pvm
Domoticz version: 4.10538
Post by pvm »
Mat2Vence wrote:Just move to the new version 3.7449 but it did not solve the issue of RGB and sound.
Did you try the solution of mrefex a couple of posts above your previous one? Any change?
Mat2Vence
Domoticz version: 3.7449
Post by Mat2Vence »
pvm wrote: Did you try the solution of mrefex a couple of posts above your previous one? Any change?
I jus tried... but the still the same issue.
Look like the communication is only broken from domoticz to xiaomi because if I am switching the light of the gateway ON, I am getting the correct status back into domoticz. But I cannot control it from the domoticz interface.
Sale for both sound and RGB for which it does not work anymore.
For instance, I only remove RGB and anything related to the sound and MP3... hopefully I should not have to remove all the other sensors....
bar1
Post by bar1 »
Does anyone know if the new Aqara sensors connect to the gateway or directly to the wifi?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
izmirkubiak
Post by izmirkubiak »
bar1 wrote:Does anyone know if the new Aqara sensors connect to the gateway or directly to the wifi?
Apparently it will be in zigbee so with the gateway.
bar1
Post by bar1 »
THANKS for the reply.
so it will work with this gateway:
http://www.gearbest.com/alarm-systems/pp_345588.html
superelch
Post by superelch »
simple hack:
put the door sensor very close to the Electromagnetic coil of your doorbell. works for me. easy hack without any soldering. ;-)
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
pvm
Post by pvm »
superelch wrote:simple hack:
Brilliant!
MrNikos
Post by MrNikos »
Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10 :-( . Is anyone using this setup? Many thanks
deennoo
Post by deennoo »
SwordFish wrote:I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
Bedlight works on Bluetooth only.
There is a trick for it i made it works with a simple bt4le dongle and a script found on github.
This control :
Brightness
On/off
Color
White temp
I will provied a how to quickly on my blog
http://domo-attitude.fr
deennoo
Post by deennoo »
MrNikos wrote:Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10 :-( . Is anyone using this setup? Many thanks
I'm that easy 2 ways
Using rflink following this : http://domo-attitude.fr/controlez-vos-milights-rflink/
Or using milight gateway
After that just a matter of event / script / scene / group as basic elements of domoticz
MrNikos
Post by MrNikos »
So i can make use of the switch/motion sensor/ doorsensor of xiaomi to switch on the milight? I already have a milight gateway!
SwordFish
Post by SwordFish »
This control :
Brightness
On/off
Color
White temp
But please not in france ;)
marcotrumpet
Post by marcotrumpet »
I use the xiaomi round switch to toggle on/off both yeelight and milight bulb (I use milight for gu10 reason too)
Inviato dal mio SM-G950F utilizzando Tapatalk
MrNikos
Post by MrNikos »
Very good! Many thanks for the information.
deennoo
Post by deennoo »
Yes of course you can !
I have got one (motion sensor) who fire 2 milights bulb for 2 minutes and if there is no move after 2 minutes trigger them off, if still mouvement after 2 keep them on
deennoo
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
This control :
Brightness
On/off
Color
White temp
My blog can be translate via google translate, as i use simple french word and sentence translate is good.
Think about us french guys who have to read english to learn how to.
bertbigb
Post by bertbigb »
deennoo wrote:
And what to think about the Dutch guys, we need to learn English, German and French. But the more languages you know the less complicated it gets. The good news: Thanks Google Translate . :lol:
Best regards Bert
Synology DS1517+ - DSM 6.2
SwordFish
Post by SwordFish »
Thanks will try it when the lights arrived.
farhanito
Post by farhanito »
sorry for my ignorance, but what does this hack do?
Users browsing this forum: djdehaan and 1 guest
