Moderators: leecollings , htilburgs , robgeerts
robgeerts
Posts: 1273 Joined: Saturday 24 January 2015 22:12
Domoticz version: 3.7067
Post
by robgeerts » Thursday 27 July 2017 16:23
It's working now @mozart, @benbammens could you try latest beta?
If it is still not working, it might be another bug. Please send me your Teamviewer ID and PASS via PM.
Mozart
Posts: 39 Joined: Monday 19 January 2015 14:35
Post
by Mozart » Thursday 27 July 2017 16:25
robgeerts wrote: It's working now @mozart, @benbammens could you try latest beta?
Indeed, it's working again.
Thanks Rob
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
benbammens
Posts: 29 Joined: Tuesday 30 May 2017 19:43
Post
by benbammens » Thursday 27 July 2017 16:39
Still nothing. I've sent PM
vgr2
Posts: 71 Joined: Monday 29 August 2016 12:02
Post
by vgr2 » Thursday 27 July 2017 21:14
Hi Rob, did update to last beta without notification from Setting Module. Now I have black screen. How can I get back to config.js?
robgeerts
Post
by robgeerts » Thursday 27 July 2017 21:31
Could yoimu send me your Teamviewer details via PM?
vgr2
Post
by vgr2 » Thursday 27 July 2017 22:29
Thanks Rob, now it's working
benbammens
Post
by benbammens » Friday 28 July 2017 20:12
En na een kleine ingreep van Rob werkt het nu ook bij mij. Bedankt!
robgeerts
Post
by robgeerts » Friday 28 July 2017 20:16
Yes, and fixed the thing that caused the problem in latest beta!
Derik
Posts: 1601 Joined: Friday 18 October 2013 23:33
Post
by Derik » Saturday 29 July 2017 0:43
mm mine is flashing the [new ] setting screen...
Cannot get the screen.
capman
Posts: 153 Joined: Friday 12 July 2013 20:48
Post
by capman » Saturday 29 July 2017 20:35
Also black screen here with the last beta
. Some solution 4 this ? I have used firefox and chrome .
robgeerts
Post
by robgeerts » Sunday 30 July 2017 12:16
What if you manually add configuration in config.js? ( in de topicstart you can find this code)
capman
Post
by capman » Sunday 30 July 2017 15:55
Okee , I found it why my screen goes black. As soon when I have multiple screens ,3 or more, it goes wrong. With 2 screens it's working.
Working code (All the way 2 the end)
Spoiler: show var config = {}
config['domoticz_ip'] = 'http://xxxxxxxxxxxxx ';
config['default_news_url'] = 'http://www.standaard.be/rss/section/1f2 ... 8784c7ea7c ';
config['news_scroll_after'] = '15';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dddd DD MMMM YYYY HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 'https://xxxxxxxxxxxx/basic.ics ';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'xxxxxxxxxxxx';
config['gm_zoomlevel'] = '13';
config['gm_latitude'] = xxxxxxxxxxx';
config['gm_longitude'] = 'xxxxxxxxxx';
config['wu_api'] = 'xxxxxxxxxxxx';
config['wu_city'] = 'xxxxxxxxxx';
config['wu_name'] = 0;
config['wu_country'] = 'BE';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'xxxxxxxxxxxxxx';
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 0;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
//TV Gids
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:12, channels: [5,6,60,49], maxitems: 6 }
//var _STANDBY_CALL_URL = 'http://192.168.178.42/cgi-bin/screen_br ... ghtness=20 '; //adjust brightness raspberry touchscreen, leave empty if not used
//var _END_STANDBY_CALL_URL = 'http://192.168.178.42/cgi-bin/screen_br ... htness=250 '; //adjust brightness raspberry touchscreen, leave empty if not used
//predefined colors, when you have RGB-lamps
//var _SAVED_COLORS = ['black', 'white', 'blanchedalmond','rgb(255, 128, 0);', 'hsv 100 70 50', 'lightyellow'];
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3 "},
{"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3 "},
{"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3 "},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
//var _ICALENDAR_URL = 'https://calendar.google.com/calendar/ic ... /basic.ics '; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
//var _ICALENDAR_DATEFORMAT = 'dddd DD MMMM YYYY HH:mm'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm','dddd DD MMMM YYYY HH:mm'
//var _ICALENDAR_LOCALE = 'nl_NL'; //en,hu, etc.
