-03-12 15:40:50.054 XiaomiGateway: Worker started...
2018-03-12 15:40:50.054 (Broadlink RM ) Started.
2018-03-12 15:40:50.054 XiaomiGateway: Using 192.168.1.114 for local IP address.
2018-03-12 15:40:50.054 EventSystem: reset all events...
2018-03-12 15:40:50.055 EventSystem: reset all device statuses...
2018-03-12 15:40:50.102 XiaomiGateway: RGB Gateway Detected
2018-03-12 15:40:50.159 Python EventSystem: Initalizing event module.
2018-03-12 15:40:50.159 EventSystem: Started
2018-03-12 15:40:50.160 EventSystem: Queue thread started...
2018-03-12 15:40:50.430 PluginSystem: Entering work loop.
2018-03-12 15:40:50.733 [1;31mError: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Module Import failed, exception: 'ImportError'[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Module Import failed: ' Name: broadlink'[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Error Line details not available.[0;0m
2018-03-12 15:40:51.642 (Thermos Jorn) Thermostat (Toon)
2018-03-12 15:40:51.647 (Thermos Jorn) Temp (Temperatuur)
2018-03-12 15:40:51.648 (Thermos Jorn) P1 Smart Meter (Unknown)
2018-03-12 15:40:51.649 (Thermos Jorn) P1 Smart Meter (Unknown)
2018-03-12 15:41:52.714 Incoming connection from: 192.168.1.100
2018-03-12 15:41:52.715 (Broadlink RM ) Stop directive received.
2018-03-12 15:41:52.716 (Broadlink RM ) Stopping threads.
2018-03-12 15:41:52.716 (Broadlink RM ) Stopped.
2018-03-12 15:41:52.716 (Broadlink RM ) Started.
2018-03-12 15:41:52.937 [1;31mError: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.[0;0m
2018-03-12 15:41:52.937 [1;31mError: (Broadlink RM ) Module Import failed, exception: 'ImportError'[0;0m
2018-03-12 15:41:52.938 [1;31mError: (Broadlink RM ) Module Import failed: ' Name: broadlink'[0;0m
2018-03-12 15:41:52.938 [1;31mError: (Broadlink RM ) Error Line details not available.[0;0m
2018-03-12 15:43:00.462 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:43:30.531 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:44:00.604 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:44:30.665 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:45:00.754 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:45:30.822 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:00.899 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:30.969 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:56.016 [1;31mError: ToonThermostat: retrieveToonState request not successful, restarting..
so the command :
cp -r /usr/local/lib/python3.5/site-packages/broadlink-0.5-py3.5.egg/broadlink/ /usr/local/domoticz/var/plugins/BroadlinkRM2/
cant succeed. However my
has the files i copied as instructed on wiki:
I dont get the broadlink-0.5-py3.egg folder reccon this a gitclone issue but im not sure.
I gitcloned to /volume1/Git/
so the command :
JesusArmy
I am new here, so first a great thanks to zak45 for this nice Broaklink plugin!
Unfortunately I am having some problems running it on my Domoticz setup (under Windows 7).
I had some difficulty to make the plugin work, but after downgrading Python to 3.5.3 I could finally make it run and add my broadlink hardware (with last 3.6.x I could add Broaklink hardware but plugin was crashing and not adding any device as expected).
Now I have two issues:
1/ I can not use the "Learn" feature
As soon as I click the learn button, the system immediatly gave up in the same second:
I will try to see if I can succeed in getting ini files from Android offical app and copy these to the server tonight as a workaround.
2/ Temperature is not working (RM2)
I have seen other posts saying that temp is not reliable. Anyway mine is showing always "0" in Domoticz. I have also many communication errors that might probably be related...
Detection of the device itself is working. I already know IP and mac but just to see I have set discovery mode and it as properly detected everything including type of device. So I guess that communication on network side seems ok... (Windows firewall, but if the rest is going through I guess that this too should isn't it ?)
Official device is also reporting temperature normally.
Thanks for any lead that could help me solve this!
