There is Somfy in the air!!
- remb0
Great news about controlling Somfy motors,
We got lots of qeustions for supporting somfy, and now we got an great answer!
The RFXtrx433E become available from June 2 2014.
RFXtrx433E is A succesor of the great RFXtrx433 with the possibility to control Somfy motors.
We already got an prototype from rfxcom.com to implement and test.
And the Domoticz team has build in support (from beta 1772)
I have tested it and it works great!!
You are able to add a manual switch,
Give it a name, Choose type RFY (the name of Somfy in Domoticz)
Set a random unique Id and Unit,
Click test to pair and Add device.
The RFXtrx433E is available: http://www.rfxcom.com/Downloads
and Hardware: http://www.rfxcom.com/store/Sender%20un ... nger/14103
- Somfy Magic
- Somfy.png (49.81 KiB) Viewed 40199 times
darrepac
Re: There is Somfy in the air!!
Argh!! I bought my RFXTRX some weeks ago without being aware of this upcoming RFXTRX "E" version with RFY support!
Would be interesting to know if the added HW can be added to previous model...
drogert
I also bought the RFXTRX433. Can you explain the difference between the normal and the "E" other then support for RFY? Can it recieve multiple protocols like lighting4 and ARC at the same time for instance? Or is this not possible in any way?
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
darrepac
I have external venetian blinds controlled with Telis var/mod remote (this the one with a rolling button in the middle to choose the angle of the vrnetian). Is Domoticz capable to change venitian angle or just "up" , "down" and "my"?
b_weijenberg
- Target OS: -
@drogert: The RFXtrx433E can use Type1, Type2 and Ext firmware. The RFxtrx433 can use Type1 or Type2. See the RFXtrx433 User Guide chapter 2
@darrepac: the RFXtrx433E supports "up" , "down" and "my".
RFX-433, RFX-433EMC, RFX-868
Omehenne
Is there more news on the 868mhz version?
TANE
Somfy control works great.
Also controlling from the HC2.
http://forum.fibaro.com/viewtopic.php?t=4390
no way to pimp my RFXtrx433 to an RFXtrx433E ??
b_weijenberg
- Target OS: -
There is no upgrade kit for the RFXtrx433.
xKingx
- Domoticz version: 2022.1
Managed to get my Somfy sunscreen working using an RFXtrx433E. Good stuff!
Raspberry Pi running Domoticz image
darrepac
How to make the choice between blinds, blinds inverted, blinds percentage?
thanks
thanks
Steven84
Can't get it working.... chose random ID & Unit but nothing?
b_weijenberg
- Target OS: -
Did you follow the procedure described in the RFXtrx User Guide?
Steven84
First i didn't then in followed it and succes!b_weijenberg wrote:Did you follow the procedure described in the RFXtrx User Guide?
Thanx Weijenberg!
triathlete78130
Hi Team,
I have installed the RFXTrx433E and can perfectly control my 13 Blinds.
The Up, Down, and Stop button works exactly like the remote control. (the Stop button beeing the My button)
Nevertheless, when I do scenario, I can only do On/Off and not use the Stop Button... and it works as designed.
How can I do to add the functionality Stop and not only on/off in the scenario definition?
Domocticz latest Beta
Raspberry Pi (B)
RFXtrx433E USB
Access via OpenVPN & dnsdynamic.org
13 Somfy RTS Blinds
To Come (Looking and searching what to take all wireless)
**Plug for Light Presence
**Alarm
Raspberry Pi (B)
RFXtrx433E USB
13 Somfy RTS Blinds
**Alarm
b_weijenberg
- Target OS: -
A new firmware version 227 for the RFXtrx433E is available on the RFXCOM download page.
Changes:
Some Somfy RTS motors did not respond correctly on up/down commands.
The maximum number of simulated RTS remotes is increased from 16 to 30.
Somfy RTS venetian blinds device added. (not yet available in Domoticz)
Other changes:
Viking checksum added
Conrad RSL improved
BTHR968 forecast corrected
RTHN318 corrected
DM10 corrected
LightwaveRF Off corrected
Prego P-8426 sensor added
Kambrook, Rubicson and Viking supported in EXT firmware.
Changes:
Other changes:
Conrad RSL improved
RTHN318 corrected
DM10 corrected
laurent207
I have domoticz v1.1812 on my rasberry with a RFXtrx433E but I don't have RFY type. Under windows it works great. Do you have a tips to have RFY type on domotics on a respberry pi ?
b_weijenberg
- Target OS: -
laurent207
how ? I install domoticz on my raspbian thanks to the domoticz's wiki.
triathlete78130
How can we do add the My/Stop button working fine in the light pannel in the script and planning possibility (On/Off)?b_weijenberg wrote:A new firmware version 227 for the RFXtrx433E is available on the RFXCOM download page.
Changes:
Raspberry Pi (B)
RFXtrx433E USB
13 Somfy RTS Blinds
**Alarm
Raspberry Pi (B)
RFXtrx433E USB
13 Somfy RTS Blinds
**Alarm
