Alexa, Google Home and Siri
stefanjongerius
Post by stefanjongerius »
Dear Madgeni,
I face a challenge adding test Home Controlicz in GH...I allow the full-access but then Google says, after trying to link, it couldn't update the service and I need to check my connection. Any ideas?
Madgeni
Post by Madgeni »
stefanjongerius wrote: Tuesday 12 December 2017 22:29 Dear Madgeni,
sure - you just need to use https - i think the port you've given Controlicz is your http port :)
sly14
Post by sly14 »
Hello Madgeni, i will be happy to test and use controlicz, [email protected]
stress1ner
Post by stress1ner »
Hey Madgeni I cant find the controlicz app in google home/smarthome, is there anything else i have to do to make it show up.
acole****[email protected]
Madgeni
Post by Madgeni »
if you've enabled it in the simulator, then it should show up?
stefanjongerius
Hi Madgeni,
I now have changed the port in controlicz, this is the https port for Synology (https://MYID.synology.me and then credentials then you reach DSM), I have been able to install Let's Encrypt certificate. However I do not know how to reach domoticz in https, which is still available in http. Is there any way to fwd in DSM to Domoticz? E.g. the tutorials available did not solved the issue yet.
It might be out of your ballpark but who knows...
stress1ner
Hey Madgeni can you ad king**[email protected] to the beta please.
Pwiiikkk
Post by Pwiiikkk »
Hi, I registered controlicz as gaec****@gmail.com could you add me. Thanks.
Noka
Post by Noka »
First a big thanks for your work Madgeni !
I subscribe to Controlicz and I work "hard" for make it work but nothing appear on my home app.
Do you have maybe just a simple tutorial how to make it work?
Thanks in advance for your work
bldewit
Domoticz version: Stable
Post by bldewit »
Hi Madgeni,
I am running into some funky stuff here.
Initially I had problems getting connected to the service in GH. Finally, after adding a fresh new user in Domoticz, I had it up and running.
I used it for several days and I must say, it worked like a charm. Kudos for that! I noticed however that some of the names of my devices were not so practical (dutch names in an English Google Home) so I added some names in description fields.
Queriïng devices did not trigger the names to be added to my Google Home, so I went into the GH app and unlinked the Controlicz service. I then tried to link it agein, with the same credentials, and I got an error saying that my settings cannot be updated, please check your connection.
So, learning from my first experience, I added a new, fresh user and changed the settings on the Controlicz webpage. Same result!
Now, no matter what I do, I always get the same errormessage, using the newest credentials or the credentials that worked before!
Any suggestions?
Unm is blde.....com
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
quirk
Post by quirk »
I also have problems with Controlicz settings and my Domoticz setup, so it would be nice to have a button on the Controlicz profile page to test and check connection between Controlicz and Domoticz
Madgeni
Post by Madgeni »
urgh - I can look to add it, but honestly, this isn't the issue with bldewit - i can see the sync requests being made, and the responses back are fine. The Google apps are just, well, shit. They really don't respond well to change. When I first wrote this integration, it NEVER came back with a success at account linking, it just told me there was an error, you had to leave, and go back in.
And respectfully, if you want to change a device name, this just works, and the sync does work in Google (if Google itself is working).
If you change a user on the Domoticz side, as long as it has access to the devices - and those devices are in A room plan (or more than 1), and you're using https, and you can access it externally yourself, you're good to go.
Madgeni
Post by Madgeni »
Noka wrote: Thursday 14 December 2017 8:45 Hi,
The app is *still* in beta (thanks Google) - so you need to let me know who you are :) give me a few characters of your email address, and i'll find you
Madgeni
Post by Madgeni »
stress1ner wrote: Thursday 14 December 2017 3:39 Hey Madgeni can you ad king**[email protected] to the beta please.
done
Madgeni
Post by Madgeni »
Pwiiikkk wrote: Thursday 14 December 2017 8:19 Hi, I registered controlicz as gaec****@gmail.com could you add me. Thanks.
done
stress1ner
Hey thanks donation sent 74N23146AL0297534 and for dashbutton help.
Lyrex
Post by Lyrex »
Madgeni wrote: Friday 08 December 2017 19:08
Lyrex wrote: Friday 08 December 2017 17:38 Hey Madgeni,
can you leave a message if your selector switch impelentation is finished? Im happy to try it out!
sure thing. as far as I can tell, it's ready, BUT it's with Google, it seems you have to tell them (Seriously) if you want them to include a particular Mode name. I can imagine this not being a quick process..
What do you mean exactly?
Madgeni
Post by Madgeni »
pretty much what i put -
https://developers.google.com/actions/s ... aits/modes
the documentation has been cheekily changed since I raised this with them - initially they had "custom names need to be submitted to Google" - now they've put:
"Currently, you must use the names in the example JSON; custom names are not yet supported."
https://github.com/actions-on-google/ac ... /issues/75
Noka
Post by Noka »
Madgeni wrote: Thursday 14 December 2017 12:14
Ah yes of course :)
There it is : jmi****.****@gmail.com
Hope it will work !
Thanks again
Madgeni
Post by Madgeni »
done! any problems, post in here :)
Users browsing this forum: Google [Bot] and 0 guests
