Geofence for Domoticz
jannl
Domoticz version: 2025.5.x
Re: Geofence for Domoticz
Post by jannl »
I am not sure what turning wifi on and off adds to presence detection, except for the privacy, which has nothing to do with presence detection.
Sandberg89a
Post by Sandberg89a »
Hallo Appestijn,
Ik weet niet hoe ik je anders kan bereiken. Ik zie nergens een e-mailadres van jou. Ik heb jouw naam van iemand gekregen, welke aangaf dat jij veel verstand hebt van iets kunnen schakelen via software op een tablet. Mag ik aan jou mijn vraag voorleggen. Het liefst via de e-mail.
m.vr.gr.
Kasper de Beer
Appesteijn
Post by Appesteijn »
Sandberg89a wrote: Monday 18 December 2017 23:53 Hallo Appestijn,
m.vr.gr.
Kasper de Beer
Check your PMs! :)
gimlichael
Domoticz version: 3.8153
Post by gimlichael »
I cannot get this app to work.
I am using Android 8 (Oreo), and the app does not register when I leave or enter the fence.
It only works when testing the connection .. outside the fence and testing, the virtual switch always remain on.
Appesteijn
gimlichael wrote: Thursday 21 December 2017 9:22 I cannot get this app to work.
Hmm, do you have the Google Play apps installed and is DomoFence authorized to access your location?
jannl
Post by jannl »
I also see some issues. The app was not working for some days and today I manually started the app. Looks like something stops the app....
Btw, I do not use any battery apps (besides Android's own)
Appesteijn
jannl wrote: Thursday 21 December 2017 14:48 I also see some issues. The app was not working for some days and today I manually started the app. Looks like something stops the app....
It looks like in Android 8.0 they changed the Geofencing API. I will have a look in the Christmas holidays.
jannl
Post by jannl »
Nope, still 7.x
gimlichael
Appesteijn wrote: Thursday 21 December 2017 13:59
Yes, the app have the required permissions .. but like you wrote later, maybe a new API needs support?
Looking forward to be using your app.
Huubke80
Domoticz version: 3.6722
Post by Huubke80 »
I have installed the app domofence, now I have the problem that it is only working when I connected to my Wifi. But when I connected to the mobile network I'm getting an error message http://IP:8080/json.htm?...... While I have acces to the webinterface from outside my LAN, someone any idea?
DutchHans
Post by DutchHans »
Is Domoticz accessable from the outside?..you should have access, otherwise you can't change a switch...
Regards, Hans
Huubke80
Post by Huubke80 »
DutchHans wrote: Saturday 13 January 2018 10:16 Is Domoticz accessable from the outside?..you should have access, otherwise you can't change a switch...
Regards, Hans
Yipzz, that is the strange thing. I think it has to do something with authentication?!
DutchHans
Post by DutchHans »
If thats the case its simple
http://username:password@yourIP:portnumber/etc
Hope this helps.
Hans
Huubke80
Post by Huubke80 »
Huubke80 wrote: Saturday 13 January 2018 13:14
Regards, Hans
Solved, the " basic authentication" instead of "login page" under settings in Domoticz did the trick. :) .
gjaa
Post by gjaa »
I'm new to Domofence but is doesn't work, I've got an error
I use the same settings as Domoticz Lite
user and password are the same
Basic Auth is set
But when I use my home wifi and change the IP to the local IP-Address and port, then it's working
I'm using the app on Android 8.1 (Nexus 5x)
What's going wrong???? :?:
Gerard
gjaa
Post by gjaa »
gjaa wrote: Monday 15 January 2018 14:22 I'm new to Domofence but is doesn't work, I've got an error
Basic Auth is set
Gerard
I started a browser on my phone and tried https://123.123.123.123:port/json.htm?type=command&param=switchlight&idx=1234&switchcmd=On
I've got the message
"status" : "On" ,
"title" : "SwitchLight"
So that's working. But in the app, when I try "Test connection (ON)", I've got the message Error:https://123.123.123.123:port/json.htm?type=command&param=switchlight&idx=1234&switchcmd=On
So what's the solution???
Gerard
gjaa
Post by gjaa »
gjaa wrote: Wednesday 17 January 2018 16:33
Basic Auth is set
Gerard
"status" : "On" ,
Gerard
Tested with the phone of my son (Android 6.0)
And it's working so it's a android 8 problem
Gerard
gjaa
Post by gjaa »
I stopped with Domofence
I use now https://www.domoticz.com/wiki/Presence_detection
This script checks the presence off the ip-addresses of the phones in the home network
Gerard
Appesteijn
I currently don't have much spare time to work on this. I'll post here when I have an update.
billouetaudrey
Post by billouetaudrey »
Basic Auth is set
Gerard
"status" : "On" ,
Gerard
Gerard
I try Miui 9.1 android 7.1 work fine
I try custom rom 8.x, work fine...
Strange
Envoyé de mon Redmi Note 4 en utilisant Tapatalk
