Did you try the solution of mrefex a couple of posts above your previous one? Any change?Mat2Vence wrote:Just move to the new version 3.7449 but it did not solve the issue of RGB and sound.
- Domoticz version: 4.10538
- Domoticz version: 3.7449
I jus tried... but the still the same issue.pvm wrote: Did you try the solution of mrefex a couple of posts above your previous one? Any change?
Look like the communication is only broken from domoticz to xiaomi because if I am switching the light of the gateway ON, I am getting the correct status back into domoticz. But I cannot control it from the domoticz interface.
Sale for both sound and RGB for which it does not work anymore.
For instance, I only remove RGB and anything related to the sound and MP3... hopefully I should not have to remove all the other sensors....
Does anyone know if the new Aqara sensors connect to the gateway or directly to the wifi?
- Domoticz version: V4.11375
I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
- Target OS: -
Apparently it will be in zigbee so with the gateway.bar1 wrote:Does anyone know if the new Aqara sensors connect to the gateway or directly to the wifi?
THANKS for the reply.
so it will work with this gateway:
http://www.gearbest.com/alarm-systems/pp_345588.html
- superelch
simple hack:
put the door sensor very close to the Electromagnetic coil of your doorbell. works for me. easy hack without any soldering.
Raspberry / Domoticz (beta) / z-wave & xiaomi & habridge & 5x Alexa & google dots & milight & yeelight & harmony hub & Netatmo & ITTT & sonoff & Conbee II .... & a girlfriend who hates that stuff ...
Brilliant!superelch wrote:simple hack:
Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10
. Is anyone using this setup? Many thanks
Bedlight works on Bluetooth only.SwordFish wrote:I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
There is a trick for it i made it works with a simple bt4le dongle and a script found on github.
This control :
Brightness
On/off
Color
White temp
I will provied a how to quickly on my blog
http://domo-attitude.fr
I'm that easy 2 waysMrNikos wrote:Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10. Is anyone using this setup? Many thanks
Using rflink following this : http://domo-attitude.fr/controlez-vos-milights-rflink/
Or using milight gateway
After that just a matter of event / script / scene / group as basic elements of domoticz
So i can make use of the switch/motion sensor/ doorsensor of xiaomi to switch on the milight? I already have a milight gateway!deennoo wrote:I'm that easy 2 waysMrNikos wrote:Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10. Is anyone using this setup? Many thanks
Thanksdeennoo wrote:Bedlight works on Bluetooth only.SwordFish wrote:I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
This control :
Brightness
On/off
Color
White temp
But please not in france
I use the xiaomi round switch to toggle on/off both yeelight and milight bulb (I use milight for gu10 reason too)MrNikos wrote:So i can make use of the switch/motion sensor/ doorsensor of xiaomi to switch on the milight? I already have a milight gateway!deennoo wrote:I'm that easy 2 waysMrNikos wrote:Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10. Is anyone using this setup? Many thanks
Inviato dal mio SM-G950F utilizzando Tapatalk
Very good! Many thanks for the information.
Yes of course you can !MrNikos wrote:So i can make use of the switch/motion sensor/ doorsensor of xiaomi to switch on the milight? I already have a milight gateway!deennoo wrote:I'm that easy 2 waysMrNikos wrote:Super information! After reading this information i ordered and recieved a lot of Xiaomi gear. I am very happy with the set it workes fantastic. Ordered the kit with a zigbee plug. Now this week im gooing to prepare my RP3 for domoticz because i want to use MiLight bulbs and GU10 spots because yeelight does not have the GU10. Is anyone using this setup? Many thanks
I have got one (motion sensor) who fire 2 milights bulb for 2 minutes and if there is no move after 2 minutes trigger them off, if still mouvement after 2 keep them on
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
My blog can be translate via google translate, as i use simple french word and sentence translate is good.SwordFish wrote:Thanksdeennoo wrote:Bedlight works on Bluetooth only.SwordFish wrote:I have been following this for a while now and have the gateway up and running. But i have a question can you control the Xiaomi bedlights with this gateway or with yeelight plugin or not at all. But great job with this plugin
This control :
Brightness
On/off
Color
White temp
Think about us french guys who have to read english to learn how to.
And what to think about the Dutch guys, we need to learn English, German and French. But the more languages you know the less complicated it gets. The good news: Thanks Google Translate .deennoo wrote:SwordFish wrote:
Best regards Bert
Synology DS1517+ - DSM 6.2
Thanks will try it when the lights arrived.My blog can be translate via google translate, as i use simple french word and sentence translate is good.
sorry for my ignorance, but what does this hack do?superelch wrote:simple hack:
