I had same problem, i had to clear localstorage in my webbrowser. try that first.htilburgs wrote: Friday 17 November 2017 9:23 @robgeerts, in the latest beta the language 'nl_NL' is not committed anymore. Bar is in english.
Going to setup, the language is empty and I'm not able to set it either through Setup of in config.JS.
Dashticz - Bug report
- DewGew
- Domoticz version: V4.10618
Re: Dashticz - Bug report
- htilburgs
I've cleared my browser already. It's the first thing I do after an update
Problem did still exists. I've removed the dashticz (beta) installation and did a new git pull --branche beta, restored custom folder and now it's working again. Strange behaviour.
Hardware:
aiolos
- Domoticz version: stable
There was a small bug in the code from the speak_lang setting. It did overwrite the language, causing weird behaviour. I saw Rob just merged the PR's, so the problem should be gone.
- DewGew
If you are using chrome. try this:htilburgs wrote: Friday 17 November 2017 10:02 I've cleared my browser already. It's the first thing I do after an update
Hit F12 the find the Application tab. find "storage" click at "local storage" then right click on your domoticz url and click clear.
- htilburgs
Thanx, that's new for me. Never to old to learn....DewGew wrote: Friday 17 November 2017 10:08If you are using chrome. try this:htilburgs wrote: Friday 17 November 2017 10:02 I've cleared my browser already. It's the first thing I do after an update
1 down, 1 to go....
Using Dashticz in IE11 gives error in beta since 16-11:
getBlock is niet gedefinieerd
main.js (276,8)
line 276: getBlock(columns['bar'],'bar','div.screen'+s+' .row .colbar',false);On my Microsoft Surface Pro 3 I have the same issue in IE11. In Google Chrome it still works...
Hardware:
aiolos
I fixed it in a new PR Rob can merge. It looks like IE11 uses an older version of javascript. In the blocks-code some functionality from a newer version was used since it looks cleaner in code, but unfortunately it didn't work.htilburgs wrote: Friday 17 November 2017 10:13 ...
main.js (276,8)
I'm using a Microsoft Surface RT and only have IE11 available.Code: Select all
- DewGew
It seems that custom.js is not loading in lataste beta?? or is it just my setup??
aiolos
I don't use it myself, but if I test it with some simple logging to the console, I see that logging.
- DewGew
This dont work anymore:
// Change block background color
function getStatus_245(idx,value,device){
if(device['Data']=='On'){
$('div.block_245').addClass('warning');
else {
$('div.block_245').removeClass('warning');
}Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
aiolos
If I paste that in my custom.js it is executed.
with this css:
it is getting a red background if the device is on.
with this css:
.warning {
background-color: red !important;
}- htilburgs
I can confirm.DewGew wrote: Friday 17 November 2017 10:43 It seems that custom.js is not loading in lataste beta?? or is it just my setup??
In latest Stable version custom.js still works
in latest Beta versieon custom.js is broken
Hardware:
aiolos
Can it be something that has to do with this change?DewGew wrote: Friday 17 November 2017 10:43 It seems that custom.js is not loading in lataste beta?? or is it just my setup??
It looks like the execution of getStatus_* is now depending on more settings, which might initially not be set at all:
if(typeof(onOffstates[idx])!=='undefined' && value!==onOffstates[idx]){
- DewGew
Yes it does. I commented that part out and now its working. How can we get around this issue?aiolos wrote: Friday 17 November 2017 13:52Can it be something that has to do with this change?DewGew wrote: Friday 17 November 2017 10:43 It seems that custom.js is not loading in lataste beta?? or is it just my setup??
It looks like the execution of getStatus_* is now depending on more settings, which might initially not be set at all:Code: Select all
aiolos
Move the try-catch outside the if statement for the onOffStates. It was not in there before the change, so it is not necessary for the getStatus_* function.
Edit: I think it is even better to move the code for the sound or speak to the triggerChange function. That function already handles the case where a status has changed. Now there is quite some duplication between triggerStatus() and triggerChange()
- DewGew
I made a PR to fix this ..aiolos wrote: Friday 17 November 2017 13:52Can it be something that has to do with this change?DewGew wrote: Friday 17 November 2017 10:43 It seems that custom.js is not loading in lataste beta?? or is it just my setup??
- htilburgs
Hardware:
- DewGew
Bugfix is now merged on latest betahtilburgs wrote:
- gijsje
- Domoticz version: Stable
I have a radiator valve from smartwares with type "Radiator 1" in domoticz and this shows up as light switch in dasticz.
I also have the thermostat with type "Thermostat" that shows as thermostat in Dashticz what is correct.
Could you change it somehow that the "Radiator 1" also shows that you can change the temperature?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
- Domoticz version: 3.7067
Could you send me the device output from Domoticz of that device?
- gijsje
How can i get this?
