Controlicz - Easy Domoticz to Alexa Integration Topic is solved
- michaldobrotka
Re: Easy Domoticz to Alexa Integration
Hi Madgeni,
Thanks for great skill, and cheers!
Question:
I have ADSL connection with dynamic IP. If my IP address will change Im loosing connection to Echo, right?
Is there possibility to set it somehow fix?
Question:
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
Hi -
i have the same - I use noip.com, it's free and provides a static hostname
Thanks for the donation MichalDobrotka
Hi Madgeni,
Is it possible to setup with no port requirement?
I've got my server running with name mapping (I can't remember the actual term!) rather than ports e.g:
https://www.example.com/domoticz/
Clabs
Clabs
There's always one! The port is a required field. Let me have a think, see what we can do..
I try to be difficult whenever possible!
Cheers,
Clabs
Cheers,
Clabs
- Domoticz version: Stable
If no port is given it should be 443 ? so if you do not fill out the port on the webpage , then assume 443.
Other ports being used can not be guessed.
yep, that was going to be my plan - should look at it tomorrow evening, and ping here when it's done
ok, at the airport bored, change to default 443 made - someone want to test it?
Hi, I have a Synology NAS DS216+ II and installed the 'easy' Domoticz app. Everything runs great. Recently I bought a Amazon Echo Dot and activated Controlicz on it. Unfortunately I don't see any devices. I created rooms but that didn't help. After reading the FAQ I found out that Domoticz need to run on HTTPS and that's where I got lost. I understand that I have to install something 'easy' on my Synology but I have no idea how to do so!? I'm a dummy when it comes to codes. Does anyone have an idea how I can deal with this HTTPS 'problem'?
Hi, I'm not sure if any specific config needed on a Synology, however, SSL is on by default now with Domoticz. Can you access your Domoticz internally using HTTPS? If so, it's just port forwarding that's needed
Thanks for you quick reply! No, unfortunately I internally can't connect to Domoticz via HTTPS. On my Synology I checked the box that says 'redirect all http connections to https', but still nog connection is possible. I'm sure the solution is very simple but I can't find it.
Stuck on a plane on the tarmac in London, so I'm looking for something to occupy me
looks like the default ssl
Port for Synology is 8443, did you specify that?
HTTPS://hostname:8443 ?
8443 that did the trick, thanks! Am I correct that now just port forwarding is neceserry so Controlicz can connect to Domoticz?
That should do it, and update the port in your Controlicz profile
Ok I now configured the port forwarding but I'm not able to connect to Domoticz. I already did a online port check and it says the port is open. When I forward to port 8084 (http) it works fine but when forward to 8443 (https) there is no connection. I think I miss something...
ok, sounds like a synology thing - is there a synology forum on here?
I am running the on Synology DS216play (which is almost identical as your version), and setup port forwarding to 8443 succesfully. Controlicz is working fine for me now with the great support of Madgeni.
When you can internally access your domoticz instance on port 8443 it is almost certainly not Synology related. Please double check your port forwarding settings in your router and try to access from a device outside of your LAN.
I found the solution... just did a restart of my Synology and everything is working fine now!
Thank you al for helping me. At the moment I'm not able to test Alexa but tonight I will. Hopefully everything will be fine
you should be able to discover the devices via the APP remotely
