Xiaomi Human Sensor 2
Hello people, I am really impressed with the work of domoticz. I have started using the elements of Xiaomi, but I have seen many shortcomings in their programming. Thing that is solved with domoticz, nevertheless, I have a sensor "Human body sensor 2" that in log says that it does not recognize it. So I guess the Domoticz people work by adding these sensors. Is it possible to know when these sensors are being added?
Thank you very much everyone for the fantastic forum.
IDANIT
Re: Xiaomi Human Sensor 2
You mean Aqara? Works like charm.
Hmm .. so I'm doing something wrong.
Is it possible that I do not recognize it by being synchronized with the gateway?
The log gives me this message:
XiaomiGateway: unhandled model: sensor_motion.aq2
I will try to delete it from the gateway and add it to domoticz.
miroslavpetrov
@arusnet
I am also using the Xiaomi Aqara stuff. I use all the sensors (motion, door, temp+hum and wall switches) everything works absolutely fine.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
pvm
- Domoticz version: 4.10538
Which version of Domoticz are you using? Possibly some elements are only supported in beta
Aaah, I'm using the latest stable version.
hq007
- Domoticz version: 3.8153
Hi, is this still an issue?
I actually have both the Xiaomi Human Sensor 2 and the older one, and the older one works and gets properly detected by Domoticz, however the model 2 does not show up. anybody else have this too?
the domoticz log actually lists;
2018-02-14 20:04:01.797 XiaomiGateway: unhandled model: sensor_motion.aq2
runnning ;
Version: 3.8153
Build Hash: 494fff7-modified
on synology
runnning ;
Version: 3.8153
on synology
Gorefest
I have the same problem, its not supported in stable release and I hesitate to update my domoticz to beta version....
So we will have to wait for the next stable version.
lumjajo
- Domoticz version: 4.10717
Unfortunately I have the same issue with the latest stable version:
the Log says:
Is this fixed in the beta? Although I am quite reluctant to install the beta version due to the recent timer issues...
the Log says:
DAVIZINHO
this is not a issue, is simply that the new aqara sensor only works in beta, not in stable domoticz
daconas
Hello, i have the Problem Auqara Motionsensor not listet.
i have the normal Motionsensor that works but the new not i am on Beta 3.8934
i show i protokoll status hier is wrote find new Auara motion sensor
but i can not find in Devices .
Have some one this Problem ?
funnybu
- Domoticz version: 3.9272
SAme problem
