I'm new to Domoticz and are playing around to get some knowledge how Domoticz is working, So far I am very impressed.
I'm reading on various sites that is possible to add a Nest thermostat but I can't find a way to properly do this step by step.
Can anyone help me?
Thanks, Rob
Adding Nest Thermostat
robpijpers
bobdvb
Re: Adding Nest Thermostat
Go to the Hardware section and select "Nest Thermostat/Protect" from the "type" field. Give it a name and put in your Nest username/password. The Nest then appears in the devices section to be added.
corederoma82
But is it fully compatible or it need some scripts?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
krizzz
After adding the Nest as new hardware you can do a lot of things without any scripting. So to answer your question, yes it is fully compatible.corederoma82 wrote:But is it fully compatible or it need some scripts?
corederoma82
Thanks for you answerkrizzz wrote: Tuesday 12 December 2017 23:28After adding the Nest as new hardware you can do a lot of things without any scripting. So to answer your question, yes it is fully compatible.corederoma82 wrote:But is it fully compatible or it need some scripts?
corederoma82
Another question please,
also Nest Protect is fully compatible?
