Python Plugin: Python Plugin Manager
remb0
Re: Python Plugin: Python Plugin Manager
Post by remb0 »
some ideas:
add a short info message on https://www.domoticz.com/wiki/Plugins
and maybe a column if plugin is installable from PP-manager?
pp manager default in domoticz? (would help lots of users searching for plugins etc.)
categories for plugins? hardware / web services because the list will grow fast and with categories (maybe an extra metadata of the plugins) the dropdown will be shorter.
maybe a screenshot for the plugins? if the plugin has a folder: screenshots ?
what if a plugin is installed already? can it be updated from the manager?
is there an install log of the prerequisites of a plugin?
one problem:
When I enable pp manager my domoticz goes down. and when restarting I can't disable the plugin: problem adding hardware.
remb0
Post by remb0 »
IDANIT wrote: Wednesday 28 February 2018 15:23 I've change from 3.5.3 to different Python version (3.4.4) and now everything works fine.
Can you reply the commands for other users? (like me :P)
ycahome
Domoticz version: lat Beta
Post by ycahome »
remb0 wrote: Saturday 03 March 2018 16:31
I would try to contact dnpwwo. A "repository" like approach would be more preferable.
Note that this plugin currently works only on Debian based systems (Linux, raspberry)
Currently, plugin framework does not allow plugin configuration from within the plugin code.
If plugin was installed from GitHub with git command (not just a zip download) can be managed.
this is an information that can be provided from plugin creators just like the installation scripts for those prerequisites.
IDANIT
Post by IDANIT »
remb0 wrote: Saturday 03 March 2018 16:39
Well, there are two ways, sophisticated by "update-alternatives" or easy by "remove" :geek:. First one didn't work for me, so I give You second one :lol:.
1. first, check what's on Your system
compgen -c python
2. if You have 3.4 already move to 4.
if dont...
3.
sudo apt-get install python3.4
4.
sudo apt-get remove python3.5
sudo apt-get autoremove
sudo reboot
Thats it
pvklink
Domoticz version: latest b
Post by pvklink »
@remb0
I had the same problems that python did not start (sometimes)
I followed your procedure
i@raspberrypi:~ $ compgen -c python
python3.5
python2
python3.4
python3.4m
python-config
python3
python
python2.7-config
python2.7
python3.5m
python2-config
python3m
pi@raspberrypi:~ $ sudo apt-get remove python3.5
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
Pakket 'python3.5' is niet geïnstalleerd, en wordt dus niet verwijderd
U kunt 'apt --fix-broken install' uitvoeren om dit op te lossen.
De volgende pakketten hebben niet-voldane vereisten:
 alacarte : Vereisten: gnome-menus (>= 3.5.3) maar het zal niet geïnstalleerd worden
 python-minecraftpi : Vereisten: minecraft-pi maar het zal niet geïnstalleerd worden
E: Er zijn niet-voldane vereisten. U kunt best 'apt --fix-broken install' uitvoeren zonder pakketten op te geven, (of u kunt zelf een oplossing specificeren).
also did a
python 3.5 still remains!
sudo update-alternatives --config python
  Keuze        Pad                 Prioriteit Status
  0            /usr/bin/python3.5   3         automatische modus
  1            /usr/bin/python2.7   2         handmatige modus
* 2            /usr/bin/python3     1         handmatige modus
  3            /usr/bin/python3.5   3         handmatige modus
  python --version
  Python 3.5.3
Jablotron connection, Ikea
pvklink
Post by pvklink »
Solved my problem, i can select 3.4 and python works now
Anyone an idea why
-EnableEventScriptSystem value has become 0 (off). It was 1 (ON) and after playing with weatherunderground and detect hardware devices python stopped and this value became 0
- i cant remove python 3.5 (see previous post)
solution:
sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.4 4   (4 is variable)
and then
and choose option 4(variable)
Also python is working again after updating EnableEventScriptSystem to 1
rowid	Key	nValue	sValue
139	EnableEventScriptSystem	1
ycahome
Post by ycahome »
Hello again.
New version is here. You have nothing to do. You will get new version on next domoticz restart or plugin "Update".
v.1.4.10
Added: Xiaomi PM2.5 Sensor
Added: Sony Bravia TV (with Kodi remote)
Changed: Selected (NotifyOnly) is now the default option for auto update
remb0 wrote: Saturday 03 March 2018 16:31 some ideas:
@remb0: Adopted your idea. Thanks ;)
As for making this plugin default on domoticz, am trying first to make it play under Windows or only if Detect Linux .
Thank you for your help
IDANIT
Post by IDANIT »
ycahome wrote: Sunday 04 March 2018 9:26 Hello again.
v.1.4.10
Great Job! TYVM!
https://github.com/kofec/domoticz-AirPurifier maybe next? ;-)
DeBaat
Domoticz version: V3.8153
Post by DeBaat »
Wow!
Wonderful idea.
Was looking in how to add Sonos plugin but was holding back because I wasn't that confident accessing the bare system.
I do have some good experience with managing plugins for WordPress. Might find some ideas there?
Keep up the good work!
michellejohnso1
Post by michellejohnso1 »
Python Plugin Management, simplified
[spam ? ?
ycahome
Post by ycahome »
michellejohnso1 wrote: Sunday 04 March 2018 15:32 Python Plugin Management, simplified
.. pluginmanager documentation master file, created by
What was that? :shock: :shock:
Your first post to this forum and looks like spam advertising!!
Maybe you should use some code tags in order to make your post readable!!
ycahome
Post by ycahome »
New version is here. You have nothing to do. You will get new version on next Domoticz restart or plugin "Update".
v.1.4.17
Added: Denon/Marantz Amplifier
Added: Disc usage
Added: Dutch earthquakes
Added: Hive Active Heating
Wiki Plugin catalogue updated. A suffix "$" added to mark the plugins that have some dependencies (from what is mentioned to instructions)
deennoo
Post by deennoo »
Thx Ycahome for your works
I try to run your plugin manager on my test domoticz (rpi 3 + stretch) domo beta 3.9014 python 3.5.3
Each time i try to add a plugin (Miflora mate xiaomi robot, pm2.5) this create a segmentation fault, any idea ?
http://domo-attitude.fr
ycahome
Post by ycahome »
deennoo wrote: Saturday 10 March 2018 17:12 Thx Ycahome for your works
Seems that the are problems with some plugins, raspberry and python 3.5.
Two questions:
- you are pressing "Update" after selecting "Miflora mate xiaomi robot or pm2.5", correct?
- can you post me the results of the following commands?
python --version
and
python3 --version
ycahome
Post by ycahome »
v.1.4.18 is here:
Added: Meteo Alarm EU RSS Reader
Added: Mikrotik RouterOS
Added: Moon Phases
Help me include your plugins (on GitHub) by requesting changes on GitHub.
Regards,
florisi
Domoticz version: 2020beta
Post by florisi »
just downloaded pp-manager in the plugins directory.
rebooted my raspberry but nothing appears.
running Domoticz v3.9014 (latest beta) on pi3
ycahome
Post by ycahome »
make sure that you have python installed
florisi
Post by florisi »
here is my output about python:
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@domotica:~ $ python --version
Python 2.7.13
Any hints?
ycahome
Post by ycahome »
are you sure that you don't see "Python plugin manager" on plugin list?
Any log entries?
florisi
Post by florisi »
Absolutely sure, no python plugin manager in the list.
Which logfile would u like to see?
