Blockly script doesn't work
bkrajnc
Post by bkrajnc »
Hi all
I have dht22 and switch/relay connected on esp8266. When I enable/disable switch in domoticz everything works fine, relay turns on or off. Now I try with Blockly logic. I would like to enable switch when the temperature measured with dht22 is equal or higher than 31 degrees and turn off when temperature is lower than 29 degrees.
Switch configuration
ScreenHunter_302 Jul. 04 18.58.jpg (151.39 KiB) Viewed 1894 times
Blockly
logic
logic
ScreenHunter_305 Jul. 04 19.57.jpg (114.65 KiB) Viewed 1894 times
I think this should work but it doesn't. What I am doing wrong?
Any advice would be helpfull
THX
bkrajnc
Re: Blockly script doesn't work
Post by bkrajnc »
.....realy nobody knows ?
dressie
Domoticz version: V2020.2
Post by dressie »
Ad the state of the switch in the first line, so if temp=31 and switch is off set switch on.
Verstuurd vanaf mijn SM-G920F met Tapatalk
StanHD
Post by StanHD »
I think this cannot work because:-
1. You have used an "If / Else If" block without an Else If. This will not work, use the other "If " block without the blue gear symbol.
2. You have joined 2 of these together. This will not work either.
Try to redo this with a single If / Else If block something like:-
If living room temp > 30 and Relay = Off
Do set Relay = On
Else If living room temp < 30 and Relay = On
Do set Relay = Off
Hope that helps.
Python:- Broadlink RM2, Sonos
bkrajnc
Post by bkrajnc »
Many thanks to all. I will check tomorow when I come from holidays ;)
bkrajnc
Post by bkrajnc »
It works like I expected ;-)
Once again, many thanks for both of answers
Boris