2018-03-22 12:09:44.063 (BroadlinkRM2) All plugin system is on pause for 5s...
2018-03-22 12:09:44.063 (BroadlinkRM2) When Broadlink led is lit press the button on your remote within 5 seconds
2018-03-22 12:09:44.063 Error: (BroadlinkRM2) Not able to learn command2/ Temperature is not working (RM2)
2018-03-22 12:10:11.214 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:12:11.215 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:14:11.217 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:16:11.252 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:18:11.253 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31Official device is also reporting temperature normally.
JesusArmy
Just tried import from apps. Import feature itself is working, but triggering the action does not seem to broadcast proper IR signal...
2018-03-22 23:54:20.148 User: Admin initiated a switch command (17/BroadlinkRM2 - 7-10 Sort in order Light off/On)
2018-03-22 23:54:20.151 (BroadlinkRM2) Calling message handler 'onCommand'.
2018-03-22 23:54:20.151 (BroadlinkRM2) onCommand called for Unit 10: Parameter 'On', Level: 0 , Connected : False
2018-03-22 23:54:20.151 (BroadlinkRM2) Generate on Command for learned code stored on unit/ini :10
2018-03-22 23:54:20.153 (BroadlinkRM2) Code loaded : 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
2018-03-22 23:54:20.156 (BroadlinkRM2) Command line : "C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\plugin_send.py" D:\Scripts\Domoticz\BroadlinkRM2/BroadlinkRM2-7-10.ini
2018-03-22 23:54:20.156 (BroadlinkRM2 - 7-10 Sort in order Light off) Updating device from 1:'On-13' to have values 1:'On-14'.
2018-03-22 23:54:20.423 (BroadlinkRM2) Update 1:'On-14' (BroadlinkRM2 - 7-10 Sort in order Light off)
2018-03-22 23:54:31.651 (BroadlinkRM2) Calling message handler 'onHeartbeat'.-
zak45
JesusArmy wrote: Thursday 22 March 2018 15:56 Just tried import from apps. Import feature itself is working, but triggering the action does not seem to broadcast proper IR signal...![]()
can you give the output of this cmd :
pip show broadlink
JesusArmy
Is it good?
D:\>pip show broadlink
Version: 0.8
Summary: Python API for controlling Broadlink IR controllers
Home-page: http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email: [email protected]
License: UNKNOWN
Location: c:\program files (x86)\python35-32\lib\site-packages
Requires: pycryptodome, PyCRC
You are using pip version 9.0.1, however version 9.0.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' comm
and.-
zak45
Version 0.8 is the problem, this is the last one but not work as expected.JesusArmy wrote: Thursday 22 March 2018 17:43 Is it good?
D:\>pip show broadlink Name: broadlink Version: 0.8 Requires: pycryptodome, PyCRC and.
You need to do that :
pip uninstall pycryptodome
pip uninstall broadlink
download python-broadlink-master-06.zip from dropbox
unzip it somewhere
go to this folder until you find setup.py
open another cmd and go to this folder
type this command
pip install .
--> do not forget the dot '.' at the end
this should install broadlink v0.6
restart Domoticz
EDIT : all of that with admin right .. of course.
JesusArmy
Thanks a lot for the instructions.
Uninstall went both well.
But unfortunately install has ended with an error
Not sure if it could be a path issue or something like this?
Full output here:
I guess problem is in one of these errors/warning?
But should I really need to install VC++ 14.0 ? Broadlink 0.8 did installed properly like this... Or should I upgrade Python version ? I did downgrade from 3.6.4 to 3.5.3 to make the plugin works yesterday...
Full output here:
D:\downloads\temp\python-broadlink-master>pip install .
