Aeotec Wallmote
Re: Aeotec Wallmote
I am finally at a stage that Domoticz detects the Wallmote while inserting but when I go to Scenes and I want to add the buttons (by self learn) it times out. Am I doeing something wrong or does this device require something else to do.
I have Domoticz v.3.8025 and OpenZWave USB Version: 1.4-2642-gc42a15e-dirty installed.
tlpeter
Re: Aeotec Wallmote
I believe (not sure) that it requires options that are not in openzwave yet.
woddanimus
Re: Aeotec Wallmote
Thats odd here: viewtopic.php?f=31&t=12539&p=140674&hil ... te#p140674
I'm now on: 3.8280 and OpenZWave USB Version: 1.4-2701-gec350f12-dirty
I've added successfully the node, but no Devices where being added.
Creating a scene and "add device" just terminates in a timeout.
thx!
it says it works with the current beta and 1.4-2501 ozw.Current BETA domoticz with 1.4-2501-g5af6780-dirty SUPPORTS WallMote:
#1 Upgrade (I'm using a dev platform for that on Orange Pi Zero with stable Armbian (Ubuntu based)
#2 Remove WallMote
#3 Include WallMote again (I'm using secure mode)
#4 Go to scenes add and click the button it will be added as activator.
am I mistaken that it should work?<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="5" innif="true" scenecount="0">
<Instance index="1" />
<Instance index="2" endpoint="1" />
<Instance index="3" endpoint="2" />
<Instance index="4" endpoint="3" />
<Instance index="5" endpoint="4" />
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="2" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="3" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="4" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="system" instance="5" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5" innif="true">
<Associations num_groups="9">
<Group index="1" max_associations="1" label="Lifeline" auto="true" multiInstance="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="On/Off control via Button 1" auto="false" multiInstance="true" />
<Group index="3" max_associations="5" label="Dimmer control via Button 1" auto="false" multiInstance="true" />
<Group index="4" max_associations="5" label="On/Off control via Button 2" auto="false" multiInstance="true" />
<Group index="5" max_associations="5" label="Dimmer control via Button 2" auto="false" multiInstance="true" />
<Group index="6" max_associations="5" label="On/Off control via Button 3" auto="false" multiInstance="true" />
<Group index="7" max_associations="5" label="Dimmer control via Button 3" auto="false" multiInstance="true" />
<Group index="8" max_associations="5" label="On/Off control via Button 4" auto="false" multiInstance="true" />
<Group index="9" max_associations="5" label="Dimmer control via Button 4" auto="false" multiInstance="true" />
</Associations>
</CommandClass>
thx!
Re: Aeotec Wallmote
I finally have one of these, I added it to my ZWave network but it sits in the hardware section under the controller as "unknown" and I can't see any new devices in the devices section for buttons. Also trying to use it to activate scenes does not work, it "times out" when pressing any of the 4 buttons when selecting the scene activator
anyone actually got these working?
sach
Re: Aeotec Wallmote
Anymore progress on the Wallmote?
I am looking to get one but only if it works properly.
Interested in controlling Fibaro dimmers. Could this be done by direct association?
ben53252642
Re: Aeotec Wallmote
I have the AU frequency 4 button Gen 5 version of the Wallmote and it's working perfectly fine for me, very happy with it, particuarly the build quality.
To set it up, just include it in your Z-Wave network, then for each button use the "Learn" function in Domoticz, press a button and set it to be a "On/Off" switch.
Now you have to understand that this switch just sends the "Turn On" command when you press a button, so you need to account for this in your events.
For example I have a button that opens or closes my blinds, if the blinds are already closed and the on button is pressed then open them and vice vesa.
Here is the scripting logic, you will want to have a learned device in Domoticz for each button on the remote
In my above Lua script you can see the Wallmote button "Living Room Blinds Switch" being used in an On / Off scenario using logic based on the blinds state.
