Dashticz - Bug report
- Domoticz version: latest B
Re: Dashticz - Bug report
I'm a bit puzzled about the setTimeout function in the various *.js files for instance weather.js file.
setTimeout(function(){
loadWeather(settings['wu_city'],settings['wu_country']);
}, (60000*30));
I can imagine that the purpose is to refresh the data after 30 minutes.
But the setTimeout function only triggers once in this case after 30 minutes, shouldn't the function be setInterval() instead ?
Frank
}, (60000*30));
Frank
Hi Rob.
First of all i like to mention that i think Dasthicz is realy great. We use it all the time.
I do have an issue i think.
If i create a switch type: Push on Button and if i click that several times from Dashticz, the log shows this:
If i click that same switch several times from within Domoticz, the log shows this:
It looks like the switch is threated differently in Dashticz... is this a "smal" bug?
2017-11-13 13:10:12.233 User: Admin initiated a switch command (335/Test Button/Off)
2017-11-13 13:10:12.280 (Dummy1) Lighting 1 (Test Button)
2017-11-13 13:10:12.467 User: Admin initiated a switch command (335/Test Button/Off)
2017-11-13 13:10:12.529 (Dummy1) Lighting 1 (Test Button)
2017-11-13 13:10:12.982 User: Admin initiated a switch command (335/Test Button/Off)
2017-11-13 13:10:13.028 (Dummy1) Lighting 1 (Test Button)
2017-11-13 13:11:00.066 User: Admin initiated a switch command (335/Test Button/On)
2017-11-13 13:11:00.113 (Dummy1) Lighting 1 (Test Button)
2017-11-13 13:11:02.047 User: Admin initiated a switch command (335/Test Button/On)
2017-11-13 13:11:02.079 (Dummy1) Lighting 1 (Test Button)
2017-11-13 13:11:03.654 User: Admin initiated a switch command (335/Test Button/On)
2017-11-13 13:11:03.717 (Dummy1) Lighting 1 (Test Button)
- Domoticz version: 3.7067
JimmyH1969 wrote: ↑Monday 13 November 2017 13:20 Hi Rob.
If i create a switch type: Push on Button and if i click that several times from Dashticz, the log shows this:If i click that same switch several times from within Domoticz, the log shows this:Code: Select all
2017-11-13 13:10:12.233 User: Admin initiated a switch command (335/Test Button/Off) 2017-11-13 13:10:12.280 (Dummy1) Lighting 1 (Test Button) 2017-11-13 13:10:12.467 User: Admin initiated a switch command (335/Test Button/Off) 2017-11-13 13:10:12.529 (Dummy1) Lighting 1 (Test Button) 2017-11-13 13:10:12.982 User: Admin initiated a switch command (335/Test Button/Off) 2017-11-13 13:10:13.028 (Dummy1) Lighting 1 (Test Button)
It looks like the switch is threated differently in Dashticz... is this a "smal" bug?Code: Select all
2017-11-13 13:11:00.066 User: Admin initiated a switch command (335/Test Button/On) 2017-11-13 13:11:00.113 (Dummy1) Lighting 1 (Test Button) 2017-11-13 13:11:02.047 User: Admin initiated a switch command (335/Test Button/On) 2017-11-13 13:11:02.079 (Dummy1) Lighting 1 (Test Button) 2017-11-13 13:11:03.654 User: Admin initiated a switch command (335/Test Button/On) 2017-11-13 13:11:03.717 (Dummy1) Lighting 1 (Test Button)
Should both be fixed in latest version!yfands wrote: ↑Monday 13 November 2017 1:14 Hello,
}, (60000*30));
Frank
@Frank, in this case it didnt matter because the loadWeather-timeout was inside the loadWeather-function
Thanks Rob. With "latest version" you mean latest beta?
Sorry, yeah, latest beta!
Hi all
I saw just for one day the RGB on Yeelight on Dashticz, now I don't see anymore.
Is it correct?
Is it correct?
It seems my dashticz is not auto updating anymore, I have to reload the page to see devices status change.
My settings have not changed:
I tested this with 2 devices/browsers, same result.
Tried reverting to previous beta (October 18), but with by curent config.js, then it works again.
Must be a bug then in one of the more recent beta's I figure..
Same here. With the latest beta i have to refress manually (F5)
Whoops, sorry, try latest beta (again)...
Yes, here it is:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 27,
"HardwareName" : "Yeelights",
"HardwareType" : "YeeLight LED",
"HardwareTypeVal" : 91,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "C0A80141",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-11-13 19:54:21",
"Level" : 44,
"LevelInt" : 44,
"MaxDimLevel" : 100,
"Name" : "YeeLight 1",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGBW",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Lighting Limitless/Applamp",
"TypeImg" : "dimmer",
"Unit" : 0,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "xxx"
- Domoticz version: 4.10538
Just downloaded latest beta
The refresh does not work for me. Dimmers and Logitech Media Server showing current track do not get updates
just checking that graphs for temp devices that have both Temp&Hum it shows only Hum
It happens when I click on a block defined as idx_1 with Temp value, and I get the popup with Hum graph, and if I have defined a graph as "graph_idx" and I see that I cannot add _1
Any advice?
Any advice?
- Domoticz version: stable
Graphs are a bit weird sometimes. I made some fixes for it and will create a pull request for Rob soon.woody4165 wrote: ↑Wednesday 15 November 2017 17:47 Hi
Any advice?
Check latest beta!
- htilburgs
@robgeerts, in the previous beta you introduced the full screen option.
Works great, but after the screen goes to standby and touching it it comes back to 'normal' mode, the full screen is not active anymore.
Have to select the upper right arrows again to come back to full screen.
Hardware:
- htilburgs
@robgeerts, after pulling the latest beta today, Dashticz doesn't work anymore in IE!
getBlock is niet gedefinieerd
main.js (276,8)
I'm using a Microsoft Surface RT and only have IE11 available.
On my Microsoft Surface Pro 3 I have the same issue in IE11. In Google Chrome it still works...
main.js (276,8)
line 276: getBlock(columns['bar'],'bar','div.screen'+s+' .row .colbar',false);
Hardware:
- htilburgs
@robgeerts, in the latest beta the language 'nl_NL' is not committed anymore. Bar is in english.
Going to setup, the language is empty and I'm not able to set it either through Setup of in config.JS.
Hardware:
