Blocky to Lua
theo69
Domoticz version: la. beta
Blocky to Lua
Post by theo69 »
Hi there I am a total n00b and just starting, now i have a blocky script i would like to translate into Lua (because I need it more often and Lua is easy to copy) Tried a lot but failed, maybe somebody can push me into the right direction :?
Thanks a lot
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
emme
Domoticz version: latest
Re: Blocky to Lua
Post by emme »
   if otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'Off' then
      commandArray['Testschalter'] = 'On AFTER 1'
   elseif otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'On' then
      commandArray['Testschalter'] = 'Off AFTER 1'
but a smarter way would be:
   if otherdevices['Einfachschalter'] == 'On' then
      if otherdevices['Testschalter'] == 'Off' then
ciao
M
"We always done this way"
theo69
Re: Blocky to Lua
Post by theo69 »
ciao
M
Wow thanky a lot trying to understand but still a noob, i tried to get rid of the delay and did:
         commandArray['Einfachschalter'] = 'Off' and commandArray['Testschalter'] = 'On'
      elseif otherdevices['Testschalter'] == 'On' then
         commandArray['Einfachschalter'] = 'Off' and commandArray['Testschalter'] = 'Off'
however its not working, where did i go wrong?
GJKNL
Re: Blocky to Lua
Post by GJKNL »
Try this. But I do not understand your logic. Now you switch something off and on and then you switch both devices off again??
         commandArray['Einfachschalter'] = 'Off''
jvdz
Domoticz version: 4.107
Re: Blocky to Lua
Post by jvdz »
emme wrote: but a smarter way would be:
This code feels flawed to me and will constantly trigger Testschalter On and Off while Einfachschalter is On... or am I seeing that wrong?
Jos
emme
Re: Blocky to Lua
Post by emme »
jvdz wrote:This code feels flawed to me and will constantly trigger Testschalter on and of while Einfachschalter is On... or am I seeing that wrong?
my understanding of the Blockly script is to toggle Testschalter after 1 sec when Einfaschalter is on....
yes... Testschalter will flash 1sec while Einfachschalter id ON....
Wasn't this the intention? :oops: :oops:
jvdz
Re: Blocky to Lua
Post by jvdz »
The difference with the Blockly code is that it will only act of a devicechange event and your script will trigger each time it is run by an event.
So to reflect the exact code you need to use devicechanged:
   if devicechanged['Einfachschalter'] == 'On' then
Jos
theo69
Re: Blocky to Lua
Post by theo69 »
Thanks to all, my problem is I am using a wireless Xiaomi Aqara Wall Switch, I have to set the off delay to 1 sec otherwise its not switching off again. Therefore I have to use a dummy switch to use the switch in my homekit (Apple). Maybe I went wrong with my script and thinking....
I would like to get rid of the 1 sec delay.
theo69
Re: Blocky to Lua
Post by theo69 »
I think I start to understand all these:
Its now working perfekt, thanks this a really a great community!!!!