If I wanted a button to Boil the Kettle for example, that would look something like this logic wise:
To have the script control a Scene instead of the devices directly you would use:
Basically you just need to understand and plan around the device always sending the On command when you press the button.
if (devicechanged["Living Room Blinds Switch"] == 'On' and otherdevices['Living Room Left Blind'] == 'Open') then
commandArray['Living Room Left Blind'] = 'On'
commandArray['Living Room Right Blind'] = 'On'
if (devicechanged["Living Room Blinds Switch"] == 'On' and otherdevices['Living Room Left Blind'] == 'Closed') then
commandArray['Living Room Left Blind'] = 'Off'
commandArray['Living Room Right Blind'] = 'Off'
if (devicechanged["Boil Kettle Wallmote Switch"] == 'On') then
commandArray["Kettle"] = 'On'
commandArray['Group:Living Room Blinds'] = 'On'
ben53252642
Re: Aeotec Wallmote
This is the exact script I'm using to control my blinds, functionality is:
1) Press the button the blinds open or close depending on state as per the script
2) If the button is pressed again within 30 seconds of blinds moving in the down direction then stop them (so I can easily set where I want them at)
3) If the button is pressed again after they are stopped then raise the blinds
-- Device Last Updates
t1 = os.time()
devices = {
"Living Room Left Blind"
numdevices = 0 -- Count number of devices in the array
for index in pairs(devices) do
numdevices = numdevices + 1
for i = 1, numdevices do
s = otherdevices_lastupdate[devices[i]]
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
str = (devices[i] .. "LastUpdate")
str = str:gsub("%s+", "")
str = string.gsub(str, "%s+", "")
_G[str] = (os.difftime (t1, t2))
-- Wallmote Blind Control -- ORDER IS EXTREMELY IMPORTANT the DIFFEERENCE1 must be the first if
if (devicechanged["Living Room Blinds Wallmote Switch"] == 'On' and otherdevices['Living Room Left Blind'] ~= 'Stopped' and otherdevices['Living Room Left Blind'] ~= 'Open' and LivingRoomLeftBlindLastUpdate < 30 and LivingRoomLeftBlindLastUpdate > 2) then
commandArray['Living Room Left Blind'] = 'Stop'
commandArray['Living Room Right Blind'] = 'Stop'
commandArray['Blinds Cat Mode'] = 'Off'
elseif (devicechanged["Living Room Blinds Wallmote Switch"] == 'On' and otherdevices['Living Room Left Blind'] == 'Open' and LivingRoomLeftBlindLastUpdate > 2) then
elseif (devicechanged["Living Room Blinds Wallmote Switch"] == 'On' and otherdevices['Living Room Left Blind'] == 'Closed' and LivingRoomLeftBlindLastUpdate > 2) then
elseif (devicechanged["Living Room Blinds Wallmote Switch"] == 'On' and otherdevices['Living Room Left Blind'] == 'Stopped' and LivingRoomLeftBlindLastUpdate > 2) then
if (devicechanged['Blinds Cat Mode'] == 'On') then
commandArray['Living Room Left Blind'] = 'On FOR 19 SECONDS'
commandArray['Living Room Right Blind'] = 'On FOR 19 SECONDS'
Last edited by ben53252642 on Saturday 10 February 2018 4:57, edited 1 time in total.
stanv
Re: Aeotec Wallmote
Had many doubts about this piece of hardware, since not everybody is positive on this. Although I didn’t do any complex scripting or usage of the wallmote, it is supported by default in the current version of Domoticz. Works like a charm and setting it up was easy, took me few minutes. Okay, this is just the default ‘button’ function, so still working on how to get the swipe functionality working, but, basic function (and build quality of it) is good!
Thought I should mention this since more people were wondering.
bdormael
Re: Aeotec Wallmote
Can I use the left button for a different action then the right button or are all buttons the same action ?stanv wrote: Tuesday 30 January 2018 11:33 Had many doubts about this piece of hardware, since not everybody is positive on this. Although I didn’t do any complex scripting or usage of the wallmote, it is supported by default in the current version of Domoticz. Works like a charm and setting it up was easy, took me few minutes. Okay, this is just the default ‘button’ function, so still working on how to get the swipe functionality working, but, basic function (and build quality of it) is good!
stanv
Re: Aeotec Wallmote
Yes, I’ve the one with four buttons, all activating a different action/scene.
