Xiaomi Human Sensor 2
Hello people, I am really impressed with the work of domoticz. I have started using the elements of Xiaomi, but I have seen many shortcomings in their programming. Thing that is solved with domoticz, nevertheless, I have a sensor "Human body sensor 2" that in log says that it does not recognize it. So I guess the Domoticz people work by adding these sensors. Is it possible to know when these sensors are being added?
Thank you very much everyone for the fantastic forum.
Re: Xiaomi Human Sensor 2
You mean Aqara? Works like charm.
Hmm .. so I'm doing something wrong.
Is it possible that I do not recognize it by being synchronized with the gateway?
The log gives me this message:
XiaomiGateway: unhandled model: sensor_motion.aq2
I will try to delete it from the gateway and add it to domoticz.
@arusnet
I am also using the Xiaomi Aqara stuff. I use all the sensors (motion, door, temp+hum and wall switches) everything works absolutely fine.
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
- Domoticz version: 4.10538
Which version of Domoticz are you using? Possibly some elements are only supported in beta
Aaah, I'm using the latest stable version.
- Domoticz version: 3.8153
Hi, is this still an issue?
I actually have both the Xiaomi Human Sensor 2 and the older one, and the older one works and gets properly detected by Domoticz, however the model 2 does not show up. anybody else have this too?
the domoticz log actually lists;
2018-02-14 20:04:01.797 XiaomiGateway: unhandled model: sensor_motion.aq2
runnning ;
Version: 3.8153
Build Hash: 494fff7-modified
on synology
runnning ;
Version: 3.8153
on synology
I have the same problem, its not supported in stable release and I hesitate to update my domoticz to beta version....
So we will have to wait for the next stable version.
- Domoticz version: 4.10717
Unfortunately I have the same issue with the latest stable version:
the Log says:
Is this fixed in the beta? Although I am quite reluctant to install the beta version due to the recent timer issues...
the Log says:
this is not a issue, is simply that the new aqara sensor only works in beta, not in stable domoticz
Hello, i have the Problem Auqara Motionsensor not listet.
i have the normal Motionsensor that works but the new not i am on Beta 3.8934
i show i protokoll status hier is wrote find new Auara motion sensor
but i can not find in Devices .
Have some one this Problem ?
- Domoticz version: 3.9272
SAme problem
