must be, will enforce float - i'll change it tomorrowmikejclark wrote: Friday 08 December 2017 16:52{ "ActTime" : 1512748152, "ServerTime" : "2017-12-08 15:49:12", "Sunrise" : "08:05", "Sunset" : "15:53", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "17.8 C, 56 %", "Description" : "", "DewPoint" : "8.90", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Virtual Switch", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveTimeout" : false, "Humidity" : 56, "HumidityStatus" : "Comfortable", "ID" : "140EA", "LastUpdate" : "2017-12-08 15:48:57", "Name" : "Lounge Temperature", "Notifications" : "false", "PlanID" : "2", "PlanIDs" : [ 2 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "THGN122/123, THGN132, THGR122/228/238/268", "Temp" : 17.800000000000001, "Timers" : "false", "Type" : "Temp + Humidity", "TypeImg" : "temperature", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "154" } ], "status" : "OK", "title" : "Devices" }Madgeni wrote:ok, that's weird!
if you use this - https://yourhost:port/json.htm?type=devices&rid=IDXOFLOUNGETEMPERATURE - what does 'temp' say?
It's now changed to 18. Is it rounding up?
Sent from my GT-I9505 using Tapatalk
Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Madgeni
Madgeni
sure thing. as far as I can tell, it's ready, BUT it's with Google, it seems you have to tell them (Seriously) if you want them to include a particular Mode name. I can imagine this not being a quick process..Lyrex wrote: Friday 08 December 2017 17:38 Hey Madgeni,
can you leave a message if your selector switch impelentation is finished? Im happy to try it out!
phtinix
My email is pht***@rnix.net, i have a gsuite account on google, i registered on controlicz. Does that work too?
qqlapraline
On my side, I have too many bugs.
Please, would you unregister me (my email is [email protected] ?
Thanks,
QQ.
Thanks,
QQ.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Many Mysensors devices (Temp, Hygro, ...)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Madgeni
maybe. I've definitely had people without gmail accounts strugglephtinix wrote: Friday 08 December 2017 20:57 Hello,
Madgeni
Oh no! That's a real shame - is the issue with Controlicz? Is there anything I can do to help?qqlapraline wrote: Saturday 09 December 2017 21:50 On my side, I have too many bugs.
Thanks,
QQ.
qqlapraline
Well, that's not working at all. I have tried adding controlicz in my Google Home App and, after enterring, my login/password to google, if asks the same again.Oh no! That's a real shame - is the issue with Controlicz? Is there anything I can do to help?
May be you have a hint.
Regards,
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Madgeni
ok, firstly can you re-register with Controlicz, and i'll re-add you to the test, then we can try troubleshooting it
phtinix
Madgeni, it is working even with my gsuite account and in french
My temperature sensors are in rfxcom, when i ask for the temperature it says me the good one but it add "the thermostat is off" all the time.
I am going to test more things today.
Madgeni
Yep, i have no idea why it says off (it definitely reports as on) - i'll look into it some more
qqlapraline
Done.Madgeni wrote: Saturday 09 December 2017 23:17 ok, firstly can you re-register with Controlicz, and i'll re-add you to the test, then we can try troubleshooting it
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Madgeni
ok, so if you can re-enable the test in the simulator, and then try re-linking in the app, i'll see if I can see any errors
qqlapraline
It works !
Thanks !
How do I add my switches ?
QQ.
Thanks !
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Madgeni
are none of your switches showing?
qqlapraline
None, exactly.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
qqlapraline
It works pretty well !
What do I have to say to change the level of a led strip ?
Regards,
QQ.
Regards,
QQ.
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Teleinfo
Madgeni
"Adjust <my light> to 65% brightness."
planetf1
Hi,Madgeni wrote: Friday 08 December 2017 9:14 can you double check your domoticz username/password?
weirdly, i can see controlicz is getting a http 503 error, which usually means the Domoticz service is not available - have you done any whitelisting/blacklisting on a firewall?
I double checked my config
- Domoticz is up & controlling my devices
- It's setup to prompt for user/pass from everywhere
- I can login with the id I gave controlicz and see/control stuff (using login page option)
- I can access my local 443 port
- from a system on the internet I can connect to 10443 (I am forwarding that to local 443)
- I can login to controlicz and see the right port etc
- If I go to the google actions page I can see controlicz is active
- When I go into google home app I can select controlicz to add a device, I enter my password, then get prompted to approve, then enter again, but then are currently getting redirected to a 404 error (not found at /opt/bitnami/apps/Controlicz/app.js:72:11... contrinues (I have screenshot if needed). Happened twice.
Any ideas?
Update ....
- I had web filtering enabled in safari (Adguard). When I disabled this I no longer got the 404 error.
However in google home after entering password I'm back to the 'something went wrong' error?
Madgeni
ok, i'll look at it this morning - lazy day in the office
phtinix
I have this message right now, is it because you are working on it?
"I'm sorry, there was an error and I'm unable to control your home device"
