Python Plugin: Python Plugin Manager
- remb0
Re: Python Plugin: Python Plugin Manager
some ideas:
add a short info message on https://www.domoticz.com/wiki/Plugins
and maybe a column if plugin is installable from PP-manager?
pp manager default in domoticz? (would help lots of users searching for plugins etc.)
categories for plugins? hardware / web services because the list will grow fast and with categories (maybe an extra metadata of the plugins) the dropdown will be shorter.
maybe a screenshot for the plugins? if the plugin has a folder: screenshots ?
what if a plugin is installed already? can it be updated from the manager?
is there an install log of the prerequisites of a plugin?
one problem:
When I enable pp manager my domoticz goes down. and when restarting I can't disable the plugin: problem adding hardware.
one problem:
- remb0
Can you reply the commands for other users? (like meIDANIT wrote: Wednesday 28 February 2018 15:23 I've change from 3.5.3 to different Python version (3.4.4) and now everything works fine.
- ycahome
- Domoticz version: lat Beta
I would try to contact dnpwwo. A "repository" like approach would be more preferable.
Note that this plugin currently works only on Debian based systems (Linux, raspberry)
Currently, plugin framework does not allow plugin configuration from within the plugin code.
If plugin was installed from GitHub with git command (not just a zip download) can be managed.
this is an information that can be provided from plugin creators just like the installation scripts for those prerequisites.
https://www.youtube.com/siakavelisgr
IDANIT
Well, there are two ways, sophisticated by "update-alternatives" or easy by "remove"
1. first, check what's on Your system
compgen -c python
if dont...
3.
sudo apt-get install python3.4Code: Select all
sudo apt-get remove python3.5
sudo apt-get autoremove
sudo reboot
pvklink
- Domoticz version: latest b
@remb0
I had the same problems that python did not start (sometimes)
I followed your procedure
also did a
apt --fix-broken install
python 3.5 still remains!
i@raspberrypi:~ $ compgen -c python
python3.5
python2
python3.4
python3.4m
python-config
python3
python
python2.7-config
python2.7
python3.5m
python2-config
python3m
pi@raspberrypi:~ $ sudo apt-get remove python3.5
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
Pakket 'python3.5' is niet geïnstalleerd, en wordt dus niet verwijderd
U kunt 'apt --fix-broken install' uitvoeren om dit op te lossen.
De volgende pakketten hebben niet-voldane vereisten:
alacarte : Vereisten: gnome-menus (>= 3.5.3) maar het zal niet geïnstalleerd worden
python-minecraftpi : Vereisten: minecraft-pi maar het zal niet geïnstalleerd worden
E: Er zijn niet-voldane vereisten. U kunt best 'apt --fix-broken install' uitvoeren zonder pakketten op te geven, (of u kunt zelf een oplossing specificeren).
sudo update-alternatives --config python
Keuze Pad Prioriteit Status
0 /usr/bin/python3.5 3 automatische modus
1 /usr/bin/python2.7 2 handmatige modus
* 2 /usr/bin/python3 1 handmatige modus
3 /usr/bin/python3.5 3 handmatige modus
python --version
Python 3.5.3
Jablotron connection, Ikea
pvklink
Solved my problem, i can select 3.4 and python works now
Anyone an idea why
-EnableEventScriptSystem value has become 0 (off). It was 1 (ON) and after playing with weatherunderground and detect hardware devices python stopped and this value became 0
- i cant remove python 3.5 (see previous post)
solution:
Anyone an idea why
solution:
sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.4 4 (4 is variable)
and then
and choose option 4(variable)
Also python is working again after updating EnableEventScriptSystem to 1
rowid Key nValue sValue
139 EnableEventScriptSystem 1
- ycahome
Hello again.
New version is here. You have nothing to do. You will get new version on next domoticz restart or plugin "Update".
v.1.4.10
Added: Xiaomi PM2.5 Sensor
Added: Sony Bravia TV (with Kodi remote)
Changed: Selected (NotifyOnly) is now the default option for auto update
As for making this plugin default on domoticz, am trying first to make it play under Windows or only if Detect Linux .
Thank you for your help
v.1.4.10
@remb0: Adopted your idea. Thanksremb0 wrote: Saturday 03 March 2018 16:31 some ideas:
IDANIT
Great Job! TYVM!ycahome wrote: Sunday 04 March 2018 9:26 Hello again.
v.1.4.10
https://github.com/kofec/domoticz-AirPurifier maybe next?
- DeBaat
- Domoticz version: V3.8153
Wow!
Wonderful idea.
Was looking in how to add Sonos plugin but was holding back because I wasn't that confident accessing the bare system.
I do have some good experience with managing plugins for WordPress. Might find some ideas there?
Keep up the good work!
Wonderful idea.
michellejohnso1
Python Plugin Management, simplified
[spam ? ?
[spam ? ?
- ycahome
What was that?michellejohnso1 wrote: Sunday 04 March 2018 15:32 Python Plugin Management, simplified
.. pluginmanager documentation master file, created by
Your first post to this forum and looks like spam advertising!!
Maybe you should use some code tags in order to make your post readable!!
- ycahome
New version is here. You have nothing to do. You will get new version on next Domoticz restart or plugin "Update".
v.1.4.17
Added: Denon/Marantz Amplifier
Added: Disc usage
Added: Dutch earthquakes
Added: Hive Active Heating
Wiki Plugin catalogue updated. A suffix "$" added to mark the plugins that have some dependencies (from what is mentioned to instructions)
v.1.4.17
Added: Disc usage
deennoo
Thx Ycahome for your works
I try to run your plugin manager on my test domoticz (rpi 3 + stretch) domo beta 3.9014 python 3.5.3
Each time i try to add a plugin (Miflora mate xiaomi robot, pm2.5) this create a segmentation fault, any idea ?
http://domo-attitude.fr
- ycahome
Seems that the are problems with some plugins, raspberry and python 3.5.deennoo wrote: Saturday 10 March 2018 17:12 Thx Ycahome for your works
Two questions:
- you are pressing "Update" after selecting "Miflora mate xiaomi robot or pm2.5", correct?
- can you post me the results of the following commands?
python --version
and
python3 --version
- ycahome
v.1.4.18 is here:
Added: Meteo Alarm EU RSS Reader
Added: Mikrotik RouterOS
Added: Moon Phases
Help me include your plugins (on GitHub) by requesting changes on GitHub.
Regards,
Added: Moon Phases
Regards,
florisi
- Domoticz version: 2020beta
just downloaded pp-manager in the plugins directory.
rebooted my raspberry but nothing appears.
running Domoticz v3.9014 (latest beta) on pi3
- ycahome
make sure that you have python installed
florisi
here is my output about python:
Any hints?
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@domotica:~ $ python --version
Python 2.7.13
- ycahome
are you sure that you don't see "Python plugin manager" on plugin list?
Any log entries?
Any log entries?
florisi
Absolutely sure, no python plugin manager in the list.
Which logfile would u like to see?
