All kinds of 'OS' scripts
remb0
Posts: 499 Joined: Thursday 11 July 2013 22:21
Post
by remb0 » Thursday 18 January 2018 18:40
thanks! this is great news. because internal is always better then plugins or scripts.
and automation is easier now.
spiderjn wrote: Thursday 18 January 2018 14:56
my pull request has been approved and commit in developpement branch.
in next beta you can see new device and new command.
Have fun.
spiderjn
Posts: 22 Joined: Wednesday 27 December 2017 13:37
Domoticz version: 3.8834
Post
by spiderjn » Thursday 18 January 2018 23:34
my modfication is inside beta today 3.8825.
good test
globalassist
Posts: 25 Joined: Monday 09 December 2013 16:51
Post
by globalassist » Friday 26 January 2018 9:55
I'm unable to connect to my Daikin airco's with the latest beta.
Not sure since when, but last connect date was: 19-01-2018
There are no errors in the log unfortunately..
spiderjn
Post
by spiderjn » Friday 26 January 2018 16:31
strange, can you see starting of hardware controleur in log ? (edit hardware and update) you can see :
2018-01-26 16:30:36.891 Daikin: Worker stopped 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Stopped hardware 192.168.0.43 ...
2018-01-26 16:30:36.891 Daikin: Started hardware 192.168.0.43 ...
globalassist
Post
by globalassist » Monday 29 January 2018 10:24
Yes, that's working fine I guess:
2018-01-29 10:23:04.212 Domoticz: retrying in 30 seconds...
2018-01-29 10:23:06.190 Daikin: Worker stopped 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Stopped hardware 192.168.1.149 ...
2018-01-29 10:23:06.190 Daikin: Started hardware 192.168.1.149 ...
2018-01-29 10:23:08.568 Daikin: Worker stopped 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Stopped hardware 192.168.1.23 ...
2018-01-29 10:23:08.568 Daikin: Started hardware 192.168.1.23 ...
Ip Adresses check out, they work and are able to connect (port 80 default message).
spiderjn
Post
by spiderjn » Monday 29 January 2018 17:58
Ok in this case, can you enable autodiscover of device, then check device list,
perhaps i change internal identifier, this can cause your "no updated value".
Best regards
globalassist
Post
by globalassist » Friday 02 February 2018 16:13
I removed them and added them again, that works.
spiderjn
Post
by spiderjn » Saturday 03 February 2018 20:11
OK perfect,
if you have idea for update this device, let me know.
Best regards
marcojpolet
Posts: 63 Joined: Thursday 04 February 2016 20:18
Post
by marcojpolet » Thursday 24 January 2019 17:49
Hello all,
I have a Daikin Altherma Hybrid heatpump with a LAN Adapter (BRP069A62). I was under the impression this would also work with the integrated version of the Daikin plugin, but unfortunately this does not seem to work. I can access it via a webrower to view some software infromation, but in the Domoticz log I keep getting Error: Daikin: Error connecting to: 192.168.1.171(the IP is correct of course
Any ideas how I could integrate my heatpump with Domoticz?
Regards,
Marco
spiderjn
Post
by spiderjn » Monday 04 February 2019 11:51
Hi Marco,
can you try this http :
http://192.168.1.171/common/basic_info and give us return ?
it's the basic call i made before get more information.
regards
SpiderJn
Alain
Posts: 171 Joined: Sunday 26 April 2020 5:27
Domoticz version: 2022.1
Post
by Alain » Saturday 22 May 2021 9:54
I get:
Page Not Found
/common/basic_info
when I try that command. I cannot connect either.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Alain
Post
by Alain » Saturday 22 May 2021 10:05
When I just browse to the IP address, it gives me a text page full of license agreements etc.
Now that the hardware is native, do you still need to create dummy devices and the LUA scripts under "Events" to control the units? That would seem strange to me.
Posts: 6685 Joined: Monday 28 January 2019 18:48
Domoticz version: 2025.1
Post
by waltervl » Monday 31 May 2021 17:23
Alain wrote: Saturday 22 May 2021 10:05
The Wiki has been updated, it should not be needed.
https://www.domoticz.com/wiki/Daikin_wifi
See also topic
viewtopic.php?f=34&t=21126