var calendars = {}
calendars.business = {width:12, maxitems: 3,icon: 'fa-calendar ', url: 'https://calendar.google.com/calendar/em ... e/Brussels ', icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics ' }
calendars.private = {maxitems: 3,icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics ' }
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256 ', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667 '}
buttons.camvoordeur = {width:12, isimage:true, refresh:2000, image: 'http://xxxxxxxxxxxxxxx
buttons.radio = {width:12, image: 'img/radio_on.png', title: 'Radio', url: 'http://192.168.178.29:9002 '}
buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl '}
buttons.nzbget = {width:4, icon: 'fa-download', title: 'NZBget', url: 'http://192.168.178.29:6789 '}
buttons.calendar = {width:4, icon: 'fa-calendar', title: 'Kalender', url: 'https://calendar.google.com/calendar '}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
buttons.domoticz = {width:12, icon:'fa-microchip', title: 'Domoticz Log', url: 'http://192.168.178.29:8084/json.htm?typ ... loglevel=2 '}
// Afvalwijzer
var trashcan = {}
trashcan.afvalapp = {key:'afvalapp',maxitems: 2,trashapp: 'ophaalkalender', width:4,street:'xxxxxxxxxxxxxxxx', country:'BE' }
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Restafval'] = 'Rest'
trashnames['Pmd'] = 'PMD'
trashnames['P-k'] = 'Papier'
trashnames['Glas'] = 'Glas'
trashnames['Snoeiafval'] = 'Snoeiafval'
var trashcolors = {}
trashcolors['Gft'] = 'green';
//trashcolors['P-k'] = 'brown';
trashcolors['Restafval'] = 'Darkgrey'
trashcolors['Pmd'] = 'deepskyBlue'
trashcolors['Glas'] = 'yellow'
trashcolors['Snoeiafval'] = 'lightgreen'
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'SCHAKELAARS';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'INFO';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Verkeersinfo';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'MUZIEK';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'ROLLUIKEN';
blocks['blocktitle_5']['width'] = 5;
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'CAMERA';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'SPEEDTEST.NET';
blocks['blocktitle_7']['width'] = 4;
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'LICHAAM';
blocks['blocktitle_8']['width'] = 4;
//NIEUWS
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.stand ... 8784c7ea7c ';
blocks['news_1']['width'] = 12;
//SCHAKELAARS
blocks[276] = {}
//blocks[276]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[276]['title'] = 'Thermostaat' //if you want change the name of switch different then domoticz
blocks[276]['icon'] = ' fa-lightbulb-o'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[276]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[215] = {}
blocks[215]['width'] = 4;
blocks[215]['title'] = 'Handmatig'
blocks[215]['icon'] = 'fa-hand-paper-o';
blocks[211] = {}
blocks[211]['width'] = 4;
blocks[211]['title'] = 'Slaapwel'
blocks[211]['image'] = 'sleep.png';
blocks[227] = {}
blocks[227]['width'] = 12;
blocks[227]['title'] = 'Lampje tablet'
blocks[30] = {}
blocks[30]['width'] = 12;
blocks[30]['title'] = 'Inkom'
blocks[29] = {}
blocks[29]['width'] = 12;
blocks[29]['title'] = 'Haard'
blocks[24] = {}
blocks[24]['width'] = 12;
blocks[24]['title'] = 'Lamp TV'
blocks[46] = {}
blocks[46]['width'] = 12;
blocks[46]['title'] = 'Rond tafeltje'
blocks[26] = {}
blocks[26]['width'] = 12;
blocks[26]['title'] = 'Leeslicht'
blocks[25] = {}
blocks[25]['width'] = 12;
blocks[25]['title'] = 'Leeslicht'
//ROLLUIKEN
blocks[18] = {}
blocks[18]['width'] = 6;
blocks[18]['title'] = 'Keuken'
blocks[18]['hide_stop'] = true;
blocks[17] = {}
blocks[17]['width'] = 6;
blocks[17]['title'] = 'Terras'
blocks[17]['hide_stop'] = true;
blocks[15] = {}
blocks[15]['width'] = 6;
blocks[15]['title'] = 'Eetkamer'
blocks[15]['hide_stop'] = true;
blocks[16] = {}
blocks[16]['width'] = 6;
blocks[16]['title'] = 'Woonkamer'
