Xiaomi Human Sensor 2
arusnet
Post by arusnet »
Hello people, I am really impressed with the work of domoticz. I have started using the elements of Xiaomi, but I have seen many shortcomings in their programming. Thing that is solved with domoticz, nevertheless, I have a sensor "Human body sensor 2" that in log says that it does not recognize it. So I guess the Domoticz people work by adding these sensors. Is it possible to know when these sensors are being added?
Thank you very much everyone for the fantastic forum.
IDANIT
Re: Xiaomi Human Sensor 2
Post by IDANIT »
You mean Aqara? Works like charm.
arusnet
Post by arusnet »
Hmm .. so I'm doing something wrong.
Is it possible that I do not recognize it by being synchronized with the gateway?
The log gives me this message:
  XiaomiGateway: unhandled model: sensor_motion.aq2
I will try to delete it from the gateway and add it to domoticz.
miroslavpetrov
Post by miroslavpetrov »
@arusnet
I am also using the Xiaomi Aqara stuff. I use all the sensors (motion, door, temp+hum and wall switches) everything works absolutely fine.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
pvm
Domoticz version: 4.10538
Post by pvm »
Which version of Domoticz are you using? Possibly some elements are only supported in beta
arusnet
Post by arusnet »
Aaah, I'm using the latest stable version.
hq007
Domoticz version: 3.8153
Post by hq007 »
Hi, is this still an issue?
I actually have both the Xiaomi Human Sensor 2 and the older one, and the older one works and gets properly detected by Domoticz, however the model 2 does not show up. anybody else have this too?
the domoticz log actually lists;
2018-02-14 20:04:01.797 XiaomiGateway: unhandled model: sensor_motion.aq2
runnning ;
Version: 3.8153
Build Hash: 494fff7-modified
on synology
Gorefest
Post by Gorefest »
I have the same problem, its not supported in stable release and I hesitate to update my domoticz to beta version....
So we will have to wait for the next stable version.
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
Unfortunately I have the same issue with the latest stable version:
the Log says:
Is this fixed in the beta? Although I am quite reluctant to install the beta version due to the recent timer issues...
DAVIZINHO
Post by DAVIZINHO »
this is not a issue, is simply that the new aqara sensor only works in beta, not in stable domoticz :-(
daconas
Post by daconas »
Hello, i have the Problem Auqara Motionsensor not listet.
i have the normal Motionsensor that works but the new not i am on Beta 3.8934
i show i protokoll status hier is wrote find new Auara motion sensor
but i can not find in Devices .
Have some one this Problem ?
funnybu
Domoticz version: 3.9272
Post by funnybu »
SAme problem
