Step by step guide: switch on and off tv via cec
QSKONE
Re: Step by step guide: switch on and off tv via cec
Post by QSKONE »
Can you help me? Need more details to point 7. I don't know how add switch to System Alive Checker without ip address.
Holland
Domoticz version: Beta Ch
Post by Holland »
I do not understand your question. You can't have a System Alive Checker without an IP address. See below
QSKONE
Post by QSKONE »
Sorry,lost in translation .
7. Make the system alive checker sub/slave device (wk.tv.local system alive) of the TV Woonkamer switch.
Holland
Post by Holland »
Regarding stap 7
See attached, add the alive checker device in the properties screen of the main TV switch, created in step 4
QSKONE
Post by QSKONE »
Thanks mate. Works but bad, my Philips 7er is ...
vulbas
Post by vulbas »
thx holland,
that work very well on my tv LG 65SJ850V.
nono212
Domoticz version: 3.6179
Post by nono212 »
Hello
Can we do only on off on cec ... or we can change channel ?
Holland
Post by Holland »
Updated the guide as the cec-client wouldn't compile anymore.
Now based on Stretch and libcec 4.04.
Enjoy
gromar
Post by gromar »
I'm almost there ... I guess :P
I made everything from the tutorial mentioned in first post but I wonder about IP example addresses on the pics:
one is the TV ip adress and what's the second one in the dummy switches?
Thanks in advance for any info! :)
nigels0
Domoticz version: 3.8153
Post by nigels0 »
I do this by using a HDMI CEC injector from Pulese Eight.
https://www.pulse-eight.com/p/104/usb-hdmi-cec-adapter
It is connected via usb, so simplifies the whole issue. You can issue the on/off commands from the raspberry without additional devices.
Holland
Post by Holland »
@gromar
First ip is the ip of the raspberry where the cec deamon is running
Second ip, is for the raspberry which runs the main domoticz installation, so it points to itself.
