Hi all
I have dht22 and switch/relay connected on esp8266. When I enable/disable switch in domoticz everything works fine, relay turns on or off. Now I try with Blockly logic. I would like to enable switch when the temperature measured with dht22 is equal or higher than 31 degrees and turn off when temperature is lower than 29 degrees.
Blockly
I think this should work but it doesn't. What I am doing wrong?
Any advice would be helpfull
THX
Blockly script doesn't work
bkrajnc
Re: Blockly script doesn't work
.....realy nobody knows ?
dressie
- Domoticz version: V2020.2
Ad the state of the switch in the first line, so if temp=31 and switch is off set switch on.
Verstuurd vanaf mijn SM-G920F met Tapatalk
- StanHD
I think this cannot work because:-
1. You have used an "If / Else If" block without an Else If. This will not work, use the other "If " block without the blue gear symbol.
2. You have joined 2 of these together. This will not work either.
Try to redo this with a single If / Else If block something like:-
If living room temp > 30 and Relay = Off
Do set Relay = On
Else If living room temp < 30 and Relay = On
Do set Relay = Off
Hope that helps.
Do set Relay = On
Do set Relay = Off
Hope that helps.
Python:- Broadlink RM2, Sonos
bkrajnc
Many thanks to all. I will check tomorow when I come from holidays
bkrajnc
It works like I expected
Once again, many thanks for both of answers
Boris
Boris
