Z-Wave factfile Eurotronic Spirit Z-Wave+ radiator thermostat controller
Information about specific Z-Wave devices
berkens
Domoticz version: 3.8891
Post by berkens »
Supplier:
Eurotronic GmbH
Website:
https://www.eurotronic.org/produkte/spi ... -plus.html
Function:
HVAC Thermostats
Z-Wave5:
Yes
EAN:
4260012711301
Features:
  • Easy control for water radiators from any Z-Wave Controller
    Fits most European water radiators (wide range of additional adaptors for different manufacturers available)
    FLiRS for quick response time (Frequently Listening Receiver Slave)
    LED Backlit LCD
    Metal nut for reliable connection to the radiator
    2 buttons for easy temperature regulation
    Battery level indicator
    Child Lock
    Over the Air update
    UK-Mode for upside down installation (LCD display upside-down)
    Open Window detection
    Automatic frost protection
Manual:
https://www.eurotronic.org/fileadmin/us ... iew_04.pdf
Datasheet (DE)
https://www.eurotronic.org/fileadmin/us ... 8_2017.pdf
Z-Wavealliance.org
https://products.z-wavealliance.org/products/2543
Product Features: View Features
Z-Wave Plus: Yes
Security S2 Classes: S2 Unauthenticated
Manufacturer Provided Product Manual: Download
Association Capabilities: View Associations
Configuration Capabilities: View Configuration Parameters
Z-Wave hardware platform: ZM5202
Z-Wave version: 6.71.01
Z-Wave library type: Enhanced 232 Slave
Z-Wave Device Type: Thermostat - HVAC
Z-Wave Role Type: Listening Sleeping Slave
Product Type ID: 0x0003
Product ID: 0x0001
Network Management Instructions: View Network Management Info
Command Classes: View Command Classes
Associated Categories: HVAC Thermostats
This Brand: See other products of this brand
Download Product Data in XML Format: Download
Nodes:
Eurotronic Spirit Nodes
Configuration:
Eurotronic Spirit Configuration
Product data XML
ZC10-17095777.XML
Eurotronic Product Data
(18.67 KiB) Downloaded 531 times
openzwave_manufacturer_specific.xml (manufacturer_specific.xml)
<Manufacturer id="0148" name="EUROtronic">
                <Product type="0003" id="0001" name="EUR_SPIRIT Thermostat" config="eurotronic/eur_spirit.xml"/>
        </Manufacturer>
openzwave_deviceconfig.xml (eur_spirit.xml)
<Product sourceFile="eurotronic/eur_spirit.xml">
        <!-- BASIC -->
        <CommandClass id="32" >
                <Value type="list" genre="user"  instance="1" index="0" label="BasicFunction" min="0" max="254" value="0" size="1">
                        <Item label="Off" value="15" />
                        <Item label="Heat" value="254" />
                        <Item label="Heat Econ" value="0" />
                        <Item label="Full Power" value="240" />
                </Value>
        </CommandClass>
        <!-- THERMOSTAT_MODE -->
        <CommandClass id="64" >
                <Value type="byte" genre="config" index="1" label="Mode" units="" min="0" max="15" value="0">
                <Help> 0=Off, 1=Heat, 11=Eco, 15=FullPower </Help>
                </Value>
        </CommandClass>
        <!-- THERMOSTAT_SETPOINT -->
        <CommandClass id="67">
                <Value type="decimal" genre="config" index="1" label="ComfortSetpoint" units="C" value="23"/>
                <Value type="decimal" genre="config" index="11" label="EnergySavingSetpoint" units="C" value="18"/>
        </CommandClass>
        <!-- Configuration Parameter -->
        <CommandClass id="112">
                <Value type="byte" genre="config" index="1" label="LCDInvert" units="" value="0"/>
                <Value type="byte" genre="config" index="2" label="LCDTimeout" units="" value="0"/>
                <Value type="byte" genre="config" index="3" label="Backlight" units="" value="1"/>
                <Value type="byte" genre="config" index="4" label="BatteryReport" units="" value="1"/>
                <Value type="byte" genre="config" index="5" label="MeasuredTempReport" units="" value="5"/>
                <Value type="byte" genre="config" index="6" label="ValveopenReport" units="" value="0"/>
                <Value type="byte" genre="config" index="7" label="WindowOpenDetect" units="" value="2"/>
                <Value type="byte" genre="config" index="8" label="TempOffset" units="" value="0"/>
        </CommandClass>
</Product>
To be continued...