Guran
- Domoticz version: 3.8364
Re: Aeotec Wallmote
I Cant get the Aeotec wallmote quad to work with my Domoticz ver 3.8364.
It connects, but when I try to configure with the learnswith I just get Time out.
Any trix that I should know of ?
Amsterdam020
- Domoticz version: 3.5629
Re: Aeotec Wallmote
What do you mean with 'it connects'?
So you included it in your zwave network.
Rp3, youlesss, rfxcom, philips hue, dsb1820
ben53252642
Re: Aeotec Wallmote
Did you try testing it with the Domoticz stable release to see if the Beta version is the problem?Guran wrote: Saturday 03 February 2018 18:34 I Cant get the Aeotec wallmote quad to work with my Domoticz ver 3.8364.
I know it works fine with the latest stable release and beta version 3.8809
Guran
Re: Aeotec Wallmote
Nope, I´ve not tested with another release.
Yesterday I got some function in one channel, but that was in the groupe and network in setup.
Today nothing works again
bdormael
Re: Aeotec Wallmote
Bought the wallmote duo this weekend and very happy with it:
- Included it via zwave include in domoticz
- It automatically added two 'Push ON' buttons in the devices section
- I've created dzvents script to act on the 'PUSH ON' events, if pushed left button, I treat it as 'ON', if pushed right button, I treat it as 'OFF'
Very easy, good quality, a happy customer
ben53252642
Re: Aeotec Wallmote
Liking my Quad Wallmote so much that I've just ordered another two.
Battery life is holding up better than expected which was my major concern, I purchased mine on 24/11/17 and its now 25/02/2018 which is about 3 months. I've been using it roughly 15 - 20x a day with the vibration disabled. It still has 67% battery remaining from my original charge which I think is pretty good.
It's looking like I should be able to get somewhere around 7 - 10 months of use per charge.
ben53252642
Re: Aeotec Wallmote
Very exciting! Three Wallmotes serve as the kitchen / living room control center.
In the morning I can do everything from raising the blinds to boiling the kettle and playing a favourite internet radio station.
Re: Aeotec Wallmote
Hi Guys,
Great product and good build quality, have these doing my whole house!
Only issue i have is making domoticz do a simple on/off switch or dimming. The only way i have been able to make this function correctly is through group associations direct with other devices. works great. But, i have some scenes made in domoticz that i want to turn on/off. Problem i find is domoticz only recognizes the ON command and the button will stay ON. press the button again and it still stays ON. I cant find a way to do a simple flip/flop with on/off.
I have tried a Blockly with a When button ON, switch OFF after 5 secs. but this just makes the scene i have attached turn ON then OFF after 5 secs.
Any advice is much appreciated.
ben53252642
Re: Aeotec Wallmote
Here you go, it's a Lua device script (be sure to set it as type "device" in the Domoticz events page).
There are two devices:
Bed Lamp
Bed Lamp Wallmote Switch
It will only control the bed lamp if it hasn't been controlled in the last two seconds (I add this because the Wallmote can send on signals very fast and we don't want to turn it on and off in a two second period of pressing the button).
You should be able to figure it out within about 5 minutes...
Bed Lamp
t1 = os.time()
devices = {
"Bed Lamp"
if (devicechanged["Bed Lamp Wallmote Switch"] == 'On' and otherdevices["Bed Lamp"] == 'Off' and BedLampLastUpdate > 2) then
commandArray['Bed Lamp'] = 'On'
elseif (devicechanged["Bed Lamp Wallmote Switch"] == 'On' and otherdevices["Bed Lamp"] == 'On' and BedLampLastUpdate > 2) then
commandArray['Bed Lamp'] = 'Off'
- sHiKoRa
- Domoticz version: 2.4739
Re: Aeotec Wallmote
I really love the design of the wallmote and have been following this topic for quiet a while. The Aeotec website states that the wallmote can control up to 16 scenes. From what I understand in this topic, this is not possible with Domoticz, is this correct? How many scenes can you guys control with this devices at the moment? I use the Aeotec minimote at the moment and it wouldn't make much sense replacing it when the wallmote can control more scenes.
