not yet, this wallmote makes use of CentralScene functionality which is not implemented in OpenZwave.
They are currently building support for it so I expect it to be released soon. https://github.com/OpenZWave/open-zwave/pull/1125
thanks for the prompt response! Ok no problems I will keep an eye out, probably a month or two before I can afford to lash out on a couple of them anyways. They look super useful a few different scenarios though, looking forward to it!
Interesting, I had held off buying them purely as I was waiting to see them fully supported. Almost pulled the trigger this month as I thought they were all go now
Current BETA domoticz with 1.4-2501-g5af6780-dirty SUPPORTS WallMote:
#1 Upgrade (I'm using a dev platform for that on Orange Pi Zero with stable Armbian (Ubuntu based)
#2 Remove WallMote
#3 Include WallMote again (I'm using secure mode)
#4 Go to scenes add and click the button it will be added as activator.
I managed to get four buttons so far (as ON) - don't know yet how to add them as OFF...
Gentle touch - just like smartphone. I'm setting it up as Toggle switch for various appliances for the first test and try to find out what is the way to get 8 buttons in total...
Sweet! yeh I figured it was only four buttons. Yeh I am look for it for the same toggles and dimmers. Way to switch lights, appliances on etc. Guessing dimmer works by using a "long touch" on one of the quadrants?
Yes, dimmer supposed to be a 'smear' on the button as the manual above states. I haven't got any dimmers, so I've setup four scenes created virtual switches with JSON toggle for the real buttons/devices.