blocks[16]['hide_stop'] = true;
blocks[14] = {}
blocks[14]['width'] = 6;
blocks[14]['title'] = 'Buro'
blocks[14]['hide_stop'] = true;
blocks[20] = {}
blocks[20]['width'] = 6;
blocks[20]['title'] = 'Slaapkamer Groot'
blocks[20]['hide_stop'] = true;
blocks[65] = {}
blocks[65]['width'] = 6;
blocks[65]['title'] = 'Slaapkamer Klein'
blocks[65]['hide_stop'] = true;
blocks[21] = {}
blocks[21]['width'] = 6;
blocks[21]['title'] = 'Slaapkamer 2'
blocks[21]['hide_stop'] = true;
blocks[22] = {}
blocks[22]['width'] = 6;
blocks[22]['title'] = 'Slaapkamer 3'
blocks[22]['hide_stop'] = true;
blocks[23] = {}
blocks[23]['width'] = 6;
blocks[23]['title'] = 'Badkamer'
blocks[23]['hide_stop'] = true;
//REGEN VERWACHT
blocks[354] = {}
blocks[354]['width'] = 4;
blocks[354]['title'] = ''
blocks[354]['icon'] = 'fa-tint';
//VERWARMING
blocks[276] = {}
blocks[276]['title'] = 'Verwarming'
//blocks[276]['icon'] = 'fa-tint';
//GEWICHT
blocks[375] = {}
blocks[375]['width'] = 4;
blocks[375]['title'] = 'Sabine'
blocks[375]['icon'] = 'fa-balance-scale';
blocks[375]['gotoslide'] = 3;
blocks[375]['gotoslide']['auto_close'] = 30; //seconds
blocks[376] = {}
blocks[376]['width'] = 12;
blocks[376]['title'] = 'Kris'
blocks[376]['icon'] = 'fa-balance-scale';
blocks[376]['gotoslide'] = 3;
blocks[376]['gotoslide']['auto_close'] = 30; //seconds
blocks[377] = {}
blocks[377]['width'] = 12;
blocks[377]['title'] = 'Milan'
blocks[377]['icon'] = 'fa-balance-scale';
blocks[377]['gotoslide'] = 3;
blocks[377]['gotoslide']['auto_close'] = 30; //seconds
blocks[378] = {}
blocks[378]['width'] = 4;
blocks[378]['title'] = 'Robin'
blocks[378]['icon'] = 'fa-balance-scale';
blocks[378]['gotoslide'] = 3;
blocks[378]['gotoslide']['auto_close'] = 30; //seconds
//Temperatuur
blocks[4] = {}
//blocks[4]['width'] = 4;
blocks[4]['title'] = 'Slaapkamer 1'
//blocks[4]['icon'] = 'fa-tint';
blocks[4]['switch'] = true; //if you want to switch the title and data
//Internet speed
blocks[356] = {}
blocks[356]['width'] = 4;
//blocks[356]['title'] = 'Ping'
blocks[356]['icon'] = 'fa-globe';
blocks[357] = {}
blocks[357]['width'] = 4;
//blocks[357]['title'] = 'Mbit/s'
blocks[357]['icon'] = 'fa-download';
blocks[358] = {}
blocks[358]['width'] = 4;
//blocks[358]['title'] = 'Upload'
blocks[358]['icon'] = 'fa-upload';
//Popup Camera Deurbel
blocks[366] = {}
blocks[366]['width'] = 2;
blocks[366]['openpopup'] = {}
blocks[366]['openpopup']['url'] = 'http://xxxxxxxx ';
blocks[366]['openpopup']['auto_close'] = 15; //seconds
//Muziek
blocks[338] = {}
blocks[338]['width'] = 4;
//blocks[356]['icon'] = 'fa-globe';
//MAPS
//var maps = {}
//maps.beveren = { width:12, latitude: xxxxxx, longitude: xxxxxxxx, zoom:13 }
//KOLOMMEN
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',211,215,276,'blocktitle_2','traffic',trashcan.afvalapp,354,320,calendars.business,calendars.private,'news_1']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',4,2,250,256,318,277,174,'blocktitle_4','spotify']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise',buttons.buienradar,buttons.camvoordeur,'blocktitle_8',376,377]
columns[3]['width'] = 2;
columns[4] = {}
columns[4]['blocks'] = ['clock']
columns[4]['width'] = 12;
columns[5] = {}
columns[5]['blocks'] = ['blocktitle_8',375,376,377,378]
columns[5]['width'] = 5;
columns[6] = {}
columns[6]['blocks'] = [buttons.domoticz]
columns[6]['width'] = 5;
columns[7] = {}
columns[7]['blocks'] = ['blocktitle_5',18,17,15,16,14,20,65,21,22,23]
columns[7]['width'] = 5;
columns[8] = {}
columns[8]['blocks'] = ['clock']
columns[8]['width'] = 12;
columns[9] = {}
columns[9]['blocks'] = [buttons.camvoordeur,366]
columns[9]['width'] = 12;
columns[10] = {}
columns[10]['blocks'] = ['blocktitle_1',227,30,29,24,46,26,25]
columns[10]['width'] = 12;
//STANBY SCHERM
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg10.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'bg10.jpg';
screens[2]['columns'] = [10]
screens[3] = {}
