Thanks for the answer, sorry I was editing my post: Yes of course, I have cleaned it up as I always do, but, no luck...
Aurora theme
jeanclic
Re: Aurora theme
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
MiloshCZ
Re: Aurora theme
Are using linux as server? What about permissions?jeanclic wrote: Friday 05 January 2018 9:23 EDIT2: I tried it on Chrome too: same result. Maybe this is because I completely removed the aurora folder and replaced it with the one just downloaded from this topic ?
bdormael
Re: Aurora theme
I have exactly the same issue on Chrome on my 2 PCs, my iPhone & iPad via Safari. all cleared cache as welljeanclic wrote: Friday 05 January 2018 9:23 Hello,
I have troubles displaying the latest version on Firefox (did not tried on any other browser):
Does anyone encounters the same issue ? (I cleaned cache and deleted datas as always).
EDIT: I tried to go in the parameters and click on "apply parameters" without changing anything:
MiloshCZ
Re: Aurora theme
But I have similar problem at mobile phone. Android 7, Chrome 63.0.3239.111 - appcache cleared
Edit: Red color is OK, I know, that sensors are offline, but....
Edit2: Same problem at Desktop Chrome switched to mobile view
eenernl
Re: Aurora theme
What happens if you open another page and return back to dashboard. It looks like the issue I had before.
* Raspberry Pi B rev2 (with latest Beta of Domoticz)
* 1x RFXtrx433E
* 4x TX320 Temperature/humidity sensors
* 6x KaKu ACD-3500 | Kaku ALED-2709 | KaKu ACM-100 | 2x KaKu AMU-500 | KaKu AWMR-300
* 1x Toon Thermostat (via ToonApiLib)
* 1x RFXtrx433E
MiloshCZ
Re: Aurora theme
No change:eenernl wrote: Friday 05 January 2018 11:59What happens if you open another page and return back to dashboard. It looks like the issue I had before.
dextm80
- Domoticz version: 4.10159
Re: Aurora theme
with new update now it's working all ok!!dextm80 wrote: Thursday 04 January 2018 23:56Exactly, live video feed isn’t working, tomorrow i try to update theme@dextm80 : what do you mean with ‘no screenshot’? Do you mean the live video feed isn’t working? oR that the small webcam-button doesn’t do anything when you click on it? Please elaborate.
Thanks for your support, you have made the best domoticz theme!
thanks!
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
piokuc
Re: Aurora theme
I found some bugs...
1. Name domoticz is on left menu...
2. Good option will be change size width menu to full name position in one line. This is a little pixel more width.
blauwebuis
- Domoticz version: current
Re: Aurora theme
A new version has been uploaded
FIXES
- Weird white colour should be fixed.
- Domoticz logo now has a full grey background
- Small mobile issues with display.
ROBUSTNESS 2.0
- Robust wasn't as robust as I hoped. I took yet another tactic, hopefully more robust. So far so good.
- If there is a javascript failure, domoticz is still useable (items now have a grey background by default, which then becomes visible)
IMPROVEMENTS
- Wider menu, by popular request.
- Mobile view now looks better on the dashboard too.
@jeanclic: does this fix your issue? Thanks for the console output that really helped.
FIXES
ROBUSTNESS 2.0
IMPROVEMENTS
jeanclic
Re: Aurora theme
thanks for the update, unfortunately, I still have the white issue. In fact, I see no change except for the wider menu. You should probably do the same for the parameters menu, I have some words splitted when I am in french.
Question: Would it be possible to have the battery level displayed everywhere, not only on the dashboard ?
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
piokuc
Re: Aurora theme
Problem with logo and Name DOMOTICZ with Version is still. Name DOMOTICz also with version should be move some pixel to right side.jeanclic wrote: Saturday 06 January 2018 11:31 Hello,
Also text wrapping should be better resolved because now one item is wrong. REBOOT- in polish URUCHOM PONOWNIE SYSTEM. No good wrapping.
Icon for notification on devices should be not as "RING" maybe better will be "CLOUD" icon or icon chat cloud.
blauwebuis
Re: Aurora theme
@jeanclic: I'm having trouble finding the issue. Could you tell me a bit more? Things like your device, browser, your theme settings. If there are errors in the console (99% sure there won't be), and most importantly: could you do a right mouse button on the bottom part of the white part -> inspect element. And then tell me (screenshot?) what css classes you see applied.
