Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Dear Madgeni,
I face a challenge adding test Home Controlicz in GH...I allow the full-access but then Google says, after trying to link, it couldn't update the service and I need to check my connection. Any ideas?
sure - you just need to use https - i think the port you've given Controlicz is your http portstefanjongerius wrote: ↑Tuesday 12 December 2017 22:29 Dear Madgeni,
Hello Madgeni, i will be happy to test and use controlicz, [email protected]
- Target OS: -
Hey Madgeni I cant find the controlicz app in google home/smarthome, is there anything else i have to do to make it show up.
acole****[email protected]
if you've enabled it in the simulator, then it should show up?
Hi Madgeni,
I now have changed the port in controlicz, this is the https port for Synology (https://MYID.synology.me and then credentials then you reach DSM), I have been able to install Let's Encrypt certificate. However I do not know how to reach domoticz in https, which is still available in http. Is there any way to fwd in DSM to Domoticz? E.g. the tutorials available did not solved the issue yet.
It might be out of your ballpark but who knows...
- Target OS: -
Hey Madgeni can you ad king**[email protected] to the beta please.
Hi, I registered controlicz as gaec****@gmail.com could you add me. Thanks.
First a big thanks for your work Madgeni !
I subscribe to Controlicz and I work "hard" for make it work but nothing appear on my home app.
Do you have maybe just a simple tutorial how to make it work?
Thanks in advance for your work
- Domoticz version: Stable
Hi Madgeni,
I am running into some funky stuff here.
Initially I had problems getting connected to the service in GH. Finally, after adding a fresh new user in Domoticz, I had it up and running.
I used it for several days and I must say, it worked like a charm. Kudos for that! I noticed however that some of the names of my devices were not so practical (dutch names in an English Google Home) so I added some names in description fields.
Queriïng devices did not trigger the names to be added to my Google Home, so I went into the GH app and unlinked the Controlicz service. I then tried to link it agein, with the same credentials, and I got an error saying that my settings cannot be updated, please check your connection.
So, learning from my first experience, I added a new, fresh user and changed the settings on the Controlicz webpage. Same result!
Now, no matter what I do, I always get the same errormessage, using the newest credentials or the credentials that worked before!
Any suggestions?
Unm is blde.....com
Any suggestions?
Unm is blde.....com
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
I also have problems with Controlicz settings and my Domoticz setup, so it would be nice to have a button on the Controlicz profile page to test and check connection between Controlicz and Domoticz
urgh - I can look to add it, but honestly, this isn't the issue with bldewit - i can see the sync requests being made, and the responses back are fine. The Google apps are just, well, shit. They really don't respond well to change. When I first wrote this integration, it NEVER came back with a success at account linking, it just told me there was an error, you had to leave, and go back in.
And respectfully, if you want to change a device name, this just works, and the sync does work in Google (if Google itself is working).
If you change a user on the Domoticz side, as long as it has access to the devices - and those devices are in A room plan (or more than 1), and you're using https, and you can access it externally yourself, you're good to go.
The app is *still* in beta (thanks Google) - so you need to let me know who you are
donestress1ner wrote: ↑Thursday 14 December 2017 3:39 Hey Madgeni can you ad king**[email protected] to the beta please.
done
- Target OS: -
Hey thanks donation sent 74N23146AL0297534 and for dashbutton help.
pretty much what i put -
https://developers.google.com/actions/s ... aits/modes
the documentation has been cheekily changed since I raised this with them - initially they had "custom names need to be submitted to Google" - now they've put:
"Currently, you must use the names in the example JSON; custom names are not yet supported."
https://github.com/actions-on-google/ac ... /issues/75
done! any problems, post in here
