Thanks a lot
Blocky to Lua
theo69
- Domoticz version: la. beta
Blocky to Lua
Hi there I am a total n00b and just starting, now i have a blocky script i would like to translate into Lua (because I need it more often and Lua is easy to copy) Tried a lot but failed, maybe somebody can push me into the right direction
Thanks a lot
Thanks a lot
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
- emme
- Domoticz version: latest
Re: Blocky to Lua
if otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'Off' then
commandArray['Testschalter'] = 'On AFTER 1'
elseif otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'On' then
commandArray['Testschalter'] = 'Off AFTER 1'
return commandArrayCode: Select all
if otherdevices['Einfachschalter'] == 'On' then
if otherdevices['Testschalter'] == 'Off' then
return commandArrayM
"We always done this way"
theo69
Re: Blocky to Lua
Wow thanky a lot trying to understand but still a noob, i tried to get rid of the delay and did:emme wrote:but a smarter way would be:Code: Select all
commandArray = {} if otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'Off' then commandArray['Testschalter'] = 'On AFTER 1' elseif otherdevices['Einfachschalter'] == 'On' and otherdevices['Testschalter'] == 'On' then commandArray['Testschalter'] = 'Off AFTER 1' end return commandArrayciaoCode: Select all
commandArray = {} if otherdevices['Einfachschalter'] == 'On' then if otherdevices['Testschalter'] == 'Off' then commandArray['Testschalter'] = 'On AFTER 1' else commandArray['Testschalter'] = 'Off AFTER 1' end end return commandArray
M
commandArray['Einfachschalter'] = 'Off' and commandArray['Testschalter'] = 'On'
elseif otherdevices['Testschalter'] == 'On' then
commandArray['Einfachschalter'] = 'Off' and commandArray['Testschalter'] = 'Off'
return commandArrayLove my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
GJKNL
Re: Blocky to Lua
Try this. But I do not understand your logic. Now you switch something off and on and then you switch both devices off again??
commandArray['Einfachschalter'] = 'Off''
- jvdz
- Domoticz version: 4.107
Re: Blocky to Lua
This code feels flawed to me and will constantly trigger Testschalter On and Off while Einfachschalter is On... or am I seeing that wrong?emme wrote: but a smarter way would be:Code: Select all
Jos
- emme
Re: Blocky to Lua
my understanding of the Blockly script is to toggle Testschalter after 1 sec when Einfaschalter is on....jvdz wrote:This code feels flawed to me and will constantly trigger Testschalter on and of while Einfachschalter is On... or am I seeing that wrong?
yes... Testschalter will flash 1sec while Einfachschalter id ON....
Wasn't this the intention?
- jvdz
Re: Blocky to Lua
The difference with the Blockly code is that it will only act of a devicechange event and your script will trigger each time it is run by an event.
So to reflect the exact code you need to use devicechanged:
Jos
if devicechanged['Einfachschalter'] == 'On' then
return commandArray-
theo69
Re: Blocky to Lua
Thanks to all, my problem is I am using a wireless Xiaomi Aqara Wall Switch, I have to set the off delay to 1 sec otherwise its not switching off again. Therefore I have to use a dummy switch to use the switch in my homekit (Apple). Maybe I went wrong with my script and thinking....
I would like to get rid of the 1 sec delay.
theo69
Re: Blocky to Lua
I think I start to understand all these:
Its now working perfekt, thanks this a really a great community!!!!
