Adding Nest Thermostat
robpijpers
Post by robpijpers »
I'm new to Domoticz and are playing around to get some knowledge how Domoticz is working, So far I am very impressed.
I'm reading on various sites that is possible to add a Nest thermostat but I can't find a way to properly do this step by step.
Can anyone help me?
Thanks, Rob
bobdvb
Re: Adding Nest Thermostat
Post by bobdvb »
Go to the Hardware section and select "Nest Thermostat/Protect" from the "type" field. Give it a name and put in your Nest username/password. The Nest then appears in the devices section to be added.
corederoma82
Post by corederoma82 »
But is it fully compatible or it need some scripts?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
krizzz
Post by krizzz »
corederoma82 wrote:But is it fully compatible or it need some scripts?
After adding the Nest as new hardware you can do a lot of things without any scripting. So to answer your question, yes it is fully compatible.
corederoma82
krizzz wrote: Tuesday 12 December 2017 23:28
Thanks for you answer
corederoma82
Another question please,
also Nest Protect is fully compatible?
