Daikin integration
All kinds of 'OS' scripts
remb0
Re: Daikin integration
Post by remb0 »
thanks! this is great news. because internal is always better then plugins or scripts.
and automation is easier now.
spiderjn wrote: Thursday 18 January 2018 14:56 Hi,
my pull request has been approved and commit in developpement branch.
in next beta you can see new device and new command.
Have fun.
spiderjn
Domoticz version: 3.8834
Post by spiderjn »
my modfication is inside beta today 3.8825.
good test
globalassist
Post by globalassist »
I'm unable to connect to my Daikin airco's with the latest beta.
Not sure since when, but last connect date was: 19-01-2018
There are no errors in the log unfortunately..
spiderjn
Post by spiderjn »
strange, can you see starting of hardware controleur in log ? (edit hardware and update) you can see :
2018-01-26 16:30:36.891 Daikin: Worker stopped 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Stopped hardware 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Started hardware 192.168.0.43 ...
globalassist
Yes, that's working fine I guess:
2018-01-29 10:23:04.212 Domoticz: retrying in 30 seconds...
2018-01-29 10:23:06.190 Daikin: Worker stopped 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Stopped hardware 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Started hardware 192.168.1.149 ...
2018-01-29 10:23:08.568 Daikin: Worker stopped 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Stopped hardware 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Started hardware 192.168.1.23 ...
Ip Adresses check out, they work and are able to connect (port 80 default message).
spiderjn
Post by spiderjn »
Ok in this case, can you enable autodiscover of device, then check device list,
perhaps i change internal identifier, this can cause your "no updated value".
Best regards
globalassist
I removed them and added them again, that works.
spiderjn
Post by spiderjn »
OK perfect,
if you have idea for update this device, let me know.
Best regards
marcojpolet
Post by marcojpolet »
Hello all,
I have a Daikin Altherma Hybrid heatpump with a LAN Adapter (BRP069A62). I was under the impression this would also work with the integrated version of the Daikin plugin, but unfortunately this does not seem to work. I can access it via a webrower to view some software infromation, but in the Domoticz log I keep getting Error: Daikin: Error connecting to: 192.168.1.171(the IP is correct of course :-)
Any ideas how I could integrate my heatpump with Domoticz?
Regards,
Marco
spiderjn
Post by spiderjn »
Hi Marco,
can you try this http : http://192.168.1.171/common/basic_info and give us return ?
it's the basic call i made before get more information.
regards
SpiderJn
Alain
Domoticz version: 2022.1
Post by Alain »
I get:
Page Not Found
/common/basic_info
when I try that command. I cannot connect either.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Alain
Post by Alain »
When I just browse to the IP address, it gives me a text page full of license agreements etc.
Now that the hardware is native, do you still need to create dummy devices and the LUA scripts under "Events" to control the units? That would seem strange to me.
Domoticz version: 2025.1
Alain wrote: Saturday 22 May 2021 10:05 When I just browse to the IP address, it gives me a text page full of license agreements etc.
The Wiki has been updated, it should not be needed. https://www.domoticz.com/wiki/Daikin_wifi
See also topic viewtopic.php?f=34&t=21126