Windows 10 laptop, Synology DS214 + DSM6.1, Zwave.me USB, Neo CoolCam powerplugs & dual wall switches, Heiman gasdetector, Eurotronic Spirit heatvalve, Samsung SmartThings hub v2 UK
berkens
Re: Z-Wave factfile Eurotronic Spirit Z-Wave+ radiator thermostat controller
Post by berkens »
The settings in Domoticz needs more fine tuning.
The HVAC/Thermostat is seen as a light/switch, switch, dimmer.
Eurotronic Spirit valve position
Eurotronic Spirit valve position 86%
I already changed the pictogram, it was shown as a bulb.
The are blinds, dimmer, doorbell, doorlock, doorswitch, sirene, nothing about heating that fits the need.
Different switch types
berkens
Post by berkens »
The display in "up-side-down" mode.
For locations where the valve is mounted in other position.
In this picture the temperature = 22.0 oC.
Compare it to the the picture in the first msg
Eurotronic Spirit display upside-down
ropske
Domoticz version: V3_8394
Post by ropske »
Hi, first of all, thanks mate.
Do we need to copy/install this ZC10-17095777.XML somewhere?
Can you give us an overview of the devices you get in domoticz for 1 valve?
I got 11 devices but i don't know what they all mean/can do
And i think many other here also, thank you!
Wolfgang
Post by Wolfgang »
Thank you for the XML File ,
but there is a problem with the temperature offset setting. If you set the offset to a value below 0 the value is not set.
I bought the valve to use it as an alternative to the danfoss lc-13 , because of the missing offset setting.
If you have a radiator built in a wooden cabinet you get wrong temperature values from the controller because of the hot spot near the sensor.
So the offset value is pretty important to me.
Addtional there is no possibility to set the target temp as a device like the lc-13 , is this a xml setting ?
Wolfgang
Post by Wolfgang »
... found a solution ...
setting the value to 215 ( 255 - 40 = -4.0 degrees Offset ) is corresponding to the negative offset
berkens
Post by berkens »
ropske wrote: Wednesday 21 February 2018 20:17 Hi, first of all, thanks mate.
The file ZC10,,,, is a product data file, explaining several specs of the controller.
You can you the information as a guideline to make the eur_spirit.xml, but I haven't used it in Domoticz.
I don't control the thermostat at this moment.
Can't help you with all the options.
Eurotronic Spirit devices
Devices overview Eurotronic Spirit
Madgeni
Post by Madgeni »
Hi -
Am i missing something - which of the 11 switches allows me to set the temp setpoint?
Thanks for the help!
jeecee
Post by jeecee »
How much sound does this device make, compared to the LC13 (which are basically mute)?
berkens
Post by berkens »
Madgeni wrote: Wednesday 07 March 2018 18:22 Am i missing something - which of the 11 switches allows me to set the temp setpoint?
The Dry Air Temp is de heating setpoint.
berkens
Post by berkens »
jeecee wrote: Wednesday 07 March 2018 19:24 How much sound does this device make, compared to the LC13 (which are basically mute)?
I find it very soft / quiet / silent compared to the Honeywell Rondostat heatvalve I have at other places. I don't hear it at 50 cm distantie.
ropske
Post by ropske »
for me its indeed very soft, i don't hear it.
i have allready a couple in my house
Madgeni
Post by Madgeni »
berkens wrote: Saturday 10 March 2018 19:09
Thanks berkens :)
Do you have any issue with Domoticz not detecting it? The node isn't showing as asleep - but unseen - If i reboot Domoticz, it reconnects once and updates the data.
berkens
Post by berkens »
Madgeni wrote: Saturday 10 March 2018 20:03
Thanks berkens :)
I'm still a beginner. Installed my Zwave.me USB stick and Domoticz on my Synology NAS DS214... Placed under the roof of my 3 story house I have often dead node(s) in the network. Also the Eurotronic Spirit heatvalve in the kitchenette downstairs is sometimes a dead node.
Now I installed the NAS on the ground floor in a cabinet and I loose the node(s) upstairs. Keeps me busy with problem before I go any further with home automation.
