I am reading with you. Today received my GW installed it according to the instruction on the wiki. Everything is working fine. Gw received two firmware updates, know i have version 1.4.1_151.0143. Trough the app everything is working fine.pjsgsy wrote: ↑Monday 05 February 2018 19:41 I just received my gateway and sensors etc today. Install was pretty straightforward. Gateway added to domoticz OK. All sensors paired and showing up in domoticz. Getting live readings from them all. I can press a switch and see the 'Click' event in the log.
So, I tried to setup a simple doorbell. I based it on the example in the wiki. I have tried the exact code and variations. It runs when the door bell button is clicked, but it seems domoticz cannot talk to the gateway, or if it is, the gateway is not doing anything.
From the switches I try to turn on the rgb light or doorbel sound. Nothing. It does work fine from the Mi app though. I have enabled the local network and I have reset and regenerated the password in case I had some typo's (there was a O or 0, but there is not now), but still, I cannot get domoticz to make the gateway play any sounds or light up.
I assume I should be able to play the sounds by simply clicking the gateway doorbell on with the relevant sound? I've tried the blocky script which I used and it does run when the switch is clicked.
I set the volume to level 50
Doorbell to level 40
RG gateway on
But nothing. These 3 don;t seem to work. I DO see them switch on and off in the dashboard, so the domoticz switches seem to be getting set. The gateway however does not seem to carry out the actions. I have the latest firmware on the gateway too.
Version: Latest stable
Platform: Windows 10
Anyone set this up and got any tips? I see nothing in the logs that seems relevant. No errors etc.
Added the GW to domoticz, 5 hardware devices are added. Tried to use them, first i can click but no response.
Know when i use the lightswitch i get
2018-02-07 20:19:22.580 User: Admin initiated a switch command (109/Xiaomi RGB Gateway/On)
2018-02-07 20:19:22.731 Error: XiaomiGateway: unable to write command - Invalid Key
2018-02-07 20:19:22.731 XiaomiGateway: SendMessageToGateway failed on first attempt, will try again
2018-02-07 20:19:22.982 Error: XiaomiGateway: unable to write command - Invalid Key
Anyone an idea, maybe firmware of ghe GW?
Using domoticz
Version: 3.8153
Build Hash: 494fff7-modified
Compile Date: 2017-07-30 12:19:41