screens[3]['background'] = 'bg10.jpg';
screens[3]['columns'] = [4,5,6,7]
screens[4] = {}
screens[4]['background'] = 'bg10.jpg';
screens[4]['columns'] = [8,9]
NOT Working code (also @the end
//TV Gids
var tvguide = {}
var calendars = {}
var buttons = {}
// Afvalwijzer
var trashcan = {}
var trashnames = {}
var blocks = {}
//NIEUWS
//SCHAKELAARS
blocks[276] = {}
blocks[215] = {}
blocks[211] = {}
blocks[227] = {}
blocks[30] = {}
blocks[29] = {}
blocks[24] = {}
blocks[46] = {}
blocks[26] = {}
blocks[25] = {}
//ROLLUIKEN
blocks[18] = {}
blocks[17] = {}
blocks[15] = {}
blocks[16] = {}
blocks[14] = {}
blocks[20] = {}
blocks[65] = {}
blocks[21] = {}
blocks[22] = {}
blocks[23] = {}
//REGEN VERWACHT
blocks[354] = {}
//VERWARMING
blocks[276] = {}
//GEWICHT
blocks[375] = {}
blocks[376] = {}
blocks[377] = {}
blocks[378] = {}
//Temperatuur
blocks[4] = {}
//Internet speed
blocks[356] = {}
blocks[357] = {}
blocks[358] = {}
blocks[366] = {}
//Muziek
blocks[338] = {}
//MAPS
//var maps = {}
//KOLOMMEN
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[4] = {}
columns[5] = {}
columns[6] = {}
columns[7] = {}
columns[8] = {}
columns[9] = {}
columns[10] = {}
//STANBY SCHERM
var screens = {}
screens[1] = {}
screens[2] = {}
screens[3] = {}
screens[4] = {}
In the code is some 'xxxx' 4 hiding some personal data
robgeerts
Post
by robgeerts » Sunday 30 July 2017 20:42
This is working for me...
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg9.jpg';
screens['default'][1]['columns'] = [1,2,4]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = [5,6,7]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = [5,6,7]
screens['default'][4] = {}
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = [5,6,7]
screens['tablet'] = {}
screens['tablet']['maxwidth'] = 1024;
screens['tablet']['maxheight'] = 768;
screens['tablet'][1] = {}
screens['tablet'][1]['background'] = 'bg9.jpg';
screens['tablet'][1]['columns'] = [1]
screens['tablet'][2] = {}
screens['tablet'][2]['background'] = 'bg9.jpg';
screens['tablet'][2]['columns'] = [2]
capman
Post
by capman » Monday 31 July 2017 21:35
Working 4 me also now, with the latest beta.
gielie
Posts: 290 Joined: Tuesday 12 January 2016 11:40
Domoticz version: latest β
Post
by gielie » Saturday 05 August 2017 12:50
I tried the latest beta but I also get a black screen. I tried to reduce the screens to 2 as stated above but still no luck.
Someone have an idea that might work?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Blueone
Posts: 130 Joined: Friday 29 November 2013 11:30
Post
by Blueone » Saturday 05 August 2017 20:55
add "var config = {}" to the top of the config file, that resolved it for me (Was using the latest beta but also a black screen).
And another question
, is it possible to set the sunrise on the place of the logo in the title bar (maybe an option in the menu)?
robgeerts
Post
by robgeerts » Saturday 05 August 2017 21:45
In latest beta, use:
columns['bar'] = {}
columns['bar']['blocks'] = ['sunrise','miniclock','settings']
Blueone
Post
by Blueone » Sunday 06 August 2017 9:28
PeJeWe
Posts: 56 Joined: Monday 28 November 2016 20:52
Domoticz version: Latest
Post
by PeJeWe » Thursday 16 November 2017 20:54
The function "edit mode" dus not work.
i have tried to reinstall it several times.
I have used git pull.
It won't save changes. i use Chrome
when i push save and i refresh nothing happens.
F12 shows me:
Uncaught TypeError: Cannot read property 'width' of undefined
at HTMLDivElement.eval (eval at globalEval (jquery.min.js:2), <anonymous>:72:47)
at Function.each (jquery.min.js:2)
at n.fn.init.each (jquery.min.js:2)
at saveBlocks (eval at globalEval (jquery.min.js:2), <anonymous>:43:20)
at HTMLAnchorElement.onclick ((index):1)
I cant add plugins.
robgeerts
Post
by robgeerts » Friday 17 November 2017 22:50
Could you test latest beta?
Remember, this function is heavily in beta
Later I want to add a menu for new blocks to add.
