Problems with controlling the setpoint
For OpenTherm-gateway related questions in Domoticz
remco770
Post by remco770 »
I've a OTGW connected through USB at my Domoticz environment (RPI)
When I control the setpoint, most of the times the setpoint isn't going trough. Sometimes it works perfectly
Remeha iSense thermostat (RF version)
OTGW through Nodo Shop
Could someone help me out?
pfwolbers
Re: Problems with controlling the setpoint
Post by pfwolbers »
Check your LOG to see or the gateway gives any errors.
Ron
Domoticz version: 2.2284
Post by Ron »
I found out that only 1 degree settings works, not 0,5 degree.
So if the roomtemperature setting is 20 degree i can not change it to 20,5 (I can but it doesn't work) but changing it to 21 works fine.
Also you have to be patiënt, of takes some time untill the thermostat shows the changed temperature.
In the log you can see the change imediatly.
