2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-19 22:04:46.533 {"cmd":"report","model":"ctrl_ln1","sid":"158d00012a35e7","short_id":24692,"data":"{\"channel_0\":\"off\"}"}
nothing new for me , have 2 pcs new Aqara magnet door/window plus 2pcs Aqara Temperature/Humidity/Pressure sensorscorbin wrote:@langoo and @TigroEHOT
When it reports 'unhandled model', it should say what the name is, ieI need to know what the name is (tempsensor in the above example) and what device it is. Also will need an example of the raw message output - enable raw gateway messages - see https://www.domoticz.com/wiki/Xiaomi_Ga ... leshootingCode: Select all
XiaomiGateway: unhandled model: tempsensor
2017-06-19 14:22:49.464 2017-06-19 14:22:49.464 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.465 2017-06-19 14:22:49.465 {"cmd":"read_ack","model":"","sid":"158d00017200ff","short_id":26405,"data":"{\"voltage\":3015}"}
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 {"cmd":"read_ack","model":"","sid":"158d0001a4c79e","short_id":44567,"data":"{\"voltage\":3005}"}
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 {"cmd":"read_ack","model":"","sid":"158d00016c3e55","short_id":55642,"data":"{\"voltage\":3045}"}
2017-06-19 14:22:49.468 2017-06-19 14:22:49.468 {"cmd":"read_ack","model":"","sid":"158d00016c402b","short_id":30460,"data":"{\"voltage\":3035}"}
- Domoticz version: V4.11375
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
I try to install this but get a error when trying to install enumdeennoo wrote:A simple how to is online for yeelight bedside lamp & Domoticz : http://domo-attitude.fr/tuto-lampe-de-c ... -domoticz/SwordFish wrote:Sory for asking but is it on your blog already?deennoo wrote:
Cant find it.
That in simple french word, google translate do a good job, i'll provied a how to on domoticz wiki next week.
If some one can help by provieding a Python Plugin this can be perfect
Is it also possible to control 2 bedlights?
pi@raspberrypi:~ $ sudo pip3 install enum
Downloading/unpacking enum
Downloading enum-0.4.6.tar.gz
Running setup.py (path:/tmp/pip-build-2iowbxb_/enum/setup.py) egg_info for package enum
File "<string>", line 3, in <module>
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 12, in <module>
from setuptools.extension import Extension
File "/usr/lib/python3/dist-packages/setuptools/extension.py", line 7, in <module>
from setuptools.dist import _get_unpatched
File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 16, in <module>
from setuptools.depends import Require
File "/usr/lib/python3/dist-packages/setuptools/depends.py", line 6, in <module>
from setuptools import compat
File "/usr/lib/python3/dist-packages/setuptools/compat.py", line 45, in <module>
import http.client as httplib
File "/usr/lib/python3.4/http/client.py", line 69, in <module>
import email.parser
File "/usr/lib/python3.4/email/parser.py", line 12, in <module>
from email.feedparser import FeedParser, BytesFeedParser
File "/usr/lib/python3.4/email/feedparser.py", line 27, in <module>
from email import message
File "/usr/lib/python3.4/email/message.py", line 16, in <module>
from email import utils
File "/usr/lib/python3.4/email/utils.py", line 29, in <module>
import socket
File "/usr/lib/python3.4/socket.py", line 51, in <module>
from enum import IntEnum
ImportError: cannot import name 'IntEnum'
Complete output from command python setup.py egg_info:
import email.parser
import socket
please contact me on my blog...this topic is for xiaomi zigbee device ok ?SwordFish wrote:I try to install this but get a error when trying to install enumdeennoo wrote:A simple how to is online for yeelight bedside lamp & Domoticz : http://domo-attitude.fr/tuto-lampe-de-c ... -domoticz/SwordFish wrote:
Cant find it.
