deennoo wrote: Sunday 03 September 2017 0:42
Ask it on the great topic please, and you Can look on m'y blog searching for yeelight give you some exemple for white model, yeelight api is similar for rgb
Sorry
mmm was thinking this was the great topic, when i search i see only this...
Perhaps a link to the good topic...
Yes its not that the Xiaomi app is bad at all, but using Domoticz opens up much more possibilities and can be quite powerful, and can be combined with devices from other manufacturers.
marcotini wrote: Saturday 02 September 2017 8:45
I don't know if there is one in Domoticz. It's just a water presence so I think that just 1 or 0 it's ok lol.
I think there is support for smoke alarm and gas alarm, i think this is the same, but water alarm
I could add it the same as the smoke alarm no problem, but hoping someone can suggest a more appropriate device.
Don't know what this would be, what Xiaomi devices do you have?
I have the Gateway, 6 temperatures sensors (1st gen round), 2 power plug, 5 door sensros (3 1st gen, 2 2nd gen), 4 motion sensor (1st gen), 1 magic cube, 1 wireless wall double switch, 4 buttons (3 1st gen, 1 2nd gen) and 1 smoke detector.
You can know whitch device is: in mihome enter the gateway->options->about->gateway information and search the device with this ID. You can know the type from the name in model.
corbin wrote:Out of those, button 2nd gen and temperature sensor is what I don't have. Are all those devices working in Domoticz?
Yes, although the temp 2 sensor generates separate devices and that is a bit of a problem for homebridge support.
The baro is presented as general device with pressure as secondary. It would be better if that is presented as a real barometric sensor, now domoticz and homebridge don't see it as a weather sensor.
I have bought a Xiaomi gateway in China last week but it doesn't connect to Domoticz.
I can control the gateway and read the status of my temperature sensor in the Mi Home app.
I've enabled LAN Communication protocol in the Mi Home app and wrote down the password.
Then I added the new hardware in Domoticz with correct IP address, port 9898 and the correct password.
But then I can't see any new devices in the devices tab.
I've also tried it on a new installed raspberry pi with domoticz on a stand alone network but also no result.
anyone who can help me?
Thanks,
Leon
What is you Fw version please ?
Rfxtrxe / RFLink / Milight / Yeelight / Tasmota / MQTT / BLE / Zigate http://domo-attitude.fr
i'de like to create a scene where when i close a door with xiaomi door sensor one light is on and when the door is open light is off.
how i can i make it possible??
thank you
