Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
heggink
Domoticz version: 12451
Re: Easy Domoticz to Alexa Integration
Post by heggink »
Done
DASHTICZ 🙃
P1 meter & solar panel
EdwinK
Post by EdwinK »
Looks cool to me.
Madgeni
Post by Madgeni »
To the person who left the 1 star review, you are a tough person to please!!
heggink
Post by heggink »
Hopefully, my 5 stars compensated a bit. It truly was a 5 star experience: registered on controlicz, added the skill, disabled my old skill, rediscovered devices and was back up and running in a jiffy.
DASHTICZ 🙃
jaschu
Domoticz version: 3.8184
Post by jaschu »
Hey Madgeni, seems to be a very great work you did there! Thank you for that! Could you tell me if or when you release the skill for germany? Kind regards.
ImNtReal
Post by ImNtReal »
I'm not sure if this is really the best place to ask for support, but I'm having trouble linking my Echo to my Controlicz account. I set up my Controlicz account just fine, but when I try to enable the skill, and link my account, it won't accept the credentials I use to sign in to the Controlicz site. I get the HTTP Basic Auth prompt, and copy and paste my e-mail address and password, but it fails. Thanks.
Madgeni
Post by Madgeni »
Hi - you'll need to switch to HTTPS on your Domoticz.
However, just noticed DNS is screwed, which is nice, not sure how I managed to do that from Paris, without a laptop. Will fix asap tomorrow am.
ImNtReal
Post by ImNtReal »
I'm using HTTPS on it. It's frontended with an Apache server. Does it matter that I have HTTP Auth in front of it?
Madgeni
Post by Madgeni »
hmm, well i don't mind, as long as the connection to domoticz is https. I'll trawl through the logs in the morning and we'll fix it :)
DNS now ok - think it could be an intermittent issue between godaddy and route53
Madgeni
Post by Madgeni »
jaschu wrote:Hey Madgeni, seems to be a very great work you did there! Thank you for that! Could you tell me if or when you release the skill for germany? Kind regards.
i've just pushed the German version for certification, so fingers crossed!
jaschu
Post by jaschu »
Great to hear! Thank you so much for the easy integration!
Madgeni
Post by Madgeni »
quick one for the users - if you don't have it working, can you check if you've put 'https://' before your hostname on Controlicz? If so, can you remove it? New users will be asked nicely to remove it :)
I'm not on FB, but thank you for the post on there highlighting my Alexa skill. If anyone on there has a problem, could you direct them here?
farhanito
Post by farhanito »
I don't know what's wrong, but alexa keep saying "[device name] doesn't support that". i was trying to get temp (from a sensor) and locking the door. both yield same result.
Madgeni
Post by Madgeni »
are you invoking get temp as "Alexa whats the temperature of device name?" - that should be ok. Let me know roughly when you did it, and i'll take a look through the logs. Locks might well still be buggy - will take a look tonight :)
Lyrex
Post by Lyrex »
great to see a alexa skill released at the skill store. Is it planned to release this skill in germany too?
Madgeni
Post by Madgeni »
yes, it's currently going through certification for Germany, should be this week :)
Scoobydoo
Post by Scoobydoo »
Excellent skill. Works perfectly. Took some getting head around SSL and setting up users but once I'd figured it out then the skill found my devices and controls them without issue.
I was running a ha bridge before this but this is now redundant and the skill is far far better.
Thanks for the hard work.
Madgeni
Post by Madgeni »
Thanks Scoobydoo - can I ask you give it a review on Amazon?
jaschu
Post by jaschu »
Unfortunately the Skill isn´t accessible in the german store. Looking forward for using it this week. Sorry for my impatience :lol:
gomario
Post by gomario »
Scoobydoo wrote:Excellent skill. Works perfectly. Took some getting head around SSL and setting up users but once I'd figured it out then the skill found my devices and controls them without issue.
Absolutely agree. Was using HA-Bridge until discovering Madgeni's work just a couple of days ago. Worked on first attempt! EXCELLENT WORK!!
Madgeni wrote:Thanks Scoobydoo - can I ask you give it a review on Amazon?
DONE and DONE!
Thanks again mate. Let us know if you need any help keeping the server choochin'.