pi@raspberrypi:~ $ sudo pip3 install enum Downloading/unpacking enum Downloading enum-0.4.6.tar.gz Running setup.py (path:/tmp/pip-build-2iowbxb_/enum/setup.py) egg_info for package enum Traceback (most recent call last): File "<string>", line 3, in <module> File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 12, in <module> from setuptools.extension import Extension File "/usr/lib/python3/dist-packages/setuptools/extension.py", line 7, in <module> from setuptools.dist import _get_unpatched File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 16, in <module> from setuptools.depends import Require File "/usr/lib/python3/dist-packages/setuptools/depends.py", line 6, in <module> from setuptools import compat File "/usr/lib/python3/dist-packages/setuptools/compat.py", line 45, in <module> import http.client as httplib File "/usr/lib/python3.4/http/client.py", line 69, in <module> import email.parser File "/usr/lib/python3.4/email/parser.py", line 12, in <module> from email.feedparser import FeedParser, BytesFeedParser File "/usr/lib/python3.4/email/feedparser.py", line 27, in <module> from email import message File "/usr/lib/python3.4/email/message.py", line 16, in <module> from email import utils File "/usr/lib/python3.4/email/utils.py", line 29, in <module> import socket File "/usr/lib/python3.4/socket.py", line 51, in <module> from enum import IntEnum ImportError: cannot import name 'IntEnum' Complete output from command python setup.py egg_info: Traceback (most recent call last): File "<string>", line 3, in <module> File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 12, in <module> from setuptools.extension import Extension File "/usr/lib/python3/dist-packages/setuptools/extension.py", line 7, in <module> from setuptools.dist import _get_unpatched File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 16, in <module> from setuptools.depends import Require File "/usr/lib/python3/dist-packages/setuptools/depends.py", line 6, in <module> from setuptools import compat File "/usr/lib/python3/dist-packages/setuptools/compat.py", line 45, in <module> import http.client as httplib File "/usr/lib/python3.4/http/client.py", line 69, in <module> import email.parser File "/usr/lib/python3.4/email/parser.py", line 12, in <module> from email.feedparser import FeedParser, BytesFeedParser File "/usr/lib/python3.4/email/feedparser.py", line 27, in <module> from email import message File "/usr/lib/python3.4/email/message.py", line 16, in <module> from email import utils File "/usr/lib/python3.4/email/utils.py", line 29, in <module> import socket File "/usr/lib/python3.4/socket.py", line 51, in <module> from enum import IntEnum ImportError: cannot import name 'IntEnum'
Your switch is the wall mounted one ?this one who need Line and neutral ? with a single button ?TigroEHOT wrote:2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
I just recieve a dual switch from this serie, but didn't open it already, will try to help Corbin
@corbin this device is the same as ctrl1 device, and surely the On with 2 button is call ctrl_ln2 with the same fonction as ctrl2 device.
I have a temp sensor to, and Domoticz log only says : 2017-06-19 22:17:26.345 XiaomiGateway: unhandled model: using 3.7995corbin wrote:@langoo and @TigroEHOT
looks like API doesn't boardcast this sensors information for the moment
The square wireless switch isn't on the app for the moment
this switch doesn't provied any power usage, he just show how is your voltageTigroEHOT wrote:Hi all!
I bought a couple of single button switches with neutral line and power usage report. But in Domoticz log I see unhandled model: ctrl_ln1
Just should wait for the update or I can help in anyway? Is there any data I can collect and provide?
Will this helpension? This is one off the new Aqara Temp/Hum sensors. I see in the app that the gateway updates the values from the sensors if I for example blows on them.corbin wrote:@langoo and @TigroEHOT
2017-06-19 23:34:51.639 XiaomiGateway: unhandled model:
2017-06-19 23:34:51.639 {"cmd":"read_ack","model":"","sid":"158d0001a1fa0e","short_id":24884,"data":"{\"voltage\":2965}"}
As you Can see the only data forcasted is the battery voltage...langoo wrote:Will this helpension? This is one off the new Aqara Temp/Hum sensors. I see in the app that the gateway updates the values from the sensors if I for example blows on them.corbin wrote:@langoo and @TigroEHOT
2017-06-19 23:34:51.639 XiaomiGateway: unhandled model: 2017-06-19 23:34:51.639 {"cmd":"read_ack","model":"","sid":"158d0001a1fa0e","short_id":24884,"data":"{\"voltage\":2965}"}
We need to wait for fw update of gateway , maybe sometimes it will be done.deennoo wrote:As you Can see the only data forcasted is the battery voltage...langoo wrote:Will this helpension? This is one off the new Aqara Temp/Hum sensors. I see in the app that the gateway updates the values from the sensors if I for example blows on them.corbin wrote:@langoo and @TigroEHOT
Yes, right.deennoo wrote: Your switch is the wall mounted one ?this one who need Line and neutral ? with a single button ?
Yes that seems as the only solution right now.warmaniac wrote:We need to wait for fw update of gateway , maybe sometimes it will be done.deennoo wrote:As you Can see the only data forcasted is the battery voltage...langoo wrote:
Arrive on the app today the water sensor
Don't know where to get it.
About square device (wireless square switch, square door sensor, square temp and the new pir (with led) : gearbest can't have them anymore.
What do you mean with gearbest can't have them?deennoo wrote:Arrive on the app today the water sensor
http://www.gearbest.com/access-control/pp_626702.html
OK, the new temperature sensors show up in the android app.
I still can't see them in Domoticz though...
As explain previouslybenbammens wrote:OK, the new temperature sensors show up in the android app.
I bought mine from them...deennoo wrote:They will never ship them even if they are on sale...langoo wrote:
I add ones to but they will not get them anymore
- Domoticz version: v4.11307
Same for me have the new door sensor.langoo wrote:I bought mine from them...deennoo wrote:They will never ship them even if they are on sale...langoo wrote:
Button in on it's way too.
