must be, will enforce float - i'll change it tomorrowmikejclark wrote: ↑Friday 08 December 2017 16:52{ "ActTime" : 1512748152, "ServerTime" : "2017-12-08 15:49:12", "Sunrise" : "08:05", "Sunset" : "15:53", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "17.8 C, 56 %", "Description" : "", "DewPoint" : "8.90", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Virtual Switch", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveTimeout" : false, "Humidity" : 56, "HumidityStatus" : "Comfortable", "ID" : "140EA", "LastUpdate" : "2017-12-08 15:48:57", "Name" : "Lounge Temperature", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "THGN122/123, THGN132, THGR122/228/238/268", "Temp" : 17.800000000000001, "Timers" : "false", "Type" : "Temp + Humidity", "TypeImg" : "temperature", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "154" } ], "status" : "OK", "title" : "Devices" }Madgeni wrote:ok, that's weird!
if you use this - https://yourhost:port/json.htm?type=devices&rid=IDXOFLOUNGETEMPERATURE - what does 'temp' say?
It's now changed to 18. Is it rounding up?
Sent from my GT-I9505 using Tapatalk
Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
sure thing. as far as I can tell, it's ready, BUT it's with Google, it seems you have to tell them (Seriously) if you want them to include a particular Mode name. I can imagine this not being a quick process..
My email is pht***@rnix.net, i have a gsuite account on google, i registered on controlicz. Does that work too?
On my side, I have too many bugs.
Please, would you unregister me (my email is [email protected] ?
Thanks,
QQ.
Thanks,
QQ.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Various mysensors devices (Temp, Hygro, ...)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
maybe. I've definitely had people without gmail accounts struggle
Oh no! That's a real shame - is the issue with Controlicz? Is there anything I can do to help?qqlapraline wrote: ↑Saturday 09 December 2017 21:50 On my side, I have too many bugs.
Thanks,
QQ.
Well, that's not working at all. I have tried adding controlicz in my Google Home App and, after enterring, my login/password to google, if asks the same again.Oh no! That's a real shame - is the issue with Controlicz? Is there anything I can do to help?
May be you have a hint.
Regards,
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
ok, firstly can you re-register with Controlicz, and i'll re-add you to the test, then we can try troubleshooting it
Madgeni, it is working even with my gsuite account and in french
My temperature sensors are in rfxcom, when i ask for the temperature it says me the good one but it add "the thermostat is off" all the time.
I am going to test more things today.
Yep, i have no idea why it says off (it definitely reports as on) - i'll look into it some more
Done.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
ok, so if you can re-enable the test in the simulator, and then try re-linking in the app, i'll see if I can see any errors
It works !
Thanks !
How do I add my switches ?
QQ.
Thanks !
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
are none of your switches showing?
None, exactly.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
It works pretty well !
What do I have to say to change the level of a led strip ?
Regards,
QQ.
Regards,
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
"Adjust <my light> to 65% brightness."
I double checked my config
- Domoticz is up & controlling my devices
- It's setup to prompt for user/pass from everywhere
- I can login with the id I gave controlicz and see/control stuff (using login page option)
- I can access my local 443 port
- from a system on the internet I can connect to 10443 (I am forwarding that to local 443)
- I can login to controlicz and see the right port etc
- If I go to the google actions page I can see controlicz is active
- When I go into google home app I can select controlicz to add a device, I enter my password, then get prompted to approve, then enter again, but then are currently getting redirected to a 404 error (not found at /opt/bitnami/apps/Controlicz/app.js:72:11... contrinues (I have screenshot if needed). Happened twice.
Any ideas?
Update ....
- I had web filtering enabled in safari (Adguard). When I disabled this I no longer got the 404 error.
However in google home after entering password I'm back to the 'something went wrong' error?
ok, i'll look at it this morning - lazy day in the office
I have this message right now, is it because you are working on it?
"I'm sorry, there was an error and I'm unable to control your home device"
