TigroEHOT
Post by TigroEHOT »
2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-19 22:04:46.533 {"cmd":"report","model":"ctrl_ln1","sid":"158d00012a35e7","short_id":24692,"data":"{\"channel_0\":\"off\"}"}
warmaniac
Post by warmaniac »
corbin wrote:@langoo and @TigroEHOT
When it reports 'unhandled model', it should say what the name is, ie
XiaomiGateway: unhandled model: tempsensor
I need to know what the name is (tempsensor in the above example) and what device it is. Also will need an example of the raw message output - enable raw gateway messages - see https://www.domoticz.com/wiki/Xiaomi_Ga ... leshooting
nothing new for me , have 2 pcs new Aqara magnet door/window plus 2pcs Aqara Temperature/Humidity/Pressure sensors
2017-06-19 14:22:49.464 2017-06-19 14:22:49.464 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.465 2017-06-19 14:22:49.465 {"cmd":"read_ack","model":"","sid":"158d00017200ff","short_id":26405,"data":"{\"voltage\":3015}"}
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 {"cmd":"read_ack","model":"","sid":"158d0001a4c79e","short_id":44567,"data":"{\"voltage\":3005}"}
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 {"cmd":"read_ack","model":"","sid":"158d00016c3e55","short_id":55642,"data":"{\"voltage\":3045}"}
2017-06-19 14:22:49.468 2017-06-19 14:22:49.468 {"cmd":"read_ack","model":"","sid":"158d00016c402b","short_id":30460,"data":"{\"voltage\":3035}"}
SwordFish
Domoticz version: V4.11375
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by SwordFish »
deennoo wrote:
SwordFish wrote:
deennoo wrote:
Sory for asking but is it on your blog already?
Cant find it.
A simple how to is online for yeelight bedside lamp & Domoticz : http://domo-attitude.fr/tuto-lampe-de-c ... -domoticz/
That in simple french word, google translate do a good job, i'll provied a how to on domoticz wiki next week.
If some one can help by provieding a Python Plugin this can be perfect
I try to install this but get a error when trying to install enum :(
Is it also possible to control 2 bedlights?
pi@raspberrypi:~ $ sudo pip3 install enum
Downloading/unpacking enum
  Downloading enum-0.4.6.tar.gz
  Running setup.py (path:/tmp/pip-build-2iowbxb_/enum/setup.py) egg_info for package enum
      File "<string>", line 3, in <module>
      File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 12, in <module>
        from setuptools.extension import Extension
      File "/usr/lib/python3/dist-packages/setuptools/extension.py", line 7, in <module>
        from setuptools.dist import _get_unpatched
      File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 16, in <module>
        from setuptools.depends import Require
      File "/usr/lib/python3/dist-packages/setuptools/depends.py", line 6, in <module>
        from setuptools import compat
      File "/usr/lib/python3/dist-packages/setuptools/compat.py", line 45, in <module>
        import http.client as httplib
      File "/usr/lib/python3.4/http/client.py", line 69, in <module>
        import email.parser
      File "/usr/lib/python3.4/email/parser.py", line 12, in <module>
        from email.feedparser import FeedParser, BytesFeedParser
      File "/usr/lib/python3.4/email/feedparser.py", line 27, in <module>
        from email import message
      File "/usr/lib/python3.4/email/message.py", line 16, in <module>
        from email import utils
      File "/usr/lib/python3.4/email/utils.py", line 29, in <module>
        import socket
      File "/usr/lib/python3.4/socket.py", line 51, in <module>
        from enum import IntEnum
    ImportError: cannot import name 'IntEnum'
    Complete output from command python setup.py egg_info:
    import email.parser
    import socket
deennoo
Post by deennoo »
SwordFish wrote:
deennoo wrote:
Cant find it.
        import email.parser
        import socket
    import email.parser
    import socket
please contact me on my blog...this topic is for xiaomi zigbee device ok ?
deennoo
Post by deennoo »
TigroEHOT wrote:2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
Your switch is the wall mounted one ?this one who need Line and neutral ? with a single button ?
I just recieve a dual switch from this serie, but didn't open it already, will try to help Corbin
@corbin this device is the same as ctrl1 device, and surely the On with 2 button is call ctrl_ln2 with the same fonction as ctrl2 device.
deennoo
Post by deennoo »
I have a temp sensor to, and Domoticz log only says : 2017-06-19 22:17:26.345 XiaomiGateway: unhandled model: using 3.7995
looks like API doesn't boardcast this sensors information for the moment
The square wireless switch isn't on the app for the moment
deennoo
Post by deennoo »
TigroEHOT wrote:Hi all!
I bought a couple of single button switches with neutral line and power usage report. But in Domoticz log I see unhandled model: ctrl_ln1
Just should wait for the update or I can help in anyway? Is there any data I can collect and provide?
this switch doesn't provied any power usage, he just show how is your voltage
langoo
Post by langoo »
Will this helpension? This is one off the new Aqara Temp/Hum sensors. I see in the app that the gateway updates the values from the sensors if I for example blows on them.
2017-06-19 23:34:51.639 XiaomiGateway: unhandled model:
2017-06-19 23:34:51.639 {"cmd":"read_ack","model":"","sid":"158d0001a1fa0e","short_id":24884,"data":"{\"voltage\":2965}"}
deennoo
Post by deennoo »
As you Can see the only data forcasted is the battery voltage...
warmaniac
Post by warmaniac »
We need to wait for fw update of gateway :( , maybe sometimes it will be done.
TigroEHOT
Post by TigroEHOT »
deennoo wrote: Your switch is the wall mounted one ?this one who need Line and neutral ? with a single button ?
Yes, right.
langoo
Post by langoo »
Yes that seems as the only solution right now.
deennoo
Post by deennoo »
Arrive on the app today the water sensor
Don't know where to get it.
About square device (wireless square switch, square door sensor, square temp and the new pir (with led) : gearbest can't have them anymore.Image
langoo
Post by langoo »
deennoo wrote:Arrive on the app today the water sensor
What do you mean with gearbest can't have them?
http://www.gearbest.com/access-control/pp_626702.html
benbammens
Post by benbammens »
OK, the new temperature sensors show up in the android app.
I still can't see them in Domoticz though...
deennoo
Post by deennoo »
They will never ship them even if they are on sale...
deennoo
Post by deennoo »
benbammens wrote:OK, the new temperature sensors show up in the android app.
As explain previously
langoo
Post by langoo »
I bought mine from them...
deennoo
Post by deennoo »
I add ones to but they will not get them anymore
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
Same for me have the new door sensor.
Button in on it's way too.
