Step by step guide: switch on and off tv via cec
Holland
Domoticz version: Beta Ch
Post by Holland »
Updated on April, 2019
If you want to switch off and on a ( in my case Samsung) tv via home automation, chances are that you run into several issues. It's not an straightforward task, also since WOL is not supported by Samsung (2015 tv).
Please find below a step by step guide to, which enables you to switch off and on the tv via a Domoticz virtual switch. In addition, the switch follows closely the state of the tv, so the button is off when the tv is off, even when you have used the rc to switch off the tv.
There are several solution that could or will work;
a. Use a Logitech Harmony Hub. I didn't want to go this way, given that you need to place a infrared sensor somewhere in the neighborhood of the tv. In addition my samsung remote control uses RF, and I read somewhere that the HH can't send and receive RF at the same time. So the HH solution is a no go for me.
b. I use a raspberry 3 with OSMC (based on Kodi) as a mediaplayer. And since the pi supports CEC you could via CEC, by issuing "echo "standby 0" | cec-client -s -d 1 and echo "on 0" | cec-client -s -d 1" switch off and on a tv that also supports CEC. The problem with this solution is that by issuing the before mentioned command the CEC connection between the OSMC and the tv is disconnected, which results that you can no longer use the tv remote control to use the OSMC media player. Therefore using the Pi OSMC CEC solution is a no go.
c. then the logical solution is to connect a separate pi (in my case an old Pi 2) to the tv, just for CEC support. This is the solution that I prefer, and the step by step guide is available below;
# Setup the pi (Based on Strech version April 2019)
1. Update the Pi to the latest and reboot (new firmware and dbus daemon)
sudo apt-get update
sudo apt-get upgrade
sudo reboot
a. Install Domoticz
sudo curl -L install.domoticz.com | bash
Run updatebeta, otherwise the following will pop up;
error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory problem
https://www.domoticz.com/forum/viewtopi ... 2&start=40
b. Install some required components
sudo apt-get install cmake libudev-dev libxrandr-dev python-dev swig
c. Prepare cec-client environment
Following is copied from https://github.com/home-assistant/hassb ... /issues/38 (@john-ruddy)
cd
git clone https://github.com/Pulse-Eight/platform.git
mkdir platform/build
cd platform/build
cmake ..
make
sudo make install
d. Compile cec-client, takes about 3 min on a Pi 2
cd
git clone https://github.com/Pulse-Eight/libcec.git
mkdir libcec/build
cd libcec/build
cmake -DRPI_INCLUDE_DIR=/opt/vc/include -DRPI_LIB_DIR=/opt/vc/lib ..
make -j4
sudo make install
sudo ldconfig
e. Test
cec-client -l
Output, in case it works :)
libCEC version: 4.0.4, git revision: libcec-4.0.4+1-ba9b538, compiled on Thu 11 Apr 22:35:24 UTC 2019 by pi@cec-pi on Linux 4.14.98-v7+ (armv7l), features: P8_USB, DRM, P8_detect, randr, RPi
Found devices: 1
device:              1
com port:            RPI
vendor id:           2708
product id:          1001
firmware version:    1
type:                Raspberry Pi
2. Setup the Domoticz config on the CEC pi
a. Create a dummy switch on the CEC pi.
b. create 2 python scripts and install those in the scripts/python directory. Also make both scripts executable, with sudo chmod +x filename.py
File 1 tv on
#!/usr/bin/python3
import os
os.system("date")
os.system('echo "on 0" | cec-client -s -d 1')
File 2 tv off
#!/usr/bin/python3
import os
os.system("date")
os.system('echo "standby 0" | cec-client -s -d 1')
c. Link the scripts with the switch via:
On action: script:///home/pi/domoticz/scripts/python/tv_woonkamer_on.py
Off action: script:///home/pi/domoticz/scripts/python/tv_woonkamer_off.py
d. the cec pi is now done. Also write down the idx number of the dummy switch, mine is 1.
3. Create a system alive check checker (add via hardware in Domoticz: System Alive Checker) on the main Domoticz installation (production environment in my case)
The ping should be directed to the ip address of the tv, with a timeout of 30 sec. To check if the tv is on or off.
4. Create a dummy switch e.g TV Woonkamer.
5. Create a dummy switch e.g TV Woonkamer.tv.script attached
6. Link the on and off actions ( via JSON), of the TV woonkamer switch to the TV Woonkamer.tv.script attached
switch
http://ip 1:8080/json.htm?type=command&param=switchlight&idx=95&switchcmd=On
http://ip 1:8080/json.htm?type=command&param=switchlight&idx=95&switchcmd=Off
7. Make the system alive checker device slave (wk.tv.local system alive) of the TV Woonkamer switch.
8. Link the on and off actions ( via JSON) of the TV Woonkamer.tv.script attached switch to the switch on the CEC pi
http://ip 2:8080/json.htm?type=command&param=switchlight&idx=1&switchcmd=On
http://ip 2:8080/json.htm?type=command&param=switchlight&idx=1&switchcmd=Off
That's it. I have it working now for a few weeks and it's rock stable.
tv woonkamer scripted attached.JPG (61.23 KiB) Viewed 28455 times
tv woonkamer.JPG (65.1 KiB) Viewed 28455 times
stlaha2007
Re: Step by step guide: switch on and off tv via cec
Post by stlaha2007 »
Nice solution...