As repeaters I use 2x Neocam powerplug and a Heiman gasdetector HS1CG-Z on 220v, on the different stocks, but still dead nodes.
In the settings of Domoticz in the Zwave.me controller is the option
""Enable Nightly Heal Network 04:00u"
Never seen that it repaired (Heal) the network, I have it enabled, but there is no result shown (time when finished or so). That is still a mistery for me.
Grtn Ben
Stephan83
Post by Stephan83 »
Since Yesterday I have a strange issue with a newly added Eurotrocs Spiritz. I added two which are working perfect (added earlier) and the last two I do not get of a Temp LaCrosse TX3 sensor. I added them in the same way. Does somebody does know this problem?
2018-10-08 22_03_10-Domoticz.png (55.31 KiB) Viewed 11307 times
In the picture you see the last line of the first thermostat and all lines of the last thermostat.
HW:Raspberry Pi 3 B, Pi B,Nano w, Aeon Labs Aeotec Gen 5 Z-Wave USB,P1,RFLink,Fibaro dimmers,Fibaro RGBW, Fibaro wallplug,Harmony Companion,GPIO switches, EUROtronic Spirit
SF:Raspbian Stretch,Domoticz 4.97,HaBridge 5.2.1,Dashticz V2.0
Stephan83
Post by Stephan83 »
Stephan83 wrote: Monday 08 October 2018 14:36 Since Yesterday I have a strange issue with a newly added Eurotrocs Spiritz. I added two which are working perfect (added earlier) and the last two I do not get of a Temp LaCrosse TX3 sensor. I added them in the same way. Does somebody does know this problem?
I fixed it!
The only thing I did as far as i can figure out is to use this line in manufacturer_specific.xml:
<Product type="0003" id="0001" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>
Instead of this line:
<Product type="0003" id="0003" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>
But As far as I can remember I tried it before with the same line.
xumpy
Post by xumpy »
I would like to report a problem with your eur_spirit.xml under the thermostat_setpoint
        </CommandClass>
Domoticz can not recognize these devices when the genre paramters is "config". You should make the genre "user".
I've changed my eur_spirit.xml to the following and now I can see the device appearing as ComfortSetpoint and EnergySavingSetpoint.
        <!-- BASIC -->
                </Value>
        </CommandClass>
                </Value>
        </CommandClass>
                <Value type="decimal" genre="user" index="1" label="ComfortSetpoint" units="C" value="23"/>
                <Value type="decimal" genre="user" index="11" label="EnergySavingSetpoint" units="C" value="18"/>
        </CommandClass>
        </CommandClass>
</Product>
Very strange that you guys could make it work with config genre??? Never mind. For those having problems please change the genre under the thermostat_setpoint!
tvurce
Post by tvurce »
My working config:
Added this to existing file /home/pi/domoticz/Config/manufacturer_specific.xml
    </Manufacturer>
And create this new file /home/pi/domoticz/Config/eurotronic/eur_spirit.xml
        <!-- BASIC -->
                </Value>
        </CommandClass>
                </Value>
        </CommandClass>
        </CommandClass>
        </CommandClass>
</Product>
In Devices there is a lot of new stuff from Eurotronic now.
I assume - Temp LaCrosse TX3 - is showing actual ambient temperature measured (but it is not refreshed, so nothing usable). And one of Eurotronics - Thermostat SetPoint is for controling valve temperature for radiator. Probably this one, which synchronize with display on the valve.
There are some other setpoints for different heating modes, but not sure, how to use this. Also I am not able to see where to set Wake Up interval for this valve. Danfoss LC-13 has this settings.
heggink
Domoticz version: 12451
Post by heggink »
Just installed this to replace my Popp thermostat which gave me hassle with zwave.
Using the settings in the previous post, the dry air is not the setpoint I can use + the temp sensor only showed up after a reboot. That said, it works fine for me.
DASHTICZ 🙃
P1 meter & solar panel
wim2008
Post by wim2008 »
I am new in this forum, but I work for several years with z-wave.
I bought this week also a Eurotronic Spirit thermostate. I like to implement the thermostate in another controller.
But I like also to invert the LCD of the thermostate. But I don't understand where do to the inverting.
How can I change the settings? Is there a special program outside Domoticz? Or must I do it first in Domoticz and after the change I can go back with the device in my controller?
Wim