Nautilus
Re: Aurora theme
Just installed the latest version, looks great! My only issue is that I cannot see any visualizations or web cameras. Cache should be cleared (appcache and empty + hard reload for chrome done a few times), user variables are there with correct numbers (as in theme.json), cameras are attached to switches and I can open the stream as popup. All in all, I cannot think of anything specific that would be missing. Console does not show errors although it is a bit weird that when I enter the developer mode background becomes white and some data is missing form the switched. When I close it and reload it looks normal again.
In any case, I'm sure it is something simple that I can get fixed with a good hint...
And thanks again for the great theme!
edit: A couple of things came to my mind that have not been solved in any of the standard themes:
1. Camera popup is stretched if it does not match the fixed aspect ration, it would be great if the popup would open in the same aspect ratio as the images coming from the camera.
2. If I add a custom page with camera streams (which are based on loading jpeg stream), when I return to "normal" Domoticz page I can still see in the network tab of the console that camera images are loaded. This creates an unnecessary strain on the cameras as no one is watching the camera the feed anymore via the custom page, but there in the background images are still being loaded. Is there perhaps something that could be done for this on a theme level?
jeanclic
Re: Aurora theme
Hello there,
I searched for corrected the "white issue", and I think the problem is located in "theme.css" at line 225: I propose the following:
This removes the white.
There is also couple of issues regarding french length of texts in column mode on dashboard: Issue with parameters menu: Also, Barometer is not working anymore.
Thanks in advance.
.item tr{
/*background-color:#D4E1EE;*/
/* background: -moz-linear-gradient(to bottom, rgba(241,245,250,0.9) 0%, rgba(241,245,250,1) 100%); */
/* background: -webkit-linear-gradient(to bottom, rgba(241,245,250,1) 0% ,rgba(241,245,250,1) 55px, rgba(241,245,250,0.05) 55px, rgba(241,245,250,0.1) 60px,rgba(241,245,250,0.1) 100%); */
/* background: linear-gradient(to bottom, rgba(241,245,250,1) 0% ,rgba(241,245,250,1) 55px, rgba(241,245,250,0.05) 55px,rgba(241,245,250,0.1) 60px, rgba(241,245,250,0.1) 100%); */
box-shadow: 2px 2px 18px 0px rgba(50, 50, 50, 0.2);
}There is also couple of issues regarding french length of texts in column mode on dashboard: Issue with parameters menu: Also, Barometer is not working anymore.
Thanks in advance.
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
bdormael
Re: Aurora theme
What I noticed is when you select iOS look, then afterwards unselect this again, you are stuck with the “white” issue everyone is talking about and it never disappears anymore
Verzonden vanaf mijn iPad met Tapatalk
Aadr
Re: Aurora theme
I am having the same problem (white blocks), but when I switch the option "Toestaan om de Widgets te verschuiven" to off, the white issue is gone. Then the theme is really good. I hope this helps with solving the problem
Aadr
Re: Aurora theme
Hello again,
sorry, I made a mistake. The option "Toestaan om de Widgets te verschuiven" should be in the on position to have a good theme. Sorry about this.
blauwebuis
Re: Aurora theme
New version uploaded
FIXES
- the white issue (hopefully).
- jitter/jumping about of some outputs when updated.
- small mobile display tweaks.
- tweaking stability.
IMPROVEMENTS
- wider settings sidemenu
NEW FEATURE
- inline setpoint: quickly change the thermostat setpoint without needing to open the popup.
FIXES
IMPROVEMENTS
NEW FEATURE
jeanclic
Re: Aurora theme
Hello blauwebuis,
very nice work, I think I am about to use the Aurora Theme in production today !
there is still a minor issue with parameters menu: The Thermostat new feature is very good, even if it is not working very fast.
- Is it possible to have the Up and Down buttons bigger ? (wall tablett).
- Is it possible to have those buttons on the measure page where are all the thermostats ? (I don't put them on the dashboard).
- Is it possible to have the buttons on the floorplan somehow ?
thanks again for all the huge work you have made !
Edit: Another request: I wonder if it is possible to maximize the size of a plan in the floorplan display: see screenshot:
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
jeanclic
Re: Aurora theme
After putting theme on my wall tablett, I have 2 issues:
1 - see screenshot : tiles are not good for highlighted items: 2 - On my wall tablett I have a user beeing only "user". and I have to set the theme as I want (no Iphone styling) with primary user before beeing able to use it with my second user. (so I deduce that the settings I have put on my computer are not taken into account on an other one. I find this not good for me... sorry if I am not very clear.
PS : barometer is working, but it takes a few minutes to show.
PS2 : I assume you are aware that on firefox or chrome, there is a mode to test different tabletts/phones resolutions ? (CTRL+SHIFT+M) on firefox dev tool.
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
Users browsing this forum: floris74 and 1 guest