However my tv is just a display connected to my av-receiver. How about this config? Both av-receiver and tv are CEC compliant...
On the other hand, when you are using a second pi with Jessie, drop in kodi itself on it with apt-get install kodi...
Have used OSMC and OpenElec, but missing extras to install like ser2net.
Gonna look into your solution for my config, as i want some scenes to handle a WOL-less Sony TV, so this hack can probably do this for me to.
Grtz,
Stephan
Scoobydoo
Post by Scoobydoo »
Thanks for the instructions.
Took a while but finally got it to build.
I found I had to add:-
sudo apt-get install --reinstall libraspberrypi0 libraspberrypi-dev libraspberrypi-doc libraspberrypi-bin
at the beginging
If i didnt do this then the build failed on the make command in the libcec/build folder.
Holland
Post by Holland »
Scoobydoo, Thanks for reporting. Will add it to the guide.
juankar
Domoticz version: 4.
Post by juankar »
Does it work with any Samsung model?
Derik
Post by Derik »
great job...
Holland
Post by Holland »
Post by juankar » Sun Oct 23, 2016 10:23 pm
If your samsung supports Anynet+(HDMI-CEC) then its likely it will work. Make sure that you enable it in the setup menu of your tv.
Anynet+ is Samsung's implementation of CEC
djansen1987
Post by djansen1987 »
Hi The manual is outdated. Install of libCEC didn't work for me anymore.
find the new install:
To compile libCEC on a new Raspbian installation, follow these instructions:
sudo apt-get update
cd
cd platform/build
cmake ..
make
sudo make install
cd
mkdir libcec/build
cd libcec/build
make -j4
sudo make install
sudo ldconfig
ref:
https://github.com/Pulse-Eight/libcec/b ... berrypi.md
djansen1987
capman
Post by capman »
djansen1987 wrote:quick tip for the LG tv users
https://www.domoticz.com/wiki/LG_2012_smart_tv
When a first run this script a get following errors in putty.
A must say that a run domoticz on my synology nas. Python is installed because a can run other python scripts with domoticz.
A have my ip adress from my lg television inserted.
Note: when a searching in the forum with the keywords 'lg' , then there 's no search because of two letters. Also 'tv' ;)
capman
Post by capman »
Probarly it's not working with the webOS 3.
Dutch: https://gathering.tweakers.net/forum/li ... 9#49161059 :(
Someone have it already working ?
squandor
Domoticz version: 3.5837
Post by squandor »
Thats because you are trying to run an python script with shell (sh)
try to run it using the following command:
python lgtv2012.py
toreandre
Post by toreandre »
Holland wrote:If you want to switch off and on a ( in my case Samsung) tv via home automation, chances are that you run into several issues. It's not an straightforward task, also since WOL is not supported by Samsung (2015 tv).
Will this work when connected to AV receiver?
The setup will look like this "Pi Zero -> AV receiver -> TV"
Both the tv and receiver is HDMI CEC devices.
giova
Post by giova »
Thanks to your tutorial, i can now switch TV ON/OFF
i also made a bash script to find tv's ip and test if it is turned on or off.
Now, i didn't understood the last part of your tuto regarding Woonkamer.tv.script device
May you please give us more details regarding this?
can the alive check script be a .sh?
or perhaps it must be a script_timeXXXX file... then why not let it set the parent device (idx 1 for you) ON or OFF depending of ping result?
well i don't see what is the best solution to attach it to the dummy Woonkamer.tv.script device...
Thanks again.
Holland
Post by Holland »
@giova
You don't need a bash script to check if a system is switched on.
Add via hardware in Domoticz: System Alive Checker
Hopefully this helps to take you to the next step
giova
Post by giova »
ok i see now, thanks for the tip !
pvangorp
Domoticz version: Latest B
Post by pvangorp »
Rrrrrr
sincze
Domoticz version: 2024.4
Post by sincze »
Whoehoe Very nice solution. :D
I solved it in a different way using https://github.com/joshjowen/script.json-cec, as an addon for kodi.
In my case... If I switch on the Fan above the stove....
- it switches on my tv (as kodi is always running on my non illegal native mediaplayer (libreelec).
- And it starts playing radio using the radio plugin of kodi.
WAF factor +100 kudos for me now.
As we don't have SONOS money.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
ilpol984
Post by ilpol984 »
I've a big problem. My TV pings even if it is off...
Inviato dal mio ONE A2003 utilizzando Tapatalk
Holland
Post by Holland »
I updated the guide as a power outage killed the SD card. The pi cec has been running for almost 2 years without any issues
Now based on Stretch Nov 17 and libcec 4.02.
Enjoy