Processing d:\downloads\temp\python-broadlink-master
Collecting pycrypto==2.6.1 (from broadlink==0.6)
Downloading pycrypto-2.6.1.tar.gz (446kB)
100% |################################| 450kB 419kB/s
Installing collected packages: pycrypto, broadlink
Running setup.py install for pycrypto ... error
Complete output from command "c:\program files (x86)\python35-32\python.exe"
-u -c "import setuptools, tokenize;__file__='C:\\Users\\User\\AppData\\Local\\T
emp\\pip-build-n5nf_jpp\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(_
_file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file
__, 'exec'))" install --record C:\Users\User\AppData\Local\Temp\pip-v83lnfyf-rec
ord\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.5
creating build\lib.win32-3.5\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.5\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.5\Crypto
creating build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.5\Crypto\Hash
creating build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\Cipher
creating build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.5\Crypto\Util
creating build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\
Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.5\Crypto\Random
creating build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.5
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.5\Crypto\R
andom\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\
Random\Fortuna
creating build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.5\Crypto\Random\O
SRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.5\Crypto\Rando
m\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.5\Crypto\SelfT
est
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.5\Crypto\SelfTe
st
creating build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.5\Crypto\S
elfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
creating build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.5\Crypto\Sel
fTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.5\Crypto\
SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
creating build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.5\Cryp
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.5\
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.5\Cryp
creating build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.5\Cry
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.5\Cry
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.5\Cry
creating build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.5\Cry
pto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.5\Crypto
\SelfTest\Random
creating build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> bui
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win3
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.
creating build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win3
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.5\
creating build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.5\Crypto\
SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.5\Cryp
to\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.5\Cr
ypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.5\Crypto\S
elfTest\Util
creating build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.5\Cry
creating build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.5\Crypto\Pr
otocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.5\Crypto\Protoc
ol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\Protoc
ol
creating build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.5\Crypto\Public
Key
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.5\Crypto\PublicK
ey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.5\Crypto\Publ
icKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\Publi
cKey
creating build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.5\Crypto\Sign
ature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Sig
nature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.5\Crypto\Signa
ture
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastm
ath.
building 'Crypto.Random.OSRNG.winrandom' extension
error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual
C++ Build Tools": http://landinghub.visualstudio.com/visual-cpp-build-tools
Command ""c:\program files (x86)\python35-32\python.exe" -u -c "import setuptool
s, tokenize;__file__='C:\\Users\\User\\AppData\\Local\\Temp\\pip-build-n5nf_jpp\
\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().r
eplace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --
record C:\Users\User\AppData\Local\Temp\pip-v83lnfyf-record\install-record.txt -
-single-version-externally-managed --compile" failed with error code 1 in C:\Use
rs\User\AppData\Local\Temp\pip-build-n5nf_jpp\pycrypto\
and.Code: Select all
ath.-
zak45
You do not need VC++ and you need to stay on python 3.5JesusArmy wrote: Thursday 22 March 2018 18:21 Thanks a lot for the instructions.
C++ Build Tools": http://landinghub.visualstudio.com/visu ... uild-tools
ath.[/code]
Just download pycrypto-2.6.1-cp35-none-win32.whl from dropbox and type this command:
pip install pycrypto-2.6.1-cp35-none-win32.whl
after, you need to go to D:\downloads\temp\python-broadlink-master>
and type
pip install .
Hello Everyone !
I am currently trying to install the broadlink plugin with no success ! I always have the same issue
Using the beta version 3.9052
Anyone has manage this problem ? I tried to find something on the forum but the answer is no clear regarding this Wrong Python Path.
Thanks for you help
2018-03-22 23:08:12.573 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-03-22 23:08:12.573 Error: (TV Controller) Module Import failed, exception: 'ImportError'Thanks for you help
JesusArmy
Wonderfull, big big thanks! It went well and I am almost sure that it is working now!zak45 wrote: Thursday 22 March 2018 18:55 You do not need VC++ and you need to stay on python 3.5
and type
pip install .
The day you stop supporting the plugin we are doomed.
Up ! Anyone can help me ?JeremyM wrote: Thursday 22 March 2018 23:27 Hello Everyone !
Anyone has manage this problem ? I tried to find something on the forum but the answer is no clear regarding this Wrong Python Path.Code: Select all
2018-03-22 23:08:12.573 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'. 2018-03-22 23:08:12.573 Error: (TV Controller) Module Import failed, exception: 'ImportError'
Thanks for you help![]()
