Geofence for Domoticz
jannl
- Domoticz version: 2026.1.x
Re: Geofence for Domoticz
I am not sure what turning wifi on and off adds to presence detection, except for the privacy, which has nothing to do with presence detection.
Sandberg89a
Hallo Appestijn,
Ik weet niet hoe ik je anders kan bereiken. Ik zie nergens een e-mailadres van jou. Ik heb jouw naam van iemand gekregen, welke aangaf dat jij veel verstand hebt van iets kunnen schakelen via software op een tablet. Mag ik aan jou mijn vraag voorleggen. Het liefst via de e-mail.
m.vr.gr.
Kasper de Beer
m.vr.gr.
Kasper de Beer
Appesteijn
Check your PMs!Sandberg89a wrote: Monday 18 December 2017 23:53 Hallo Appestijn,
m.vr.gr.
Kasper de Beer
gimlichael
- Domoticz version: 3.8153
I cannot get this app to work.
I am using Android 8 (Oreo), and the app does not register when I leave or enter the fence.
It only works when testing the connection .. outside the fence and testing, the virtual switch always remain on.
Appesteijn
Hmm, do you have the Google Play apps installed and is DomoFence authorized to access your location?gimlichael wrote: Thursday 21 December 2017 9:22 I cannot get this app to work.
jannl
I also see some issues. The app was not working for some days and today I manually started the app. Looks like something stops the app....
Btw, I do not use any battery apps (besides Android's own)
Appesteijn
It looks like in Android 8.0 they changed the Geofencing API. I will have a look in the Christmas holidays.jannl wrote: Thursday 21 December 2017 14:48 I also see some issues. The app was not working for some days and today I manually started the app. Looks like something stops the app....
jannl
Nope, still 7.x
gimlichael
Yes, the app have the required permissions .. but like you wrote later, maybe a new API needs support?Appesteijn wrote: Thursday 21 December 2017 13:59Hmm, do you have the Google Play apps installed and is DomoFence authorized to access your location?gimlichael wrote: Thursday 21 December 2017 9:22 I cannot get this app to work.
Looking forward to be using your app.
Huubke80
- Domoticz version: 3.6722
I have installed the app domofence, now I have the problem that it is only working when I connected to my Wifi. But when I connected to the mobile network I'm getting an error message http://IP:8080/json.htm?...... While I have acces to the webinterface from outside my LAN, someone any idea?
DutchHans
Is Domoticz accessable from the outside?..you should have access, otherwise you can't change a switch...
Regards, Hans
Regards, Hans
Huubke80
Yipzz, that is the strange thing. I think it has to do something with authentication?!DutchHans wrote: Saturday 13 January 2018 10:16 Is Domoticz accessable from the outside?..you should have access, otherwise you can't change a switch...
Regards, Hans
DutchHans
If thats the case its simple
http://username:password@yourIP:portnumber/etc
Hope this helps.
Hans
Hope this helps.
Hans
Huubke80
Solved, the " basic authentication" instead of "login page" under settings in Domoticz did the trick.Huubke80 wrote: Saturday 13 January 2018 13:14Yipzz, that is the strange thing. I think it has to do something with authentication?!DutchHans wrote: Saturday 13 January 2018 10:16 Is Domoticz accessable from the outside?..you should have access, otherwise you can't change a switch...
Regards, Hans
- gjaa
I'm new to Domofence but is doesn't work, I've got an error
I use the same settings as Domoticz Lite
user and password are the same
Basic Auth is set
But when I use my home wifi and change the IP to the local IP-Address and port, then it's working
I'm using the app on Android 8.1 (Nexus 5x)
What's going wrong????
Gerard
Basic Auth is set
Gerard
- gjaa
gjaa wrote: Monday 15 January 2018 14:22 I'm new to Domofence but is doesn't work, I've got an error
Basic Auth is set
Gerard
I started a browser on my phone and tried https://123.123.123.123:port/json.htm?type=command¶m=switchlight&idx=1234&switchcmd=On
I've got the message
"status" : "On" ,
"title" : "SwitchLight"
So that's working. But in the app, when I try "Test connection (ON)", I've got the message Error:https://123.123.123.123:port/json.htm?type=command¶m=switchlight&idx=1234&switchcmd=On
So what's the solution???
Gerard
- gjaa
gjaa wrote: Wednesday 17 January 2018 16:33gjaa wrote: Monday 15 January 2018 14:22 I'm new to Domofence but is doesn't work, I've got an error
Basic Auth is set
Gerard
"status" : "On" ,
Gerard
Tested with the phone of my son (Android 6.0)
And it's working so it's a android 8 problem
Gerard
- gjaa
I stopped with Domofence
I use now https://www.domoticz.com/wiki/Presence_detection
This script checks the presence off the ip-addresses of the phones in the home network
Gerard
Gerard
Appesteijn
I currently don't have much spare time to work on this. I'll post here when I have an update.
billouetaudrey
- Target OS: -
I try Miui 9.1 android 7.1 work finegjaa wrote:gjaa wrote: Wednesday 17 January 2018 16:33gjaa wrote: Monday 15 January 2018 14:22 I'm new to Domofence but is doesn't work, I've got an error
Basic Auth is set
Gerard
"status" : "On" ,
Gerard
Gerard
I try custom rom 8.x, work fine...
Strange
Envoyé de mon Redmi Note 4 en utilisant Tapatalk
