and automation is easier now.
Daikin integration
- remb0
Re: Daikin integration
thanks! this is great news. because internal is always better then plugins or scripts.
- Domoticz version: 3.8834
my modfication is inside beta today 3.8825.
good test
good test
I'm unable to connect to my Daikin airco's with the latest beta.
Not sure since when, but last connect date was: 19-01-2018
There are no errors in the log unfortunately..
strange, can you see starting of hardware controleur in log ? (edit hardware and update) you can see :
2018-01-26 16:30:36.891 Daikin: Worker stopped 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Stopped hardware 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Started hardware 192.168.0.43 ...
Yes, that's working fine I guess:
2018-01-29 10:23:04.212 Domoticz: retrying in 30 seconds...
2018-01-29 10:23:06.190 Daikin: Worker stopped 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Stopped hardware 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Started hardware 192.168.1.149 ...
2018-01-29 10:23:08.568 Daikin: Worker stopped 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Stopped hardware 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Started hardware 192.168.1.23 ...
Ip Adresses check out, they work and are able to connect (port 80 default message).
Ok in this case, can you enable autodiscover of device, then check device list,
perhaps i change internal identifier, this can cause your "no updated value".
Best regards
Best regards
I removed them and added them again, that works.
OK perfect,
if you have idea for update this device, let me know.
Best regards
Best regards
- Target OS: -
Hello all,
I have a Daikin Altherma Hybrid heatpump with a LAN Adapter (BRP069A62). I was under the impression this would also work with the integrated version of the Daikin plugin, but unfortunately this does not seem to work. I can access it via a webrower to view some software infromation, but in the Domoticz log I keep getting Error: Daikin: Error connecting to: 192.168.1.171(the IP is correct of course
Any ideas how I could integrate my heatpump with Domoticz?
Regards,
Marco
Regards,
Marco
Hi Marco,
can you try this http : http://192.168.1.171/common/basic_info and give us return ?
it's the basic call i made before get more information.
regards
SpiderJn
regards
SpiderJn
- Domoticz version: 2022.1
I get:
Page Not Found
/common/basic_info
when I try that command. I cannot connect either.
Page Not Found
/common/basic_info
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | Qlima | Solaredge
TP-Link | Plugwise | Thermosmart | Node-Red | Grafana | Master and 5 remote servers
When I just browse to the IP address, it gives me a text page full of license agreements etc.
Now that the hardware is native, do you still need to create dummy devices and the LUA scripts under "Events" to control the units? That would seem strange to me.
- Domoticz version: 2024.7
The Wiki has been updated, it should not be needed. https://www.domoticz.com/wiki/Daikin_wifi
See also topic viewtopic.php?f=34&t=21126
