I've a OTGW connected through USB at my Domoticz environment (RPI)
When I control the setpoint, most of the times the setpoint isn't going trough. Sometimes it works perfectly
Remeha iSense thermostat (RF version)
OTGW through Nodo Shop
Could someone help me out?
Problems with controlling the setpoint
pfwolbers
Re: Problems with controlling the setpoint
Check your LOG to see or the gateway gives any errors.
Ron
- Domoticz version: 2.2284
I found out that only 1 degree settings works, not 0,5 degree.
So if the roomtemperature setting is 20 degree i can not change it to 20,5 (I can but it doesn't work) but changing it to 21 works fine.
Also you have to be patiënt, of takes some time untill the thermostat shows the changed temperature.
In the log you can see the change imediatly.
